3.1.3 color change
Looks like you changed the color of the program code to a dark blue, from black. Makes it a lot harder to see on my laptop.
Can you either change it back, or allow a customization?
* Orest
The dark blue font looks & reads OK on my laptop. But your suggestion for color customization may be useful.
Would you please try the 2.8.16 URL
I did that on my laptop. Results were strange and did not re-set the program code font colors.
Under your link, I tried to check the version number but only a blank box with 'OK' button would come up. When I went to the Program Details tab, the program files and folders were all scrambled and not in their proper places. Many programs had the green arrow (indicating they weren't saved) and of the few programs I clicked on, none of the code was present. I closed the console and went to another PC to call up the console.
Under 3.1.3 all appears normal (on both laptop and PC desktop) with the exception of the font color on the program code (dark blue) plus any if condition with time is dark blue on white background.
Both my PC & laptop have Windows Vista (latest SP) and I use Foxfire 4.0.1 browser to access the console.
I can confirm the code text color change. I was able to print screen in both 3.1.3 and your link Michel but I havent been able to upload the images to this post. I did have some of the same problems with the 2.8.16 console as sanders2222 did but not as bad, not sure why.
Running windows 7, and using http://www.universal-devices.com/99i/3.1.3/admin.jnlp - Java application
Tim
