Everything posted by BJB2757
Integrated plugins: list of what works ok?
Same issue here as well. The new plugin store says the author is Pradeep Mouli. Also the trial expired, and there does not seem to be a way to renew it. Where is the proper place to post issues with specific plugins?
Same issue.
eisy-ui 1.3.4 - Integrated plugins (Beta)
@Jimbo.Automates When I migrated HomeKit and Ecobee, and then looked at the nodes, the HomeKit Hub nodes all looked normal. But the node for my Ecobee thermostat had an error message, instead of usual readouts & controls. I've not yet had a chance to see what happens if I migrate only one or the other of the two plugins. All of my other plugins migrated successfully. UPDATE: Appears to work well when migrating HomeKit, but leaving Ecobee on PG3 UPDATE #2: Re-migrated both plugins to esiy-ui, and everything is working this time:)
Ecobee not communicating
Thank you! That worked, I set the min setpoint delta to 2 degrees:) -Barry
Jim, my Ecobee is set to require a minimum of 2 degrees between the heat and cool setpoints. But the plug-in seems to be enforcing a 3 degree minimum delta between hot and cold. Is this something that can be changed? Thanks:) -Barry
Got it working, thanks so much!
"The Homekit and Ecobee plugins have been released to beta, but require an update of IoX that is not available yet" This is great! For those of us who are considering being less adventurous, any idea when the new IoX will be availbale?
OnkyoAVR has been hanging
@bpwwer I set the log back to 'info' 10 days ago, and things have been working flawlessly since then. In other words, when I first posted I had an issue that was easy to reproduce, and now I don't have the issue at all. Something else (other than the log setting) that I changed 10-12 days ago must be at play. I did clean up some code that had been hitting the plug-in a few times in quick succession. Possibly my old code was causing a timing issue as you suggested., If I run into the issue in the future, I'll try adding a short 'wait' in between calls. Meanwhile, for now the issue is closed. Thank you again for your help!!
Bob, thank you so much. An unexpected result. An hour after seeing your post, I set the logging level to debug, and restarted the plug-in. Things ran flawlessly for almost 2 days, which was weird because it had not gone that long in recent times. So an hour ago I set the logging level to 'info' and restarted the plug-in. Ten minutes later I once again had the error that I posted above. I guess the good news is that I now have a work-around, i.e. keep the logging level set to 'debug'. Any thoughts? Thanks again for offering to help -Barry
I've used this plugin for a long time, and it's been super-reliable. BUT recently - possibly after a recent Eisy upgrade - the plug-in has been working perfectly only after it is restarted. At some point after it is restarted, it seems to hang. One crisp symptom is that the 'Update' button works flawlessly after the plugin is restarted, but then a short while later (usually less than an hour), when you click on 'Update' you get a "TCP client read response failed" error. My system is on the latest production version of everything, and I've tried deleting the plugin and reinstalling it in a new slot. Something must be corrupting the plugin? Any ideas as to what might be causing this? I love this plugin, in part because it's the only plugin that lets you directly set a specific listening mode (e.g. Dolby Atmos).
Alexa routines not working - Fix made
That worked, thanks for fixing it! My Alexa routines triggered by the 'motion detector' are now working once again:)
Default email service on my Polisy suddenly stopped working early thos morning
Harmony Elite Button Press to ISY
It would be great if there was a 'virtual device' that you could add to the Harmony, and include it in every activity. You could then program any available buttons on the Harmony remote, to trigger a function on the virtual device. The virtual device could be connected to a node server, and you could have ISY programs watch the corresponding nodes for button presses & and then do anything you wanted. I have zero idea how to create such a virtual device & get Harmony to allow us to add it to a Harmony activity. But other than that, the right person could probably implement this pretty easily I'm guessing? Or maybe such a virtual device for the Harmony already exists??? Or is this essentially what the Hue Emulator node server already does? I will try it.
KPL with Fanlinc, all fan buttons go on
OK thanks, good to know I’m not missing anything. Some other people have said that functionality is not consistent with all the different nodes that are now possible. But still it would be nice if at least you could copy scene attributes for Insteon, so we’d at least have the same functionality as before. Sent from my iPhone using Tapatalk
Does "copy scene attributes" exist in 5.3? I don't see it.
