EISY Normal Temperature
I appreciate the body of the EISY is a heatsink but what is considered the "normal" surface temperature of EISY.  Mine is almost uncomfortable to pick up and a quick measure shows it at about 45C.  It is only running the standard UDI packages of Insteon plus a few Poly's - nothing extra.
Just concerned that running hot 24/7 will affect lifespan.
Solved by Michel Kohanim
Put some ventilation spacers underneath or stand it vertically by some means.
Spacers can be short pipe slices or hex nuts.
I have a MeLE 3C running Ubuntu 24/7/375
Keep in mind the finned top is actually plastic, not aluminum.   Make sure it is well ventilated on all sides.
root@mele-ud22:~# sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +47.0°C  (high = +105.0°C, crit = +105.0°C)
Core 0:        +41.0°C  (high = +105.0°C, crit = +105.0°C)
Core 1:        +41.0°C  (high = +105.0°C, crit = +105.0°C)
Core 2:        +41.0°C  (high = +105.0°C, crit = +105.0°C)
Core 3:        +41.0°C  (high = +105.0°C, crit = +105.0°C)
acpitz-acpi-0
Adapter: ACPI interface
temp1:        +27.8°C  (crit = +119.0°C)
nvme-pci-0200
Adapter: PCI adapter
Composite:    +39.9°C  (low  =  -0.1°C, high = +84.8°C)
                       (crit = +94.8°C)
Sensor 1:     +40.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 2:     +46.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 8:     +40.9°C  (low  = -273.1°C, high = +65261.8°
Thanks for the feedback folks.  It hasn't reached egg frying temperature so I guess running warm is normal.
