0.9.6x is available
Hi
A new and updated version of the server is live now.
Release note:
0.9.63 - Fixed bug with system going offline not showing.
Added Smoke detector
Added Siren (usable as a controllable 12V supply)
Updated sensors to allow config of DON/DOF behavior.
Changed use model for delays in switches, outlets (incl multi) and manipulators.  Now allows programing both ON and OFF delay in 1 operation (using new drop down) - the delay settings now prepare the delay - not executing it.  The main reason for this is to allow a programmed sequence of both on and off (or vice versa) - e.g. to power cycle the internet connection - or ensure a valve turns off even if internet goes down in-between 2 programming operations. (Note, yolink API changed behavior of delay so the delay will now be reset (removed) if a new command if issued after the programming of a delay)
Tried to update and now it shows “disconnected”. When I hit start it tells me that the nodeserver is already running….
Log file is empty. Can’t get it to show anything.
does the main log show something - Maybe try to power cycle your Polisy/eisy
What procedure did you use - I have been using replace existing (click half way up when installing the  updated node
Edited by Panda88
Power cycled eisy with no change.
Not sure what procedures used. Think I just updated from purchased ns store then installed?? Later on I purchased and installed again just to try.
Can’t get log to show anything…
When I hit “stop” there is a message and progress bar showing it stops. When I hit start there is no message or progress bar…If I hit start again it just says “ns already running”   If I hit “restart” there is no messages or progress bars.
About to delete and reinstall but rather not.
Edited by drprm1
Did you try to click download log?   I find the gui sometmes do not show the log, but it is there if you download it
Did you click reinstall here? button when upgrading?
Never reinstalled, pretty sure just updated….
Tried to download log and I get a red pop up message saying “Error, file not found………”
try to go to store - and install again - click the reinstall here button
That way you do not need to reinstall
Edited by Panda88
Reinstalled to same slot.
No changes
Still showing disconnected. When hit Start still says it’s already running.
still no log
Edited by drprm1
did you check the main polisy log (not the individual node log) - to see if there is any info?
I have no idea what is happening - it seems to be PG3 - related - maybe bob can help
I don’t see anything in the Polyglot log.
PG3 related? Started with this update so would think problem lies there?
Would like to hear if this happened on anyone else’s PG
Edited by drprm1
Correct, but it is PG3 handling the update - There have been some changes lately but it is very difficult to test as developer as you have different privileges
I tried Reinstall Here, Stop/Start, and Restart. Version still shows 0.8.99 and Disconnected.
Does this help? It's from the PG3 log.
10/2/2023, 18:43:30 [pg3] info: startNs:: YoLink
10/2/2023, 18:43:30 [pg3] info: startNs:: YoLink is valid
10/2/2023, 18:43:30 [pg3] info: checkLicense:: YoLink Valid perpetual license found.
10/2/2023, 18:43:30 [pg3] info: startNs:: YoLink finished update check
10/2/2023, 18:43:30 [pg3] info: Received commands on topic udi/pg3/frontend/system/admin: getStoreEntry
10/2/2023, 18:43:30 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c010004a629
10/2/2023, 18:43:30 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 14.191932ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c010004a629
10/2/2023, 18:43:30 [pg3] info: Getting Node Server store entry for nsid 78312440-23ea-4ed6-9361-9cdc2d5e7c6b from store Production
10/2/2023, 18:43:30 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c01000560b0
10/2/2023, 18:43:30 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 12.402224ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c01000560b0
10/2/2023, 18:43:30 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c010005ad2c
10/2/2023, 18:43:30 [pg3] error: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [404 - OK] :: 10.028043ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c010005ad2c
10/2/2023, 18:43:30 [pg3] error: [00:0d:b9:5d:9b:24_2] getNode failed :: TypeError: Cannot read properties of undefined (reading 'data')
10/2/2023, 18:43:30 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c010005dea5
10/2/2023, 18:43:30 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 11.314377ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c010005dea5
10/2/2023, 18:43:30 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c0100060595
10/2/2023, 18:43:30 [pg3] error: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [404 - OK] :: 10.395288ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c0100060595
10/2/2023, 18:43:31 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002abcf
10/2/2023, 18:43:31 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 11.807533ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002abcf
10/2/2023, 18:43:31 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002abd0
10/2/2023, 18:43:31 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 11.193565ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002abd0
10/2/2023, 18:43:31 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002b231
10/2/2023, 18:43:31 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 11.177191ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002b231
10/2/2023, 18:43:31 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002f11b
10/2/2023, 18:43:31 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 11.447724ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c020002f11b
10/2/2023, 18:43:31 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_8b4c0200031535
10/2/2023, 18:43:31 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 11.242035ms - http://127.0.0.1:8080/rest/nodes/n002_8b4c0200031535
10/2/2023, 18:43:31 [pg3] info: IoX Request: [Try: 1] [00:0d:b9:5d:9b:24] :: - http://127.0.0.1:8080/rest/nodes/n002_setup
10/2/2023, 18:43:31 [pg3] info: IoX Response: [Try: 1] [00:0d:b9:5d:9b:24] :: [200] :: 10.842269ms - http://127.0.0.1:8080/rest/nodes/n002_setup
10/2/2023, 18:43:31 [pg3] info: startNs:: Starting YoLink
10/2/2023, 18:43:31 [pg3] info: call_udx: Making request to socket with url /rest/pg3.start.ns
10/2/2023, 18:43:31 [pg3] info: startNs:: YoLink starting polls
10/2/2023, 18:43:31 [pg3] info: Starting YoLink Info timer 0
10/2/2023, 18:43:31 [pg3] info: startNs:: YoLink updating database (enabled, timestarted)
10/2/2023, 18:43:31 [pg3] info: startNs:: YoLink started.
