EricBarish
Everything posted by EricBarish
  1. Had same result yesterday. Rebooted system again and it cleared up and all returned to normal.
  2. Gary, I have been using these to drive loads close to the web controller and to power other a/c relays far away from the controller over low voltage wire. They are cheap and have no problem over the years. Eric
  3. Jeff, What do you mean by everything is blank? Can you see the wirelesstag control node? I had problems finding the wireless nodes. See my solution a few meassages down in this catagory. Once I figured out the strange name for the wireless tag manager and turned on the monitor tags to true. The wireless tags showed up. Working fine since. Eric
  4. Had all my insteon leak sensors lose connection twice in the last month. They can be brought back online by pressing the button on each sensor. Is this a sign of the PLM going bad ? Or something in eisy-ui ?
  5. Gary Its been a while since I used the humidity sensor. Surprised it burned out even if you connected incorrectly. Check to make sure you have 5 volts between V+ and V- on the web board with nothing connected. . Here is link to the data sheet for this device. Spec says something about a 80 ohm load between Data and V-, i think this is allready on the web board, you check with a volt meter with no power to the board and see what you get. Those chips are expensive, I remember getting them for a few dollars. I checked but can npot find the spares i purchased. Eric https://static.datasheets.com/doc/13022347-honeywell-hih-4021-003-ds.pdf
  6. Yes it is reproductible. Here is the section with the error codes, looks like something to do with the plugins. All plugs have been moved from PG3 and are now working, but not deleted in PG3. this error with PG3 disabled on backup try. 2026-10-24 12:02:24 [error] web: Backup failed: Error: socket hang up at AxiosError.from (/var/eisyui/node_modules/axios/dist/node/axios.cjs:874:24) at RedirectableRequest.handleRequestError (/var/eisyui/node_modules/axios/dist/node/axios.cjs:3299:25) at RedirectableRequest.emit (node:events:509:28) at eventHandlers.<computed> (/var/eisyui/node_modules/follow-redirects/index.js:49:24) at ClientRequest.emit (node:events:509:28) at emitErrorEvent (node:_http_client:109:11) at Socket.socketOnEnd (node:_http_client:617:5) at Socket.emit (node:events:521:24) at endReadableNT (node:internal/streams/readable:1735:12) at process.processTicksAndRejections (node:internal/process/task_queues:90:21) at Axios.request (/var/eisyui/node_modules/axios/dist/node/axios.cjs:4339:41) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async eisyBackup (/var/eisyui/dist/server/services/system.js:600:33) at async /var/eisyui/dist/server/routes/api/authenticated/system.js:86:18 2026-10-24 12:02:24 [error] web: Error with API request to GET /api/system/backup/create: socket hang up eisy-logs-2026-10-24T16-04-30.zip
  7. Figured it out, if you disable PG3 in eisy-ui. backup will not work. If enable works.
  8. This just started. Worked fine a couple of days ago. Did try a hard re-start, no effect.
  9. Anyone else getting a 500 error on backup attempt? Version eidy-ui
  10. Well finally fixed the problem and have the nodes for the wirelesstags working First after installing or migrating your plugin, ignore this in the node list Wireless TagController Now go look at the top of your node list for some thing like this ( no idea were this name came from) Node Name Type #5B02630EC28c Wireless Tags Manager If you click on this node you will get the correct panel on the right. In this panel go to monitor tags and set value to true. Nodes will appear under the #5B202630C28 No idea why two different node names show up for the wirelessplug in, the one labeled wireless tagsController does nothing. Found this by pure chance, looking at the top of the node list and wonder what this strange node name was.
  11. Under eisy-ui -->settings --> display you get a choose of light (black letters on white background) or the current white text on back
  12. Have tried many things to get this plugin to shows it nodes. Reinstalled, hard reboot of eisy and others. have latest Beta updates installed. Nothing worked so far. In reading the read-me for this pluging by JimBoca it stated the following after the tag manger node shows up, "The Tag Manager node created in the ISY has a "Monitor Tags" option, which by default is disabled in case you have multiple ISY's. It should only be enabled on the ISY that is on the same LAN as the Tag Manager. When this option is enabled, the nodeserver updates all the Tag URL's so any updates are pushed to the REST server. " This option is not showing up in the wirelesstag controler options after a new install in eisy-ie. Has anyone been able to get this node server to work with the new Eisy-ei? I can get the wireless tags working in Home-asst and send the data to eisy-ie using variables for the programs needing it but holding off for now.
  13. Moved wireless sensors to plugins in eisy-ui. The controller shows up but the sensors themself's do not show up under the controller.
  14. All Nodes/devices are showing up under the plugin in Polygot 3x polygot 3x wireless plugin display eight nodes detected but node values are not updating. easy-ui no nodes showing up eisy-ui node list nothing under wireless tag controller in admin console only see wireless tag controller no devices
  15. Checking mine same, Only see the control page, not the devices. Devices are showing up in my.wirelesstag.net tried stopping and restating pllugin no effect.
  16. This should work from digikey somewhat expensive $28.30 for one plus shipment. IN STOCK HIH-4020 / HIH-4021 Series: Offers identical analog voltage processing but adds environmental protections like integrated covers or condensation I had a lot of problems with the lifetime of the initial HIH-4000 over the years, Probably since I used it outside. Now I just us the value from my weather station (outside and inside readings) for humidity HIH-4021-003 SHT40I-HD1B-R2 There is a surface mount unit SHT401 for $ 2.7 /unit but connection would be challenging
  17. Javi, Have switched over to Eisy-UI completely. One small item. In Light display mode when you try to change a state variable value the section displayed goes from black text on a black background. Thanks for all the work. Eric
  18. Not sure if the latest update fixed this problem. After updating this afternoons Beta update, ring nodes have appeared in the node list. Tried a power reboot this morning to no effect. Thanks ?
  19. Did something wrong. Tried to move the ring plugin from pg3 to the eisy-ui plugins. Ring plugin shows up in the eisy-plugins with its three nodes. Then went through the process in the eisy-ui to remove the plugin from PG3. Now the Ring plugin is not showing up in the node directory. For the other PG3 plugins moved to eisy-plugins but did not remove from PG3 they are working fine. Not sure what is going on ????
  20. Gary, That seems way off, the stated accuracy is +- 0.5 c Or +- 0.9F for the DS1822. I'm using premade temp sensors (Hilitchi 3m/9.8ft Waterproof Temperature Sensors Digital Temp Probe (Pack of 5pcs) from amazon and accuracy is very good. I would check another sensor. I used some old Cat 5 wire for the main run from the Web control (need twisted pair to decrease interference). The sensors coming off a short distance ( length of cable supplied on probe) from the main run. No calibration in Webcontrol, If this delta is real need to us a program in your home control device to correct.
  21. WebControl 8 Network IO Controller Programmable now avaible on amazon
  22. Light mode in eisy -ui is much easier to view. Tahnks
  23. I saw somewhere that AI is going to do all our future programing for the eisy. Just tell it what you want and it does the rest.
  24. Yes, to many drop down boxes in UDX for each step of writing a program. In IOX everthing you need is on the program creation page and you just need to move to it with your mouse to create each part of the program.
  25. Upgrade now working for all items. Something hanged up durring the upgrade. Opened a ticket and after Michel checked a few things just said to reboot. After three reboots all systems now working, IOX, PG3, UDX and connection to home assistant. Somehow even though I thought I setup the system with a fixed IP address it changed it after the update. Once I fgured this out got PG3 and home assistant working. Now that I can update and change programs in UDX will start switching over to using it rather then the admin consule.
