ERROR: See log for: Please enable "Allow ISY Access by Plugin" on Configuration Page click "Save" then Restart this plugin.
Solved by Geddy
45 minutes ago, someguy said:
I'm not sure where to "enable "allow isy access by plugin".   can anyone help?
PG3(x) plugin configuration tab.
I looked there and wasn’t sure what to do. There was nothing that related to “allow isy access”. More detail, please. 🙂
I'm traveling now and don't have access, however, on the plugin configuration page there is a sentence that says allow access, or something similar. I think it is a check box.
It was mentioned in a PG3x update about a month ago. If you still can't find it, go back and read the release notes.
One other thought, are you on a recent PG3x version? If not, run update and then reinstall all plugins.
@someguy
Please review: https://forum.universal-devices.com/topic/43175-pg3x-version-3219-outdated/
As @DennisC and the post linked above the option should be on the configuration page.
If you're not seeing that option it might mean you are running an older PG3 version. Please confirm what version you are running and if you have run the "Reinstall all plugin" routine.
I do not run the Elk plugin so can't give a screenshot, but expect it should be an option with a checkbox.
