TEXT Notification Fails with “Mail server failure.”
Setup:
Eisy
Cell: Mint Mobile (T-Mobile)
Gmail Account
Help Needed; I’m unable to send TEXT notification via eisy,
What I’ve confirmed:
Eisy email notifications work ######@gmail.com, “when SMTP Settings is Use Default”
Manual email sent from a PC to ##########@tmomail.net works.
What I’ve tried;
SMTP configuration Use Default
SMTP manual configuration tested (Gmail):
Server: smtp.gmail.com
Port: 587 (also tested 465)
Security: TLS checked and unchecked
Username: full Gmail address
Password: Gmail App Password
From address set
TEST Button Result is always an immediate “Mail server failure.
Questions:
Is there anything I’m missing? Has anyone been able to get TEXT notifications to work with a Mint Mobile phone?
Any help would be greatly appreciated
Solved by RRalston
@toddlock Something does seem right from what you have submitted.
You indicated: "Manual email sent from a PC to ##########@tmomail.net works." Doesn't that mean you successfully sent an email which was delivered as a text to your T-Mobile phone?
For you to experience "TEST Button Result is always an immediate “Mail server failure." potentially indicates your router/firewall may be blocking those ports. "Mail Server failure" is different from the carrier blocking the action. I don't think you would get any response like that if you were able to successfully connect to the mail server.
I have xfinity mobile, which is verizon underneath and I send texts to my phone all the time using "<cell.phone.number>@vtext.com
But I also found this in the Wiki related to gmail
Configuring gmail Account
https://wiki.universal-devices.com/ISY994:Configure_Mail_Server_Settings#SMTP_Errors:~:text=Configuring%20gmail%20Account,-%28NOTE
Hope this may help you.
Rob
@RRalston You are correct: if I send from my PC email account to ##########@tmomail.net, it goes to my cell phone. I'll check my router firewall settings and see if I can open a port to make this work. Also, thanks for the mail config info, this is helpful. Todd
An alternative is to use the Notification plugin. You could use the built-in notification in UD Mobile for a limited number of notifications, or move over to the full Notification plugin and Pushover.
Been doing this for a number of years now and have never had a failure.
@RRalston I was able to get it to work, I created and used the Gmail configuration App password in the Wiki link. Thanks for the help!!!
Thanks to this refresher, I finally hooked up my Polisy to send email and cellular text notifications via Gmail.
I do need to report a variance, though. I was following the Wiki entry, but when I go to the 2-step verification part, there was no "App Passwords" at the bottom of the page to choose the ">" from. I think it's because I was creating my first one*. Anyway, I then Google searched for "create a google app password", and one of the links was for Google Help. There, I found a link for "Create and manage your app passwords" which took me directly to a screen where I could enter the app name and get a 16-character password - presumably because I had already logged in to get to the 2-step verification page. Documenting in case it helps someone someday.
*because now it's there!
-Tom
