SHM
Everything posted by SHM
  1. Did a brief survey of nodes and programs. It appears that Yolink door sensor and HomeKit thermostat nodes are not working. Here is a screenshot of the Yolink message. Same for the HomeKit thermostat node.
  2. Thanks. Did the migration. I did not try to migrate Matter but 2 plugins (Push, IFTTT) failed to migrate. Screenshot reason attached.
  3. Quick question. I have the IoX Matter plugin and have been using it for several Matter devices. The plugin has been "beta" for some time and looks like it won't migrate. Will it still work the same on the PG3 side? P.S., Work the same on PG3 side even if all other plugins are migrated?
  4. How do I access the release notes for 6.1.2_3 and plugins beta? Am I to understand that this release will allow eisy access from outside the LAN?
  5. Worked perfectly. Thanks.
  6. Tried to delete HoneywellHome plugin but it is still present on the dashboard as "unmanaged" and no delete option. How can I delete it?
  7. SHM replied to SHM's topic in ratgdo
    FYI For some reason, latest ratgdo firmware (July 2026) for the 25i board disrupts the communication between ratgdo and the plugin (?mDNS issue). I was able to re-flash the ratgdo with the April 2026 firmware and all is restored. Paul Weiland aware of the issue and hopefully can hash it out with @Goose66. For the time being, what a relief!
  8. SHM posted a topic in ratgdo
    Long time user of the plugin with no issues, until today when I upgraded the ratgdo firmware (ESP) to the July 2026 version. After installing, only 2 of 3 garage doors responded to the plugin commands, even though the ratgdo web interface works normally for all doors. I deleted then re-installed the plugin and configured it as before. The plugin cannot discover the ratgdo devices. Attached is log. Any suggestions? Running version 4.08 on PG3X 3.4.19, iox 6.05 ratgdo_7-24-2026_12310_PM.zip
  9. I finally gave up on the Honeywellhome plugin which was controlling my nice ($) T10 thermostat. I searched the plugins and found Jimbo.Automates's HomeKit plugin. As the T10 is HomeKit compatible, I gave it a try. Spent all day yesterday with Jim and he got it working perfectly. So, no need to throw away your Honeywell thermostat.
  10. SHM posted a topic in YoLink
    Does the plug-in support the Yolink Thermostat2?
  11. SHM replied to 4481hoods's topic in Ecobee
    I have installed the HomeKit plugin and I have successfully paired my Honeywell T10 thermostat to it. When I try to set up some programming of the thermostat in the AC, the only options in Homekit/thermostat are pair and repair. Is there any way I can access the thermostat functions?
  12. I have a nice Honeywell T10 thermostat that I have been using with the Honeywell Home plugin. The latter no longer seems to work. So, I am trialing the HomeKit plugin, as the Honeywell thermostat can be integrated with HomeKit. After installing the plugin, I went to the thermostat's HomeKit menu, which just shows a 2D barcode. Then, when I hit "Discover" the thermostat shows up as a node, but is unpaired. The thermostat never displays a pairing code to enter in the plugin's custom parameter. Any suggestions?
  13. I have the same problem. Debug log shows "discovery failed" and "certificate expired". Thermostat works well from Honeywell app, so not likely wifi. Any ideas? Maybe redo client ID and Secret?
  14. Thank you. So my program is similar and is: IF /ambient weather daily/main/daily rain >= 0.45 inches Then Turn sprinklers off My problem is that my sprinklers are turning off before the 0.45 inches is reached.
  15. So it just rained! The weather station recorded daily precipitation of 0.02", which is what appears on the plugin and ISY. My program was activated by this data, but it is written to activate only if daily precipitation is >0.45" Attached are plugin, isy data and plugin log. Any ideas? debug.log install.log
  16. OK. How do I collect the data the plugin sends?
  17. I have been using Ambient Weather for some time to get data from my Rainwise station. Works great. I recently used the daily rain and rain rate in programming to turn off sprinklers. So, if rain is greater than 0.45 inches or 0.25 inches/hr, it shuts things off. For some reason, the program shuts off the sprinklers well before the criteria are met. Is there an issue with fractions of an inch?
  18. SHM posted a topic in Rachio
    Any plugin support for the Rachio smart hose times yet?
  19. SHM replied to SHM's topic in UD Mobile
    OK. Thanks. Your sync is quite a bit faster and mine also sticks on node server and/or Matter. I do not get errors.
  20. SHM replied to SHM's topic in UD Mobile
    1 easy is local, the other is remote. about 30 nodes and programs, few scenes. On iOS 26.4.2. The sync has been slow for some time, but it eventually happens.
  21. SHM posted a topic in UD Mobile
    I have been having the same issue with very slow sync for my 2 controllers, usually requiring multiple cancels and re-sync. Running UDM 1.4.23, Iox 6.05
  22. SHM posted a topic in UD Mobile
    Adding iBeacon support with ability to populate state variables (as in Mobilinc Pro) would be nice. Very useful in programming.
  23. SHM replied to SHM's topic in UD Portal
    The following (not sure which) solved the problem: Under location services/system services toggle on/off significant locations Disable Focus mode
  24. I changed the wiring into the motor such that there was only 1 wire coming out of the lift master 8550 red (control) and white terminals, then those wires split to a Y and the garage wall remote and ratgdo wires insert in to the appropriate sides of the Y. My observation was that doubling the red and white wires from the remote and ratgdo and then inserting them in to the lift master terminal never gave a motionless connection. When the garage door opened, there was enough vibration to momentarily have either of those wires to loose contact, hence the door would stop. Haven't had a problem since.
  25. SHM posted a topic in UD Portal
    I have 2 separate EISY's (running 6.05) at 2 locations. My wife and I both have UD mobile and still have Mobilinc Pro (for ibeacons). I have set up geofences using Occupancy for both of us. Recently, I have noticed that while my geofence reporting and ibeacon responses are good, hers are not (that is, not reporting). I have spent quite a bit of time making sure that the URL's in Occupancy are accurate, the UUID's, etc in beacons are accurate and have made sure her phone (iPhone 17) has the correct settings for location always on, etc. All to no avail. Should she have separate login credentials at UD mobile and at the Portal? Would this make a difference? Right now, her UD mobile app uses my login credentials.
