SHM
Everything posted by SHM
  1. SHM replied to Javi's topic in eisy
    I have used ratgdo board with the ratgdo plugin and it gives open/close, light, door status and others. Works very well. I also have the Yolink garage door sensor that gives open/close status as a backup. Yolink products seem better for longer distances.
  2. So I loaded the new plugin version in PG3 (AC side) and configured. Re-started the new version, then rebooted the AC and voila. It works. The beta version shows up as node 5 in the pics. Thanks!!
  3. So install in PG3 (legacy) and test a program in AC?
  4. SHM replied to SHM's topic in IoX Support
    So using the portal to connect to remote easy should still work? I should set easy to accept incoming connections? Is that a security risk?
  5. Thanks. Versions attached
  6. Running 1.8.65 and my Temp, Humidity sensor is showing up normally as a node in easy ui. Opening the node shows all the fields correctly (notably, temp is in fahrenheit). However, when the node is used in programming, to set the value of a state variable to the temp of the sensor, the only temp option is centigrade. Have re-installed, rebooted with no change. Any ideas?
  7. SHM posted a topic in IoX Support
    Will turning on firewall in Mac OS have any impact on IoX/eisy ui?
  8. Almost all (about 12) None are in scenes.
  9. How could I miss that…
  10. All of a sudden, a handful of insteon lights switch on by programming, but then switch off spontaneously in a second. Have checked all programming and nothing has changed. Have tried reboot but problem persists. Any ideas?
  11. Where did the parentheses go in programming in eisy UI. Are they still needed?
  12. I have successful upgraded ZMatter to 7.46 but the attempt to add the free Long Range option resulted in cannot validate license., and the z-wave.me controller ui shows the long range box still greyed out. Also, is there an advantage in adding the "maximal Power" add-on? If so, their PayPal system doesn't seem to work.
  13. re-installing Push plugin solved the problem
  14. Just noticed in eisy ui that when using Push to send a message in a program change (e.g., when thermostat temp >67, set push furnace node message "off"). the push node value for the furnace node is a fixed number and there are no choices for the message values (On, Off, etc). Any ideas? Running eisy ui 1.4.7_1, IoX 6.1.2_13, UDX 5.2.0
  15. I have successfully added the ratgdo 32 disco garage door opener to HomeKit, but only 1 node (light) shows up in eisy . No open/close status or distance (from laser). Any ideas?
  16. I have been using this plugin successfully with 25i boards. Decided to make the leap to eisy ui and plugin still works great. now running eisy ui 1.4.6, IoX 6.1.2_12, UDX 5.1.0_4, mDNS responder 2881.100.56.0.1. I configured the 32 disco using my MacBook (OS 27.0.1) using Chrome. Board added just fine., and shows up on my wireless router. When I opened the web ui in Safari (either ratgdo.local or LAN IP) it opens just fine. When I try to open in Chrome, it says address not reachable. In either browser, when I try to add the 32 disco to the plugin it cannot be discovered, even with a custom parameter for the new board. Interestingly, if I use an older MacBook (OS 12.7.6, using the CH 340 driver), I can reinstall the 32 disco and it now opens in either chrome or safari, but I still cannot add the board to the plugin. It must be some software issue (?mDNS) that prevents communication between the plugin (or chrome) and the board. I am now out of ideas and expertise. Hope Goose66 will pick this up.
  17. For me, these work fine: IFTTT Pushover Weatherbit NOAA Ambient Weather HomeKit Hib Yolink Ratgdo Needs adjustment: Ratgdo Harmony Hub
  18. Have been using your Harmony Hub plugin for some time. I have recently converted to eisy ui, including migration of my plugins. The Harmony plugin shows up on the dashboard and is “connected” but it doesn’t seem to work. In fact, UD mobile sync fails because of a “blank” node in Harmony hub (per javi). Attached is the plugin log. Seems like there is no communication. Any ideas? The plugin version is 3.0.10. HarmonyHub-log-2026-10-17T17-52-09.038Z.zip
  19. SHM posted a topic in Polyglot v3 (PG3x)
    Any instructions for configuring MK's eisy ai plugin?
  20. SHM replied to SHM's topic in UD Mobile
    Did the UDM update to version 4.4.27 today but sync still stalls per ticket 30358
  21. SHM replied to SHM's topic in UD Mobile
    OK
