bgrubb1
Everything posted by bgrubb1
  1. If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system. Instead: Back up your IoX and PG3 Reflash your eisy using our USB reflash stick
  2. your system is WAY down level
  3. let me clarify. I believe it only supports Insteon switches. Not scenes, not Zwave, not zigbee etc
  4. I thought the IOX/Matter plugin only supported Insteon ?
  5. its been 1.5 years since the initial launch on EiSY would be nice to hear its future
  6. updated - no changes noted All devices found, refrigerator shows unknown ...Barry
  7. Just confirming. Dryer power off, start, stop work as expected
  8. @TJF1960 Sent you a PM with log file. Notes included, but all working except refrigerator ...Barry LG_ThinQ_10-13-2026_125831_PM.zip
  9. Interesting I have 2 eISY's on my network Both are at 6.0.5 Both are accessible via ip address to eISY UI Both of them shows the eISY UI tab in the portal One works, the other reports file not found. File not found: eisy-ui-1.0.8-4/index.html Any ideas ?
  10. Been using it since day 1 works great and displays well in UD Mobile
  11. seems to work well on inital install Only changed IP address and system name- all else default Found all equiptment including Solar heat
  12. I gave up and used "Virtual Buttons" Node Server in PG3X
  13. @garybixler there is an alexa skill that works great without UDI. Thats my MO but Venstar plugin for UDI control
  14. I previously had that issue Power cycle EiSY fixed it
  15. i have had the exact same issue in two locations both with unifi In both cases it was caused by slow internet connections run a speed test on the lan leg the isy is on
  16. correct basically the iolinc closes the same contacts as pressing wall button. you have to connect to the pads that the switch closes, not the normal wires that go to opener
  17. works if you solder the contacts to the wall panel to the pads for the push button
  18. @Guy Lavoie thanks for the link. I haved looked at UDI sales a couple of time for spare supplies.
  19. I tried to make this work months ago and never got the alexa spoken to work There is a PG3X node server called "Virtual Button" that accomplished it for me
  20. I Installed a new Echo-11 last week and it asked if I wanted Alexa+ I clicked no and I am on non + running fine
  21. I moved an instance 2 weeks ago from a polisy to a eisy (internal zmatter to different usb zmater) 2 weeks ago and the restore fuction worked - no issues. I did have to do a reboot after installing the usb to get the zmatter as showing active. did you open s usb to confirm the antenna wires are connected ?
  22. any chance you have the antennas swapped ?
  23. try admin / admin
  24. Does anyone know what the expanded Matter support is that is mentioned in the Black Friday sale email ? Is something other than a switch supported now ? Upgrade to eisy r2 and get 13% off, plus 1 FREE year of ISY Portal! Try our web-based eisy UI (no Java), HomeKit integration, expanded Matter support
