Everything posted by IndyUDIuser
UDM Favorite needs 3 taps to run program
A late followup... A few weeks later, the icon started working as desired. The little circle appears every time I open Favorites, and I can click the button to turn on the fan. I have no idea what changed, but it is working now.
UDM often seems out of sync with devices/scenes
A follow-up on this issue... Today I opened UDM and it says three of my scenes are turned on, even though none of them are. These seem to be the same scenes I was having trouble with earlier. One of them is called "Galley" and has three wall switches in my kitchen in it. One of those is a dimmer switch called Swag Light. The physical switch is working OK for the lamp. But when I turn the switch on or off, the status is not updating in Admin Console or UDM. If I ask Alexa to turn Swag Light on or off, it works as expected and NOW both AC and ADM show the correct status. If I ask Alexa to turn on/off Galley, the Swag Lamp turns on/off. But the other two devices (Kitchen East and Kitchen West) don't change at all. The switches don't physically turn on/off nor does their status in AC. I have another scene called Kitchen Lights with Kitchen East and Kitchen West in it, and it works as expected when I tell Alexa to turn that scene on or off. The two switched from above are turned on/off, and AC is updated properly. These devices and scenes have been around for years. I don't know why they have become problematic in recent months. What is the normal procedure to correct this kind of situation? Is the Swag Light switch failing (since it is not signalling its status to AC)? Should I just remove it from AC, factory reset the switch, and then add it back in? Should I remove all of the switches and re-add them just to clean up everything? I don't suspect my PLM (even though it is over a decade old) because Alexa commands work OK. Only a couple of wall switches seem to be acting up. Maybe I'm mistaken on that. Once I figure this out then I can maybe fix the other two scenes in my living room that is acting similarly. Thanks.
Old dumb user here, upgrade where? How?
Wait... Tried it in Chrome and got right in. Browser incompatibility?
When I try to use Firefox to browse to http://eisy.local I get a login page where it either rejects my login with an unknown error, or the page disappears in a couple of seconds and displays: Unable to connectFirefox can’t connect to the server at eisy.local:3000 Anybody know why it is doing this? Thanks.
Problem with misbehaving simple vacation program
Thank you so much for the explanation. I was a batch programmer (mostly COBOL and C) for over 40 years, so I'm used to code that always executes as written, statement for statement, linear fashion. I find this IoX language quite different, and challenging. The fact that different parts of a program can be evaluated at different times is tough to wrap my old brain around sometimes. I appreciate your help!
But the variable is zero (I triple checked it), and there is an AND clause between the variable check and the From/To statement, so shouldn't the entire program be FALSE all the time? Why would it still trigger at 10PM?
My wife and I decided to take an overnight trip a few days ago so I created this simple program to make the house look "lived in" that night. I set $sOnVacation (a state variable I had just created) to 1 just before we left, and then set it to zero right after we returned. At 10PM that night the lights turned off unexpectedly. It happened again the next night. Since the variable is 0 (zero), why would it do that? There must be something I'm not understanding. Thanks! Look Lived In - [ID 0051][Parent 004E] If $sOnVacation is 1 And From Sunset To 10:00:00PM (same day) Then Set 'Living room lights' On Else Set 'Living room lights' Off
Dumbing down to Insteon hub at vacation home
I have a 10yo desktop computer that I've used Admin Console on for 10 years - first with an ISY994i and now an Eisy. Several months ago I upgraded it to Windows 11 using a Rufus Installer utility (since Microsoft blocked me from upgrading normally). Now I can no longer install Java, as I get a Windows 1603 error. Oracle says its a known error but evidently they don't care as that was posted years ago. I have tried for hours with no luck... deleting old Java files, removing remnants from the registry, every internet tip I can find. I've pretty much given up. I have a 1yo Windows 11 laptop and Java and Admin Console work fine. So I would recommend against upgrading from Win10 to Win11. YMMV If they get EISY-UI stabilized I may start using that instead of Admin Console. We'll see.
Stop reporting added device that was added weeks ago
Try rebooting the EISY. That seemed to help mine when I was getting those messages. I just pulled the power cord out of the back for 10 seconds and then plugged it back in. Once it rebooted, the "added" messages stopped happening.