Need Beta Testers for Smart Home API v2
I'm an "auto" diehard. My ISY sets the thermostats to 70 heat/74 cool when we're home, sets back to 66 heat/78 cool when we're not home, and 64 heat/80 cool (vacation mode) when we've been out for more than 20 hours. "Home" is based on my cell phone being within the geo fence, or any of the motion sensors being triggered within the prior hour (I don't rely on the geo fence for my teenagers). Also have some other functions, e.g. there is an "on the way home" mode that gets triggered when I leave my office (plus any time I'm driving in the direction of the house) so that it's nice and warm (or nice and cool in the summer) by the time I arrive, and stuff like that. It's rare that I override the automatic settings by pressing the buttons on the front of the thermostat, or by asking Alexa. It's hard to say which I enjoy more: configuring this stuff, or benefiting from the completely hands-off automatic nature of it:) -Barry
That's good, that's good. Maybe one refinement for the third case: when the current temp is smack in the middle of the two old setpoints (which could definitely happen if the temp readings are discrete, e.g. heat is set at 70.0, current temp is 72.0, cool is set at 74.0), then check and see which of the NEW setpoints it is closer to. -Barry
Is Logitech Harmony Hub compatible with ISY?
Thanks a lot. Although that's a bit of a heavy lift given my knowledge level... -Barry
The Yonomi folks are very responsive, just like UDI:) They responded and confirmed that the Harmony API does not provide a direct way to do volume up/down, mute/unmute, or channel changing. Yonomi said they've discussed this with the Harmony people, and "believe they are working to add support for it". Now we just need Harmony to return UDI's emails, so we can cut out the lag-y IFTTT middle man! -Barry
Sub-Account
Hi Alex, yep, for each of them to respond by turning on the respective lights in that room, you indeed need 3 separate amazon accounts. And also yes, if you want Prime music in each room, you'd need all three amazon accounts to be Prime (at least that's how Amazon has things working right now). As you point out, the Echoes do come pre-linked to the Amazon account that ordered them. After the Echos arrive, you have to un-link them from your main account, log into new Amazon accounts that you create specially for this purpose, and then link the Echo to those additional accounts. On the ISY Portal, you create a sub-account for each Amazon account. Instructions here: http://wiki.universal-devices.com/index.php?title=ISY_Portal_Amazon_Echo_Integration#Instructions_for_using_Multiple_Echos_Smart_Home My two cents: it's ridiculous that Amazon requires this - my guess is they simply did not anticipate this situation of having Echoes in multiple parts of a house needing to have different "contexts". It's early days:) I bet that at some point they'll give us a way to have multiple contexts all within a SINGLE Amazon account. Another thought: You do have the option of leaving all three Echoes in one amazon account, and have different spokens set up for each room, e.g. "Turn on Den", "Turn on Bedroom", "Turn on Kitchen". But because all spokens will work in all rooms (and for me this is a pretty big "but") if Alexa mis-hears you as it occasionally does, or if someone is intentionally goofing around, you will end up turning stuff on/off in other parts of the house and not know it. e.g. you could be in the kitchen late at night, and you accidentally turn on the light in the bedroom where someone is sleeping. Whereas with separate accounts, you can set things up so that each room does not know about the other room's spokens.. -Barry
Yes exactly - my harmony hub does indeed use IR to control the volume of my AV Receiver. What I'm looking for is a non-IR way for the ISY to communicate with the Harmony (and then the harmony would use IR to control the volume). Then Alexa could control the ISY. I use Alexa --> Yonomi skill --> Harmony to do simpler thinks (like simply turning off the TV) because Yonomi executes much faster than IFTTT. But, like IFTTT, Yonomi also does not have a volume-changing activity. The lack of a direct interface between ISY and Harmony is one thing. But given that neither IFTTT nor Yonomi enable you to change the volume, maybe the Harmony API doesn't expose a volume-changing function??? I'm going to ask the Yonomi guys - they are very responsive.
List of Spokens
Woah, nice that works. Thank you so much! -Barry
A few months have passed...it is now pretty easy to have the ISY send a post to an IFTTT Maker recipe which can then turn on/off any Harmony activity. For example when I say "Alexa turn off everything" the ISY runs a tiny program that turns off the lights, ceiling fan, and (by sending a post to IFTTT) it also tell Harmony to turn off the AV system. But, if anyone can point me to the simplest way to tell Harmony to increase/decrease volume (without transmitting IR through the air), please let me know! Thanks. -Barry
List of Spokens
Hi Michael, Has this URL changed? Should it work from any browser? I tried it with my UUID, was prompted for credentials, but then Chrome said "server error". Also tried embedding credentials, i.e. https://myusername:mypassword@my.isy.io/api/voice/spoken/nodes?uuid=myuuid, with the same "server error" result. Am I doing something wrong? Thanks in advance for any suggestions. -Barry
ISY portal with Moblinc and http while within home wifi
Agree with MWareman - it would be perfect if MobiLinc would allow a distinct username and password for local access…it already allows a distinct IP address for local access! -Barry Sent from my iPhone using Tapatalk
