June 6Jun 6 8 hours ago, EricBarish said:I went with home assistant last week. Connected my ecobee (by homekit) and roombas, garage control and other items in a few mintues. Really like the dash board on Home assistant. Figuring out the programing, AI helped a lot.Using home assistant as an interface to devices missing in Eisy and Eisy for most programs and my smarthome, zwave and zigbee control.Home assistant has an Eisy/ISY integration so I can pass data between the two systems using eisy variables.With dashboard can quicky see what is going on with the systems.Should have done this a while ago with the loss of the ecobee cloud connection and (Homekit ? on eisy) pushed me to make the jump.Doesn't Ecobee work with Home Assistant without Homekit? Speaking of AI, I used it to write my own plugin. It isn't very polished and does not do as much as Jimbo's but it has gotten me by since it went down. I had my own developer key luckily. One thing I could never figure out (AI could not I mean :) ) was how to get the comfort setting names into the ISY. It just calls them SMART1, 2, etc... It also does not show the comfort setting in the program, you have to click the program line to see it. I do plan to go back to Jimbo's eventually. Just a lot of work to update all my programs.
June 6Jun 6 11 minutes ago, btreinders said:Doesn't Ecobee work with Home Assistant without Homekit?Yes. There are several integrations for ecobee. Two are official:1- An intergraiton when you already have your own dev key. It provides access to everything the Ecobee API offers, is cloud based and no Homekit needed. similar experience to Jimbo's Plugin.2- A homekit device integration. You log your ecobee in on the same L2 lan as your HA server (L2 Bonjour based), the integraton sees it and the thermostat offers a pin to authenticate with. It offers some important features yet is also feature hampered by Homekit Accessory Protocol's (HAP) more limited definition of a thermostat. It however is completely local, cloud free and no apple products are required.
June 6Jun 6 Yes, the Homekit method does have missing features which is a bummer, but being all local is nice since there is no polling delay. I was really hoping Ecobee would allow us to use the local method, and the cloud method for features missing with local but no luck. UDI is working with Ecobee on getting API access back but no promises yet, and sounds like the API is different so will require some development.
June 10Jun 10 Trying to setup ecobee plugin from the beta store. I upgraded packages to get the latest software like was suggested. The configuration instructions are overwhelming:Install and configure udi-poly-homekit first (PG3 store): pair your Ecobee(s), then enable the hub MQTT transport (mqtt_enable and broker settings in that plugin; see its PROTOCOL.md). MQTT is the preferred transport for new installs and is the default of hk_transport here — point both plugins at the same broker and matching *_hub_slug. WebSocket (ws_host / ws_port and optional ws_token) remains supported as a fallback when MQTT is not available. This nodeserver’s HomeKit mode talks to that hub only; it does not replace it.Missing backend param: the plugin seeds a default once: homekit for a fresh NS (no OAuth, no api_key, no saved Ecobee tokens/PIN in customdata, no extra nodes yet); cloud if Polyglot OAuth is enabled for this NS, api_key is set, customdata has tokenData / pin_code, or the NS already has nodes besides the controller (legacy upgrade). If backend is already stored in PG3, it is never changed by seeding.Ecobee cloud (REST API): Ecobee has cut off UDI / Polyglot Cloud access for this integration. Cloud mode only remains viable if you use your own Ecobee developer application key that you registered before Ecobee stopped honoring requests for the old shared keys, and you configure api_key / PIN flow as documented for local Polyglot. Do not rely on historical OAuth or UDI-provided keys for new setups.can you give a simplified verbose example of what we should enter, especially in the homekit plugin? I do not have a personal API key for ecobee.Thanks
June 11Jun 11 Have to agree looked at these instructions and scatched my head. Decided to see what home assistant could do. Took a few seconds to connect my ecobees with homekit\home assistant and sent the data to easy needed for my control programs.
June 11Jun 11 All defaults should work, just remember this is beta, I put in a lot of options for testing which should not be necessary once it is proven.
June 19Jun 19 I followed the instructions, and got the Ecobee in my nodes, and it is reporting the nodes and able to change the climate type.The only thing that I noticed is missing is that the previous version had the ability to not just control the climate type (home or away), but it used to allow a command to put the "schedule mode" into "running", which put it into whatever the schedule commanded.I know the homekit version has a lot less functionality......is that one of the commands that was lost?
