IoX Finder - Error Not Found warning
I am certain someone know why I receive this warning everytime I initiate the IoX Finder.  Admin console and Polyglot open without error or warning.  Everything works as is should.  But I get this popup error everytime I start the IoX Finder.  Any thoughts?  Thank you
Solved by Geddy
Yes, I started getting this error message a week or so ago.  Never  got it before.  Once I clear it with “OK” and load the LAN version of the console, everything seems to work OK.  But I need to load the console in between repeated error messages since the console won’t load while the error message is still visible.    I guess it’s just a bother to have to clear the message but I am concern that it means something else is not right.
I am getting the same message with my ISY 994i.  I don’t think there is any firmware update for ISY 994i.  Am I use supposed to live with this error message that needs to be cleared?
Once I clear the error message and launch the LAN console, everything appears to work correctly.  I will assume that to be the case then until I find something going wrong or hear of an update.
This has been fixed…you need to clear Java cache, download a new “start.jnlp” file from UDI site (click on “My ISY”) and it should be fixed. This was reported several weeks ago and downloading a new IoX launcher seemed to fix it. Make sure you delete any existing start.jnlp or admin.jnlp files before proceeding.
You mention Polyglot, but posted in ISY994 area…moving to IoX since it’s not really clear you’re using the 994. But agreed, with @Javi it’s not really a firmware issue, but you are behind. Many bugs have been fixed and enhancements made since 5.5.9 so you should try to stay current.
You need to clear Java cache and download a new start.jnlp file. Make sure you delete any existing copies on your system before proceeding.
  • 3 weeks later...
I assume that the two entries in the IoX Finder link to the same target.  Is there a reason there needs to be two links to the same eisy?
