Still not running on 443.
Can you add libunwind and openssl111 to your UDI repo?
What's the best way to add something to startup - I see a lot of UDI warnings in the rc files?
5 minutes ago, Michel Kohanim said:
@Toddimus,
Ok, let's try this:
1. killall and stop
2. mongo polyglot --eval "db.dropDatabase()"
3. reboot
Thank you!
[admin@polisy ~]$ sudo killall daemon
Password:
[admin@polisy ~]$ sudo service polyglot stop
polyglot not running? (check /var/polyglot/polyglot_daemon.pid).
[admin@polisy ~]$ mongo polyglot --eval "db.dropDatabase()"
MongoDB shell version v3.4.23
connecting to: mongodb://127.0.0.1:27017/polyglot
MongoDB server version: 3.4.23
{ "dropped" : "polyglot", "ok" : 1 }
[admin@polisy ~]$ sudo reboot
login as: admin
Keyboard-interactive authentication prompts from server:
| Password for admin@polisy:
End of keyboard-interactive prompts from server
Last login: Wed Oct 30 15:00:09 2019 from 10.10.10.70
FreeBSD 12.0-RELEASE-p10 r351358 POLISY
Welcome to Polisy!
[admin@polisy ~]$ ps -aux | grep poly
polyglot 1066   0.0  0.1  10768  2188  -  Ss   15:04   0:00.00 daemon: /usr/local/bin/polyglot-v2-freebsd-x64[1198] (daemon)
polyglot 1198   0.0  0.7 571920 29356  -  R    15:04   0:00.08 /usr/local/bin/polyglot-v2-freebsd-x64 -w /var/polyglot
admin    1200   0.0  0.1  11248  2696  0  S+   15:04   0:00.01 grep poly
admin    1204   0.0  0.1  11248  2696  0  S+   15:05   0:00.00 grep poly
polyglot 1205  59.9  2.9 689432 119284  -  R    15:05   0:03.68 /usr/local/bin/polyglot-v2-freebsd-x64 -w /var/polyglot
polyglot 1066   0.0  0.1  10768   2188  -  Ss   15:04   0:00.00 daemon: /usr/local/bin/polyglot-v2-freebsd-x64[1205] (daemon)
admin    1207   0.0  0.1  11248   2696  0  S+   15:05   0:00.01 grep poly
[admin@polisy ~]$
@Toddimus
What do you get for:
pkg info polyglot?
[admin@polisy ~]$ pkg info polyglot
polyglot-2.2.5_4
Version        : 2.2.5_4
Installed on   : Wed Oct 30 11:12:00 2019 PDT
Origin         : misc/polyglot
Architecture   : FreeBSD:12:amd64
Prefix         : /usr/local
Categories     : misc
Licenses       : MIT
Maintainer     : andrey@xkinghome.net
WWW            : https://github.com/UniversalDevicesInc/polyglot-v2
Comment        : Polyglot v2 for UDI ISY 5.x.x
Annotations    :
        FreeBSD_version: 1200086
        repo_type      : binary
        repository     : udi
Flat size      : 88.8MiB
Description    :
Polyglot v2 server for Universal Devices ISY994 version 5.x.x
WWW: https://github.com/UniversalDevicesInc/polyglot-v2
[admin@polisy ~]$
I'm seeing similar issues to others.  My Polisy had a noticeable rattle so I opened it up and the wifi card wasn't attached to the main board.  Reseated it, and went through some of the update steps described in prior postings.  I can still SSH into the box, but the web UI isn't accessible.
Glad to see Nodelink running on this.  I hope that's a supported option going forward as i could then totally repurpose the Pi I've been using to previously run Nodelink and Polyglot.
1 hour ago, Michel Kohanim said:
Hello everyone,
Sincere apologies for the radio silence. The crashing issue is definitely related to multiple instances of Polyglot running. We are working on a fix.
@Bumbershoot, in the meantime, please do this:
sudo killall daemon
sudo service polyglot start
Please let me know what you get.
@Toddimus,
Please the same as above BUT do not do sudo polyglot start. Please let me know what ps shows.
Here's what I get, but it looks the same as before:
polyglot 3518   0.0  0.1  10768  2336  -  Ss   15:45     0:00.01 daemon: /usr/local/bin/polyglot-v2-freebsd-x64[3535] (daemon)
polyglot 3535   0.0  1.0 585004 42768  -  R    15:46     0:00.43 /usr/local/bin/polyglot-v2-freebsd-x64 -w /var/polyglot
admin    3537   0.0  0.1  11248  2696  0  S+   15:46     0:00.01 grep poly
[admin@polisy ~]$
@Toddimus & @Bumbershoot,
Can you please do us a huge favor?
1. Put NODE_ENV=development in the /var/polyglot/.env file
2. Reboot and wait for 5 minutes
3. Send /var/polyglot/log/debug.log  to support@universal-devices.com or post
@io_guy,
Let me check with the team. Just need to make sure we have enough resources for everything.
I only did update/upgrade so polyglot is latest
[admin@polisy /var/polyglot/log]$ pkg info polyglot
polyglot-2.2.5_4
Version        : 2.2.5_4
Installed on   : Wed Oct 30 15:39:27 2019 PDT
and now it's stuck in a continual restart...
