Friday at 01:05 AM4 days There seems to an upgrade now available for IOX, UDX, and Eisy UI. v6.1.2_10 v5.0.0_7 v1.4.4Has any one upgraded to these yet?
Friday at 01:29 AM4 days Author OK, I think I'll wait for a day or two. I don't have a test device anymore.
Friday at 03:59 PM4 days I did.. I'm like you and normally wait a week or so but rolled the dice this AM! So far all seems okay,No reboot was required, but is it best practices to still reboot the eisy after an upgrade?John Edited Friday at 03:59 PM4 days by johnjces
Friday at 04:12 PM4 days Using the new web UI eisy.local IMO is over-rated at this point. After reading the EISY User Guide there are many features missing which require use of the Admin panel noted below.Features only in Admin ConsoleMany features still require the admin console, such as:Everything related to Insteon, ZWave, Zigbee or MatterScenesCreate or modify programsBackup & restoreUpgrade packagesLogs (Error log, event log, etc)Everything under Configuration (except Portals)OpenADR
Friday at 04:16 PM4 days WOOPS! I didn't reboot and couldn't get into the NODES section of web UI. Nor could I log into my PG3X stuff. SO... a reboot fixed all.Guess I will make a reboot a mandatory part of my upgrades! And wait a week as usual!!!John Edited Friday at 10:00 PM3 days by johnjces
Friday at 04:17 PM4 days 5 minutes ago, apodsim said:Using the new web UI eisy.local IMO is over-rated at this point. After reading the EISY User Guide there are many features missing which require use of the Admin panel noted below.Features only in Admin ConsoleMany features still require the admin console, such as:Everything related to Insteon, ZWave, Zigbee or MatterScenesCreate or modify programsBackup & restoreUpgrade packagesLogs (Error log, event log, etc)Everything under Configuration (except Portals)OpenADRThat is out dated data, please upgrade everything listed is now supported
Friday at 05:42 PM4 days Is there a set of instructions somewhere for how to upgrade and how to get started with the new admin UI? All I've seen is the announcement and hadn't seen any reference to upgrade instructions.Thanks
Friday at 10:04 PM3 days Thanks; I've been using the admin console exclusively for years and got an email that it was being discontinued, so figured now was the time to switch over.I also happened upon this: https://wiki.universal-devices.com/Eisy:User_Guide#eisy-uiBasically you use the admin console to upgrade your eisy's packages (which installs the new UI), then point a web browser at the eisy's URL. Details in this wiki article.
