October 18Oct 18 How about maintaining a list of the plugins that are working fine, vs ones that need adjustments?
October 19Oct 19 For me, these work fine:IFTTTPushoverWeatherbitNOAAAmbient WeatherHomeKit HibYolinkRatgdoNeeds adjustment:RatgdoHarmony Hub
October 19Oct 19 The main one I switched over so far was Virtual and I had to basically touch everything it was involved with to get it working.
October 19Oct 19 22 hours ago, Guy Lavoie said:How about maintaining a list of the plugins that are working fine, vs ones that need adjustments?Envisalink DSC Alarm monitor and controlNotifications (formatting is a bit borked but fixable)MQTT
Tuesday at 06:47 PM4 days To add to the Working list:Audio PlayerKasaPlexPing (new version out works fine)MQTT (Sonoff)Vue (had to recreate scenes or groups the nodes were a part of)WeatherFlow Edited Tuesday at 06:48 PM4 days by TJF1960
Tuesday at 07:10 PM4 days Author I've moved these over without issue:VenstarCTHueSomfyELKI'm running into an issue with one plugin (Virtual) because my installed version is from the beta store. Switching over to the production store isn't working because the version number in the production store is lower than my beta version. Hopefully that gets resolved when the production version at least matches the beta version I have.
Tuesday at 08:54 PM4 days Working for me:HomekithubEnvisalink-DSCWeatherBitNotificationPingVUENOT WORKING (moved back to PG3): Rachio, iAqualink, eISYIR
Wednesday at 07:16 AM3 days @JTsao I had a bit of trouble with iAqualink, but it works now.I had to go into each program and change a little thing, save, then change it back, save. Then those programs worked.Ross
Wednesday at 11:54 AM3 days FWIW, the following appears to be working for me:TwinklyNotificationRingHolidaysYolinkLocalGoveeAmbientWeatherVirtualCasetaHarmony HubHaving said this, when I deleted those "working" migrated plugins from the legacy PG3x system, ALL of my migrated-and-working plugins ceased working. Furthermore, my migrated plugins continue to receive notifications in PG3x (new version available, restart admin console) and do not get these notifications in the new easy-plugin environment. I cannot help but suspect that the eisy-plugin remains dependent on PG3x. Edited Wednesday at 11:55 AM3 days by oberkc
Wednesday at 02:09 PM3 days @JTsao my iAqualink is working fine.. I am on the staging repo.These plugins are working fine.WeatherflowRatgdoHUE (with lots of rework)KasaTimedataHolidaysSun (didnt work initially)NotificationsiAqualinkRussoundELKYoLinkRingWebcontrol832Eisy-AISt-Inventory (had to reinstall in a new slot, migration did not work)
Friday at 04:37 AM1 day IOX-Matter beta 2.0.1-beta.5 when installed shows CONNECTED under EISY Plugins but under nodes shows no connection. When installed it will not show the pairing code. Also seems to lose recognition of being installed and then ask for update. Update and same lack of connection in nodes.Tried deleting and reinstalling the PG3 version but will not allow for install as says my trial has expired.Lost all connection to HomeKit.Any guidance?
9 hours ago9 hr Same issue as @WRamsey IOX-Matter beta 2.1.0 -beta.4 when installed shows CONNECTED under EISY Plugins but under nodes shows no connection. When installed it will not show the pairing code.
6 hours ago6 hr I changed the config parameter to modern instead of auto. the plug in provided pairing info but will not pair. tried rebooting and now per plug in log in its will not connect to matter services with error code 2 under node matter sys offline
6 hours ago6 hr And every time I restart the plug-in the version info reverts to 0.0.0 and the update option to beta.5 becomes available. not sure if the plug-in actually needs updating again or if the version info is buggy
5 hours ago5 hr 1 hour ago, WRamsey said:And every time I restart the plug-in the version info reverts to 0.0.0 and the update option to beta.5 becomes available. not sure if the plug-in actually needs updating again or if the version info is buggySame issue.
4 hours ago4 hr 1 hour ago, WRamsey said:I changed the config parameter to modern instead of auto. the plug in provided pairing info but will not pair. tried rebooting and now per plug in log in its will not connect to matter services with error code 2 under node matter sys offlineSame issue here as well. The new plugin store says the author is Pradeep Mouli. Also the trial expired, and there does not seem to be a way to renew it.Where is the proper place to post issues with specific plugins?