Admin Console cannot run; JRE install error 1603
A follow-up to say I've pretty much given up on this error. I have spent hours trying every suggestion I could find online to fix this, but nothing has worked. I believe it is a Windows error, probably not specific to Java, but I'm not sure. One thought I had is this 10yo PC was originally Windows 10 but I upgraded it several months ago to Windows 11 using a free Rufus upgrade tool. I had to do this because Microsoft kept claiming my mobo was not compatible with Windows 11 (missing some useless "security feature" I cannot remember at this time). The Rufus installer got around that and allowed me to do an in-place upgrade to Win11. This allowed me to keep the 10 year's worth of applications installed. The upgrade worked fine, and I'm now booting Win11. This Java install error is the only problem I've seen so far. I have no plans to replace this workhorse PC, so I'll just have to live without Admin Console on it I guess. I'll just use my laptop instead.
System Busy dialog repeatedly after variable updated
@IndyMike and @Guy Lavoie Thank you for the information. Good to know. (I thought about flashing a light but didn't want the neighbors to get suspicious - ha ha).
Actually, I changed the code to send a beep to the switch instead of flashing the backlight. That works, and no "System Busy" messages.
Thank you! I searched for that node address and found out it was one of my kitchen switches. With more research I found the following program was causing the messages to appear. This was an experimental program to blink the switch's backlight to confirm that the OnVacation variable was set, so that I would remember to turn it off when I got back from vacation. It worked as designed. Alas, every time it repeats, it generates the "System busy" message. I guess maybe that is OK and harmless. I'll delete the program anyways just so this doesn't bug me in the future. KITRMT On vacation blinker - [ID 0046][Parent 0064] If $sOnVacation is 1 Then Repeat Every 5 seconds Set 'Kitchen / KTCHN Lights North Dmr' Backlight 0% Wait 1 second Set 'Kitchen / KTCHN Lights North Dmr' Backlight 100% Else Set 'Kitchen / KTCHN Lights North Dmr' Backlight 100% This will blink the backlight on the north wall switch so I can tell that the On Vacation variable is set.
Move to Folder
I must be on a different version of UD Mobile than @MKaye . I'm on 1.6.5 (Android). My Favorites tab displays my favorites as square tiles on a white background. At the bottom of the screen there is two buttons labeled "Paste" and "Cancel" but they are ghost images hidden behind the five icons for Home, Favorites, Notifications, Automations, and Settings. Thus the Paste and Cancel buttons are unusable. Looks like a UI design flaw to me. I don't know what you would use them for. I normally go to the Devices screen, click the 3 dots beside a device or scene, and select "Add to Favorites". That creates a "shortcut" on the Favorites screen. When I don't need the Favorite anymore, I go to the Favorites screen, click the three dots on an item's tile, and select "Remove from Favorites". This deletes the tile from the Favorites but does not delete the original device/scene. I don't see what the "Move to Favorites Folder" does. I don't have a folder called Favorites on the Home tab, nor does it create one. Seems useless to me.
I have a state variable called sOnVacation that is normally set to zero. I have about a dozen programs that check this variable. I set the variable to 1 when I go on vacation, so my EISY doesn't turn on lamps or fans or other devices while I am gone. I set up all these programs a long time ago but didn't try to set the variable to 1 for the fist time until just before a recent trip. When I updated it to 1, the Admin Console kept displaying the small dialog box saying "System Busy - Please do not power off/unplug the system or make adjustments to liked/attached devices". It displays what looks like an address (56 83 05 1) below that. This dialog box pops up about every 5-10 seconds and then goes away. This happened over and over for close to 10 minutes. I thought maybe IoX was updating the status of all the programs, yet this continued on and on. Finally I changed the variable back to 0 and the messages stopped immediately. Any idea what is going on? Here's a sample of one of my programs: CELFAN 7D 21:00-09:00 MBDRM Fan ON - [ID 001C][Parent 002C] If From 9:00:00PM For 12 hours And $sSummerTime is 1 And $sBedroomIsWarm is 1 And $sOnVacation is 0 Then Set 'Master Bedroom / MBR Fan Sw' On Else Set 'Master Bedroom / MBR Fan Sw' Off
I'm a bit rusty...
I had my bathroom remodeled a year ago. The electrician subcontractor removed a ceiling light fixture (that I had on a 2477D dimmer) and replaced it with a basic LED fan/light combo from Lowes. Within a week the fan motor failed (made a humming noise but wouldn't turn on). By the time the sparky came back to replace the fan, I had switched the 2477D for a 2477S switch. New fan has been working fine since. I would not recommend using a dimmer with one of these fans. EDIT: The 2477D was fine. I'm using it on another LED light fixture in the same bathroom.
