How to temporarily comment out a line in a program (for easier testing) ?
EJones01
Go to solution Solved by EJones01,
Its common practice to comment out code when testing, but I can't find an easy way to do this? Currently I have to copy a program and then delete lines....but thats very slow as once deleted I have to copy again. Any help would be appreciated, thanks
There is no way to comment out commands in a program.
Best you can do is duplicate the program, make changes you want to test and then disable the original program.
Another option, which I use, is to add a comment where the line should go and either type the line in, or a short reminder of what should be there.
This helps me during final 'tweaking' which I'm doing that now on several programs
First, I agree, a simple way to comment out line(s) of code would be nice, but I have used the following method with success.
Check out the last comment in this thread:
OK...so
Repeat 0 times  - stops the next lines running
Repeat 1 times  -  and this starts running lines after this
OK...so
No. Repeat 0 times will execute it once anyway. That syntax is messed up.
Replace the line with WAIT 0 SECONDS.
