Request for Back Button in web ui
Request for Back Button when navigating sub menus in web ui ... dont see this as an item on the "To-Do List"
example: if you select a node, right click to configuration .... do you thing in the config menu, but want to navigate back to the specific node to do whatever ... there is no method to navigate back one level ... you can only navigate back to the "all nodes"
Depending on the node type that your working on, this can become a pita ... here's a zwave example
Once you filter for the zwave node (group), select Config ... set a config param, there is no method to return to the original screen ... you can only navigate back to the entire list of nodes
The same naigation holds true for any node type, right click / menu item / new page / there is no method to return to the view of the node you started on
All those who agree, raise their right hand...
Actually a nice alternative for those who have two screens on their computer is to open two eisy-ui sessions, one on each screen. You can then go define that new variable or whatever on one, then immediately go back to what you were working on in the other. This can also be done in the old admin console: run two sessions. Very handy for testing how a variable updates when turning a node on, etc. With admin console, you need to open a second IsY finder and everything.
Looks like navigate back is working, my guess is you want the search retained in session?
2 hours ago, Javi said:
Looks like navigate back is working, my guess is you want the search not retained in session?
Hey Javi ... I'm confused by your reply ...
"Looks like navigate back is working" where is this navigate back function ?
and
"my guess is you want the search not retained in session" = true, but a user still has to navigate "back" to previous screen to see the search results
Guy, I like the 2 screen solution (tested) and is a great option for users with 2 monitors ... but I found it awkward on my single 15" laptop screen
and
Sorry, must have typed an extra word.
Navigate back is standard browser navigation (mouse or back button). Retained search would keep the search as it was on return.
