July 5Jul 5 13 minutes ago, Mark said:Current Situation with Ecobee APIEcobee has ceased support for new developer accounts, which directly impacts integrations like Polisy Universal Devices. This means that new users cannot obtain API keys necessary for integration.A few weeks ago Ecobee stopped communicatingMessage in PG3............Ecobee Nodeserver with API, or Homekit backends. (API is currently blocked by Ecobee)Like others was using Ecobee with PG3.........If anyone has a fix or an alternative please post.As discussed in this thread, install HomekitHub plugin and latest Ecobee plugin connect to HomekitHub. https://forum.universal-devices.com/topic/41709-pg3-ecobee-node-server-production-release/#comment-405393 Edited July 5Jul 5 by Jimbo.Automates
July 19Jul 19 I installed this a while ago and it is working great. I'm very happy to have this working again since I had automated my mini splits to run based on my Ecobee thermostat state. Thanks for providing this fix!
August 30Aug 30 Fan state has stopped working (sometimes).I have two Ecobee thermostats, and have ISY tell me when the fan state changes to ON so it will run a then statement in my program based on the time of day.Both work at times, but usually only one is working with the fan state. The other I can see from the ISY Admin Console that it shows the fan state is on, but the program rarely is triggered. I've restarted the three polyglot plugins, and sometimes it starts again, but most of the time it doesn't.Using Ecobee ver 4.1.10 standardMQTT ver 0.50.8 freeHomeKitHub ver 2.0.17 ProfessionalPolisy ISY 6.1.1 (performed the same way on 6.05)Any others experiencing the same issue, and what did you do to correct it?
September 8Sep 8 If AC is showing proper status then it sounds like a programming or notification issue?
September 8Sep 8 No admin console has showed the same temperature all this time, never changes. Hopefully the debug logs I sent will help.
September 8Sep 8 Ok, I was confused because you said "fan state is on, but the program rarely is triggered". What do you mean by "same temperature"? I thought this was about fan state?If AC is not showing proper temperature, fan state or ... The please confirm you have checked the Healthy Hub Checklist
September 8Sep 8 I removed, and reinstalled the plugin again. Repaired the two thermostats this morning, and so far both are reporting correctly when the HVAC fan is on.