June 19Jun 19 9 hours ago, alambertus said:I followed the instructions, and got the Ecobee in my nodes, and it is reporting the nodes and able to change the climate type.The only thing that I noticed is missing is that the previous version had the ability to not just control the climate type (home or away), but it used to allow a command to put the "schedule mode" into "running", which put it into whatever the schedule commanded.I know the homekit version has a lot less functionality......is that one of the commands that was lost?Glad it's working for you. Yes that was lost, or I couldn't figure out how to do it.
June 19Jun 19 17 hours ago, alambertus said:I followed the instructions, and got the Ecobee in my nodes, and it is reporting the nodes and able to change the climate type.The only thing that I noticed is missing is that the previous version had the ability to not just control the climate type (home or away), but it used to allow a command to put the "schedule mode" into "running", which put it into whatever the schedule commanded.I know the homekit version has a lot less functionality......is that one of the commands that was lost?Figured it out, it's back now. Update to 4.1.3.
Monday at 05:13 AM4 days got production udi_poly_homekit and ecobee to work! remember to restart admin console after configuring and starting eachOther than ecobee, will the homekit plugin allow me to access any other apple home devices like apple TV or apple home knowing if I am home or away?
Monday at 03:30 PM3 days 10 hours ago, photogeek54 said:got production udi_poly_homekit and ecobee to work! remember to restart admin console after configuring and starting eachNice 10 hours ago, photogeek54 said:Other than ecobee, will the homekit plugin allow me to access any other apple home devices like apple TV or apple home knowing if I am home or away?This is a HomeKit hub, so in theory you could pair those devices with this hub, but then you'd have to unpair it from any other hub. But not something I can play with since I have no Apple devices.
Tuesday at 03:39 AM3 days So I updated my programs to use the new ecobee plugin and there are a few things that look strange. I have added 3 new climate types to my ecobee, "wakeup", "hot day" and "retiring". In ecobee I only see one additional climate type it calls "smart1", not sure which of those it is and 2 missing. In one of my programs it is trying to set climate type to "smart3" but the action below for that row calls it "home". I've attached photos.
Tuesday at 01:34 PM3 days Yes that's one thing missing with Homekit mode. I check again but I think that smart1 was the only extra one available and I neglected to test how that actually worked. I'm not sure how smart3 showed up but will check as well.
Tuesday at 10:32 PM2 days Jim, my Ecobee is set to require a minimum of 2 degrees between the heat and cool setpoints. But the plug-in seems to be enforcing a 3 degree minimum delta between hot and cold. Is this something that can be changed? Thanks:) -Barry
Tuesday at 11:46 PM2 days 19 hours ago, photogeek54 said:So I updated my programs to use the new ecobee plugin and there are a few things that look strange. I have added 3 new climate types to my ecobee, "wakeup", "hot day" and "retiring". In ecobee I only see one additional climate type it calls "smart1", not sure which of those it is and 2 missing. In one of my programs it is trying to set climate type to "smart3" but the action below for that row calls it "home". I've attached photos.This is the best I can figure out, but it's a pain, released in 4.1.10https://github.com/UniversalDevicesInc-PG3/udi-poly-ecobee/blob/master/README.md#homekit-climate-type-no-cloud-apiNot sure if I'm going to use this, I still haven't customized all this in our new home yet but it seems to work. I may just use climate settings in the ISY instead of relying on the ones set in the ecobee app.51 minutes ago, BJB2757 said:Jim, my Ecobee is set to require a minimum of 2 degrees between the heat and cool setpoints. But the plug-in seems to be enforcing a 3 degree minimum delta between hot and cold. Is this something that can be changed? Thanks:) -BarryTry 4.1.10, see the setting in the config page. We can't read the setting from the thermostat in HK mode then set hk_heat_cool_min_delta https://github.com/UniversalDevicesInc-PG3/udi-poly-ecobee/blob/master/CONFIG.md#homekit-thermostat-node-drivers-and-commands
Wednesday at 03:43 PM1 day 15 hours ago, Jimbo.Automates said:This is the best I can figure out, but it's a pain, released in 4.1.10https://github.com/UniversalDevicesInc-PG3/udi-poly-ecobee/blob/master/README.md#homekit-climate-type-no-cloud-apiNot sure if I'm going to use this, I still haven't customized all this in our new home yet but it seems to work. I may just use climate settings in the ISY instead of relying on the ones set in the ecobee app.Try 4.1.10, see the setting in the config page. We can't read the setting from the thermostat in HK mode then set hk_heat_cool_min_delta https://github.com/UniversalDevicesInc-PG3/udi-poly-ecobee/blob/master/CONFIG.md#homekit-thermostat-node-drivers-and-commandsThank you! That worked, I set the min setpoint delta to 2 degrees:) -Barry
