May 29May 29 After over a year working, my Honeywell plugging gives me this error. I have restarted the plugin several times and rebooted the EISY. Is anyone getting this error? Is anyone else's still working? Is anyone still using this?
May 29May 29 If it's WiFi, is there a chance that the thermostat itself has WiFi/networking that locked up or has a problem?Can you reach it with an app if it uses that? (Or ping it or see it in your router)Can you restart it somehow (eg remove from its mount and reseat) to eliminate that as a possible cause?
May 29May 29 Author Yes, I can reach it with the resideo app.But, now that you mention it, I am unsure whether I assigned a static IP address for the thermonstat. I will have to look into this. Edited May 29May 29 by oberkc
June 24Jun 24 I have the same problem. Debug log shows "discovery failed" and "certificate expired". Thermostat works well from Honeywell app, so not likely wifi. Any ideas? Maybe redo client ID and Secret?
