November 8Nov 8 @Panda88 , after updating to IoX 6.0 and synchronizing UD Mobile, I received an error for Node Server 7 which is Yolink on my system. Please see attached screenshot.As an aside, I have a Yolink local hub that I would like to add to my system. I just want to verify current procedure for including the local hub node server support. Does this require a new plugin purchase (which is fine, just want to know best migration path)?If so, can the updated plugin be installed in same slot, or is a new slot installation required? Keep both running, or just the updated version?Thanks,Dennis
November 8Nov 8 I am still looking for the ST issue - I have not identified where it happens and there is not much in the error from UDmobile -I'll keep lookingLocalHub requires yoLinkLocal - it is a superset of the original Yolink node (doing both local cloud) - I did not find a way to add an upgrade to existing users
November 8Nov 8 Author 53 minutes ago, Panda88 said:I am still looking for the ST issue - I have not identified where it happens and there is not much in the error from UDmobile -I'll keep lookingLocalHub requires yoLinkLocal - it is a superset of the original Yolink node (doing both local cloud) - I did not find a way to add an upgrade to existing users Does that mean it is a new purchase (that's ok, just trying to be sure)?Can it be installed in same slot has original, or does it need to go in to a new slot and all programing updated?
November 8Nov 8 it is a new purchasei believe it is safer to use a new slot but you coul try and back anf the restore after installing the new node Others have more experinse here
November 9Nov 9 Author @Panda88 I had submitted a support ticket regarding the ST issue. @Javi replied with a message to see this post:https://forum.universal-devices.com/topic/45909-in-udm-unable-to-open-settingspluginsyolinklocal/#findComment-399529Wasn't sure if you were aware of this post.
November 10Nov 10 I believe I finally found the issue - I no longer see it on my side after sync to UDmobile
November 11Nov 11 Author 5 hours ago, Panda88 said:I believe I finally found the issue - I no longer see it on my side after sync to UDmobile Updated and synchronized with UD Mobile without errors. Thanks for taking care of this.
November 13Nov 13 5 minutes ago, Panda88 said:OK - back to testing again YoLink plugin was updated this AM as well as the UD Mobile.
November 13Nov 13 Author 26 minutes ago, Panda88 said:OK - back to testing again I am running Yolonk plugin at two locations. Since the last update, I am not receiving errors in UD Mobile when synching.
November 13Nov 13 @Panda88 No longer get that ST issue on UD Mobile. Thanks so much for your persistence in fixing it!
November 13Nov 13 39 minutes ago, BobM99 said:@Panda88 No longer get that ST issue on UD Mobile. Thanks so much for your persistence in fixing it!Ditto, fixed mine as well.Thanks @Panda88!
November 13Nov 13 I am still seeing an ST issue on UD Mobile when syncing, similar to what @TUhl01 posted above. I'm running UD Mobile 1.4.3, with Yolink plugin 1.6.8.
November 13Nov 13 @Javi Is there any way to figure out what Family 10 and Instance 60 refers to? I guess the node (family) is in slot 10 but how do I know what Instance is - It would make debugging easier Edited November 13Nov 13 by Panda88
November 13Nov 13 @DennisC , @BobM99 , and @TJF1960 - what device/firmware are you guys running? I'm on eisy 5.9.1, YoLink plugin 1.6.8, and UD Mobile 1.4.1. I was getting the error still last time I tried to sync. I haven't taken the plunge into 6.0 yet and wondered if the plugins has been fixed with the updated firmware, but still off with older firmware. Fine for me as I don't use UD Mobile enough to worry about the error, but do try to keep it in sync when things update and just updated the YoLink plugin yesterday.Thanks @Panda88 for testing and trying to fix!Edit: Just saw there was an update to UD Mobile. Now running 1.4.3 and indeed still getting error.
November 13Nov 13 Author 2 hours ago, Geddy said:what device/firmware are you guys running?I'm on IoX 6.0, UD Mobile 1.4.4 (Android), and Yolink 1.6.8.Over the last 5 days, I updated both my systems to IoX 6.0. no problems with the update remain except with Elk not parsing data correctly and showing numeric values.I have opened a support ticket with UD, but they haven't located the issue yet.I also have reached out to Jimbo, but he hasn't responded yet.For critical items and wife acceptance, I programed UD Mobile favorites to show what the numerical values should represent.
November 13Nov 13 3 hours ago, Panda88 said:I think I found the bug - try .1.6.9 - just releasedMy system was able to sync without throwing an error using 1.6.9. Thanks!
November 13Nov 13 Thanks @Panda88 for the update. I bit the bullet and updated to 6.0 (took about 15 minutes - no issues in the process - a few plugins wouldn't connect so just reinstalled and they work fine). Also got 1.6.9 updated and no sync issues with UD Mobile (iOS).Thanks @DennisC for the info of running 6.0. I hadn't been home long enough and wanting to take the time to update if I had to "fix" things following it. In all took less than 30 minutes to get things updated and a couple of plugins reconnected. Things seem to be working fine for me. Time will tell. Now I've got to read about the web ui parts and see if that's something I want to dig into. Thankfully trusty "old" java admin console works perfect!
November 14Nov 14 23 hours ago, Panda88 said:@Javi Is there any way to figure out what Family 10 and Instance 60 refers to? I guess the node (family) is in slot 10 but how do I know what Instance is - It would make debugging easierInstance is the slot number, So Family 10 (node Server), instance 60 (slot 60).
November 15Nov 15 On 11/13/2025 at 2:02 PM, Panda88 said:I think I found the bug - try .1.6.9 - just releasedAll good now on my UD Mobile sync. Thanks for the fix.
