Tuesday at 07:30 PM5 days I have 30+ insteon devices that have worked for several years. I came home a couple nights ago and all switches have flashing lights. Some flash from green to white and some are just flashing red. Everything works and all are still in the console. I have tried restore on the devices with no luck. I have rebooted everything and still flashing lights. Help please
Tuesday at 07:58 PM5 days Have tried to go into the event log, level 3, and if there are Insteon signals being sent? I've had a similar thing happen with what appeared to be a feedback loop, possibly between the eisy and sone lights. The lights controlled by 2 switches turned off for a couple of seconds, then back on. Repeatedly. Rebooting the eisy stopped it.
Tuesday at 08:09 PM5 days Author I pulled up log. All looked good. I have rebooted EIsy several times. No luck.
Tuesday at 08:17 PM5 days I believe it is possible to set Insteon switches to not blink the green/red leds for comm status. As I understand you, for whatever reason, the switches think they are failing when they aren't. Ideally, you would solve the root problem. But if they all work and you can't figure it out, you could just shut off that feature. I believe if you go into options on the device in the admin console, you can't click "no led". Edited Tuesday at 08:17 PM5 days by apostolakisl
Tuesday at 08:31 PM5 days Author I did this also. They all still blink. Every Insteon switch and outlets are blinking.
Tuesday at 09:00 PM5 days Another possibility could be a bad Insteon device transmitting noise or garbage. You might try turning off one breaker at a time and seeing if it stops the blinking.
Wednesday at 01:28 AM5 days @Tv103165 , the flashing you are describing sounds like a device operating in RF Beacon mode (or 4 tap phase detect mode). When activated on a device:1) devices on the opposite phase leg will flash green2) devices on the same phase leg will flash red3) older devices may flash white.Operation is described on pages 6 - 7 here: http://cache.insteon.com/pdf/2992-222-us.pdfI've never seen a device enter this mode by itself. I've used the mode with PLM's and plug in devices (lamplincs dimmers and relays). You typically have to press the set button 4x rather quickly. I just tried it on a Swithlinc and it functions there also (difficult to hit the set button 4x fast).Assuming that one of your devices is confused and entered this mode erroneously, turning off breakers (as suggested by @Guy Lavoie ) may be an easy way to reset. I placed one of my Lamplinc dimmers in Beacon mode and verified that power cycling reset the device.Let us know what you find - I never seen this type of failure before.
Wednesday at 04:35 AM5 days I know we haven't solved the OP's problem yet, but I really love the lengths this community will go to help others out. Kudos @IndyMike-Tom
3 minutes ago3 min Author Just an FYI for anyone if this happens again. All is working again. I had a LED paddle fin garage light that went bad in the garage. It was controlled by an insteon switch. Once I replaced the light all worked again. Thinking back all probably started flashing same time LED light went out. Could be coincident but probably not.
