Water temperature...
Does anyone know if there is a way to take an underwater temperature and get a reading on mobilinc or the ISY994i?
I would love to be able to monitor my pond's water temp and possibly use it to set an alarm or program with that info.
How do I do this?
  • 1 month later...
Does ISY have a display or output of the temp somewhere? I don't have any Insteon thermostats since my system is all proprietary rs485 (probably) comm signals.
I know with Elk temp readings ISY can text/email those two you or send them to an Elk Keypad for display. I don't see thermostat reading in the custom notifications section, but that could be because I don't have any thermostats.
If ISY can't send you the temp, I know you can get it to work using cai webcontrol and the ISY.
Those devices were just now released. I don't think the current 3.2.6 firmware supports them.
Michel,
Can you give an estimated ETA on if & when it will be supported? I am really looking forward to use them as a relatively non-expensive temp/humidity sensor in each room and setup programs to report back to my venstar tstats thats actually controlling the HVAC.
Sent from my SPH-D710 using Tapatalk 2