10/2/2023, 18:43:31 [pg3] info: Received commands on topic udi/pg3/frontend/system/admin: getStoreEntry
10/2/2023, 18:43:31 [pg3] info: Getting Node Server store entry for nsid 78312440-23ea-4ed6-9361-9cdc2d5e7c6b from store Production
10/2/2023, 18:43:33 [pg3] info: Received commands on topic udi/pg3/frontend/ns/admin: startLogging
10/2/2023, 18:43:33 [pg3] info: Is client running? /var/polyglot/pg3/ns/000db95d9b24_2/logs/debug.log does not exist.
10/2/2023, 18:43:40 [pg3] info: Received commands on topic udi/pg3/frontend/ns/admin: setLogLevel
10/2/2023, 18:43:40 [pg3] info: Received commands on topic udi/pg3/frontend/system/admin: getStoreEntry
10/2/2023, 18:43:40 [pg3] info: Getting Node Server store entry for nsid 78312440-23ea-4ed6-9361-9cdc2d5e7c6b from store Production
10/2/2023, 18:43:41 [pg3] error: downloadLog: Error: File not found: /var/polyglot/pg3/ns/000db95d9b24_2/logs/debug.log
    at Object.addLocalFile (/var/polyglot/node_modules/adm-zip/adm-zip.js:258:23)
    at /var/polyglot/node_modules/@universaldevices/pg3x/lib/routes/log.js:94:16
    at async /var/polyglot/node_modules/@universaldevices/pg3x/lib/services/https.js:48:9
10/2/2023, 18:43:46 [pg3] info: Received commands on topic udi/pg3/ns/command/00:0d:b9:5d:9b:24_
Edited by landolfi
I rebooted and did Reinstall Here. Now the Yolink NS shows as 0.9.63 but still disconnected, and Start results in "Node Server Start: Already running".
It is likely and issue for Bob - I sent him a message already
on PG3x
Edited by drprm1
Maybe try power cycling and if needed reinstall node server after the restart?
Have power cycled a  few times.
As stated earlier that reinstalling would be next and that I'd rather not. (i know not a giant task) but Panda88 said I shouldn't have to.
I'm having the same problem. eisy, PG3x 3.2.8.  The installed version is 0.9.63, status is disconnected. Tried Update Packages, reboot, power cycle, reinstall, stop, start.  The YoLink nodes show in PG3x but not in the AC.
@bpwwer
Bob, do you have any idea what may be happening.  Works fine on both my setups (PG3 and PG3x)
Same problem PG3x 3.2.8 , Yo-Link at 0.9.63, twice reinstall, reboot of EISY, many restart or stop/start, also did a 'Add all nodes' in the admin.  Status still disconnected.
Did the update work for anybody (except the author)?
BTW: :  during frustrating times I do want to say how much I appreciate this node server and your efforts....this too shall pass.
Edited by sjenkins
Same problem as the others and EISY is current on everything.  Yo-Link did upgrade to 0.9.63, but is disconnected.  I agree Yo-Link and this Node server are great to have.
Does anyone get a log file from the node server - please enable debug and try to start it -
I'm not very familiar with logs.  I did Log, selected Debug, Start.  Then I tried to download the Log Package.  I received a red popup with file not found.  I tried some other Log options and never did get a log window.
