December 4Dec 4 When I click on this sequence "Configuration" -> "Portals" to show Portal Integration, I get the error message shown in the screenshot.Everything works perfectly with my system including Alexa and Elk integration and time module.I am on same network as my EISY. I think some information showed here once upon a time. I don't think I used this screen for important information but I'd like to find out how to have everything working correctly with the app.
December 5Dec 5 Have you updated eisy and UD Mobile this week?There was an issue with UD Mobile that I think has been recently corrected. Not sure if it was the UDX for eisy that was updated this week, or a recent UD Mobile app update, but it has been fixed for me. Edited December 5Dec 5 by DennisC Spelling
December 6Dec 6 Author Yes. I updated everything within the last week or so. Running IOX / UI version 6.03 and PG3 version 3.4.5My PG3 error log does have many errors like these from today but I have no idea why:Sat 2025/12/06 09:58:01 AM System -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Sat 2025/12/06 09:58:04 AM System -170001 <s:Envelope><s:Body><u:GetDisclaimerStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetDisclaimerStatus></s:Body></s:Envelope> Sat 2025/12/06 09:59:04 AM System -170001 <s:Envelope><s:Body><u:SetDebugLevel xmlns:u="urn:udi-com:service:X_IoX_Service:1"><option>0</option></u:SetDebugLevel></s:Body></s:Envelope>
December 6Dec 6 Check that you are running udx (v4.2.0).You can check by running https://eisy.local:8443/WEB/sysconfig.txtMake sure you are running the latest version of UD Mobile.
December 6Dec 6 Author 55 minutes ago, DennisC said:Check that you are running udx (v4.2.0).You can check by running https://eisy.local:8443/WEB/sysconfig.txtMake sure you are running the latest version of UD Mobile.Thanks for the link to make it easy - udx is 4.2.0UD Mobile is current version 1.4.7Did system reboot twice - no change / same error
December 10Dec 10 On 12/4/2025 at 4:20 PM, zorax2 said:When I click on this sequence "Configuration" -> "Portals" to show Portal Integration, I get the error message shown in the screenshotTry turning off wifi and connecting only over cell data. That should go away. I tested and had same result while I was on local network. Disconnected from the network and it refreshed just fine.
December 12Dec 12 Author @Geddy Thank you for your suggestion.Tried turning off wifi and I didn't get the error message I posted above. I do get a spinning blue and then an error - (ERROR - The request timed out).I guess since all the devices and programs work properly I'll just not worry about it as it appears there's nothing I can do on the user side to prevent either error for that page.
December 12Dec 12 1 hour ago, zorax2 said:I do get a spinning blue and then an error - (ERROR - The request timed out).Yeah, I see what you're talking about. I get the error too.What is it you're trying to do with that setting option?If things are working then I wouldn't think that's a setting that needs to be adjusted.Since it is an error though you might want to open a ticket with UD so it gets @Javi's attention. It might be a bug, but I'm not sure why that setting is needed as I cannot recall ever wanting/needing to click on that. More than likely it's a remnant of how admin console used to approve the Portal request. It might just be a part of old layout that isn't needed now that eisy-ui is coming along and will handle portal requests differently.https://www.universal-devices.com/my-tickets
December 12Dec 12 Author @DennisCI don't think it is necessarily related to the "Invalid Credential" error. However, all this happened after I recently updated my eisy IOX and everything else.Thank you for your help in finding that post. I appreciate it. Edited December 12Dec 12 by zorax2