Cannot login to PG3 thru Admin Console
https://eisy.local/pg3/dashboard This is working for me today. I find the PG3 website/store confusing and not the best designed, but that's just me. I've been adding these tips to a Word document so I can remember what to do the next time I need to look at my one and only plugin in maybe a year or two from now. Ha ha. The "Launch Polyglot V3" in Admin Console takes me to this link. https://192.168.0.76:3000/ Sometimes it works, sometimes it doesn't. I'll try to avoid it from now on and just browse to the PG3 store directly in my browser using eisy.local as you suggested.
Plugin Costs
I was able to get into PG3 web pages today. I spent an hour poking around in the screens and finally (I think) got your plug-in updated so it now tells me I am using the Standard edition instead of the free edition. I am glad this is the only plug-in I use. I find the PG3 Store user interface difficult to use and poorly designed. But that's just me (40 years as a software engineer, 25 years as Insteon/UDI user).
EISY - LOCKS UP
That worked fine. Thank you!
Plugin Costs
Thanks for the advice. I cannot even get into the PG3 application today. Keep getting an "unauthorized" error. What fun.
When I am in Admin Console (current version) and go to Plugins > Launch Polyglot V3 (PG3) I get: I have tried rebooting the EISY from Admin Console, and even restarting EISY by pulling the power cord for 1 minute. Neither helped. I am using Firefox browser from my laptop on the same LAN. How do I resolve this so I can look at my plugins? Thanks in advance. I am using the same login credentials I use to get into Admin Console.
Plugin Costs
I happened to be in the Plugins panel yesterday and saw there was an update available for the "Notifications(1)" plug-in - the only one I use. So I went ahead and purchased it. Now I have four lines in my plugins list for that one plugin. I tried to activate the one I had just purchased, but I'm not sure I know what I'm doing LOL. Anyways, after the update I got a few PG3 SMS notifications on my phone saying they were from the FREE version. @Jimbo.Automates can you help me out to clean this up? Thanks.
EISY - LOCKS UP
Thanks for the tip. I've never used SSH to get into my ISY. Can you give me a quick instruction how? "CPU Usage" would be a nice feature to put in Admin Console or the new UI version of the console (I forget what it's called).
Alexa started turning on the wrong switches
I have a scene called "Bedroom lights" whose members consist of a wall switch and a lamp module, both in my main bedroom. I have Alexa linked to my EISY so I can say "Turn on bedroom lights", and it turns them on. This has worked reliably for years. Then a couple days ago I noticed with I said "Turn on bedroom lights", the Echo would chime but nothing would happen. Minutes later my wife told me the lights in the other two spare bedrooms had come on for no reason. I was able to reproduce the problem. It happened every time I said "Turn on bedroom lights". So I went in to look at my Alexa setup in IoX (which I haven't touched in over a year) and found that there were at least a half-dozen devices in the "spoken words" list that I had no memory of adding -- including the other two spare bedrooms, and a few devices I would never want Alexa to turn on/off. I deleted all the extra nodes from the list (including bedrooms 2 and 3) and now "turn on bedroom lights" is working properly again. My questions are: 1) How did all these extra devices get added to the list of "spokens"? Is there some automatic or hidden process that tries to "discover" more devices to add, even if I don't need them? Did Amazon do this, or Universal Devices? I haven't messed with the Alexa integration with my EISY in a long time, so maybe there's something occurring that I'm not aware of or have forgotten. 2) Why did Alexa start activating the two switches instead of the "bedroom lights" scene that it's supposed to activate? It's almost as if Alexa heard "bedroom lights" and tried to find any device that had "bedroom" in the spoken. Yet the SCENE called "bedroom lights" (an EXACT MATCH) did NOT get turned on. Which is weird. 3) In recent past I was doing some cleanup work in Admin Console and renamed all of my light switches slightly. But I did not change the scene name "Bedroom lights". And I did not think about the spokens. Did that confuse things for Alexa and cause it to turn on the wrong devices? I'm going to have to be careful to check my spokens list occasionally - a forgotten feature. Now my wife can stop asking why the spare bedroom lights keep coming on. P.S. I have Alexa+ disabled on my Amazon account.
EISY - LOCKS UP
I'm curious ... how do you tell if the EISY is in a loop? Is there a way to see how much CPU usage it is consuming (like you would with Windows for instance)? I don't believe I've coded a looping situation (yet), so I'm wondering how I would know if I did. Thanks.
