Yesterday at 01:46 PM1 day Moved wireless sensors to plugins in eisy-ui. The controller shows up but the sensors themself's do not show up under the controller.
1 hour ago1 hr Author Have tried many things to get this plugin to shows it nodes. Reinstalled, hard reboot of eisy and others. have latest Beta updates installed. Nothing worked so far.In reading the read-me for this pluging by JimBoca it stated the following after the tag manger node shows up, "The Tag Manager node created in the ISY has a "Monitor Tags" option, which by default is disabled in case you have multiple ISY's. It should only be enabled on the ISY that is on the same LAN as the Tag Manager. When this option is enabled, the nodeserver updates all the Tag URL's so any updates are pushed to the REST server. "This option is not showing up in the wirelesstag controler options after a new install in eisy-ie. Has anyone been able to get this node server to work with the new Eisy-ei?I can get the wireless tags working in Home-asst and send the data to eisy-ie using variables for the programs needing it but holding off for now.
8 minutes ago8 min This issue was previously reported in this linkPerhaps it's time to tag @Jimbo.Automates