2019-10-30 15:47:11 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:11 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:11 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:11 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:11 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:17 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:17 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:17 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:17 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:17 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:22 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:22 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:22 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:22 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:22 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:28 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:28 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:28 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:28 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:28 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:33 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:33 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:33 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:33 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:33 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:39 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:39 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:39 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:39 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:39 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:44 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:44 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:44 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:44 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:44 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:50 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:50 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:50 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:50 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:50 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:47:55 [polyglot] info: Starting Polyglot....
2019-10-30 15:47:55 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:47:55 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:47:55 [polyglot] info: Running in Polisy mode
2019-10-30 15:47:55 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:48:01 [polyglot] info: Starting Polyglot....
2019-10-30 15:48:01 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:48:01 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:48:01 [polyglot] info: Running in Polisy mode
2019-10-30 15:48:01 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 15:48:06 [polyglot] info: Starting Polyglot....
2019-10-30 15:48:06 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 15:48:06 [polyglot] info: Settings: Retrieved config from database
2019-10-30 15:48:06 [polyglot] info: Running in Polisy mode
2019-10-30 15:48:06 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
Received my Polisy today
Another one here with the same issues.
Nothing listening on port 3000
Tried updates and have the same issues as others.
@io_guy,
Letting it run for a few more minutes...  I'll have your log shortly.
@Bumbershoot, THANK YOU!
Email coming shortly, but this is the jist of it:
2019-10-30 16:10:11 [polyglot] debug: Created PID file: /var/polyglot/polyglot.pid
2019-10-30 16:10:14 [polyglot] info: Starting Polyglot....
2019-10-30 16:10:14 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 16:10:14 [polyglot] info: Settings: Retrieved config from database
2019-10-30 16:10:14 [polyglot] info: Running in Polisy mode
2019-10-30 16:10:14 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 16:10:14 [polyglot] debug: TLS: Found Keys and Certificate data in database. Exporting to /var/polyglot/ssl/
2019-10-30 16:10:14 [polyglot] debug: Checking for DB Maintenence needs...
2019-10-30 16:10:14 [polyglot] debug: DB Version Found: 2 no maintenence necessary.
2019-10-30 16:10:14 [polyglot] info: Aedes MQTT Broker Service: Started on port 1883
2019-10-30 16:10:15 [polyglot] info: MQTT Client Service: Started
2019-10-30 16:10:15 [polyglot] error: uncaughtException: listen EACCES 0.0.0.0:443
Error: listen EACCES 0.0.0.0:443
    at Object._errnoException (util.js:1031:13)
    at _exceptionWithHostPort (util.js:1052:20)
    at Server.setupListenHandle [as _listen2] (net.js:1350:19)
    at listenInCluster (net.js:1408:12)
    at doListen (net.js:1523:7)
    at _combinedTickCallback (internal/process/next_tick.js:141:11)
    at process._tickCallback (internal/process/next_tick.js:180:9)
2019-10-30 16:10:15 [polyglot] error: uncaughtException REPORT THIS!: Error: listen EACCES 0.0.0.0:443
2019-10-30 16:10:15 [polyglot] info: Caught SIGTERM/SIGINT Shutting down.
2019-10-30 16:10:15 [polyglot] debug: All NodeServers stopped.
15 minutes ago, Michel Kohanim said:
@Bumbershoot, THANK YOU THANK YOU. Working on it right now.
I just got back from an errand.  I'm assuming @Bumbershoot got you the info you need?  Also, I looked and didn't see a .env file in the /var/polyglot folder.  I tried vi .env but it was blank.  Is that how I would do it?
I didn't have any polyglot nodes installed so I have a pretty blank slate.
Yep, I didn't have the file either.
sudo touch .env
I used vi as well to enter the content.  Scary...  It's been 20 years since I've used vi, and I swore I'd never use it again. Emacs forever! ?
polyglot 2.2.5_5
I might be getting ahead of things here, but this might help.
2019-10-30 16:46:59 [polyglot] info: MQTTS: Client Connected:
2019-10-30 16:46:59 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/connections/# QoS 0
2019-10-30 16:47:00 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/# QoS 0
2019-10-30 16:47:00 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/settings QoS 0
2019-10-30 16:47:00 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/nodeservers QoS 0
2019-10-30 16:47:00 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/log QoS 0
2019-10-30 16:47:00 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/ns/# QoS 0
2019-10-30 16:47:00 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/profile/# QoS 0
2019-10-30 16:47:00 [polyglot] debug: ISY: 404 - http://192.168.1.10:80/rest/config/
2019-10-30 16:47:00 [polyglot] error: ISY: Could not get Version. Check your settings. If this is the first time you are starting Polyglot, this is normal.
2019-10-30 16:47:45 [polyglot] error: MQTTS: polyglot_frontend-cDOoa authentication failed. Someone is messing with something....
2019-10-30 16:47:45 [polyglot] info: MQTTS: Client Connected:
2019-10-30 16:47:45 [polyglot] info: MQTTP: Frontend Websockets interface Connected.
2019-10-30 16:48:22 [polyglot] info: Settings Saved Successfully.
2019-10-30 16:48:22 [polyglot] debug: ISY: 200 - http://192.168.1.20:80/rest/config/
2019-10-30 16:48:22 [polyglot] info: ISY: Got Version 5.0.16
2019-10-30 16:48:22 [polyglot] debug: ISY: 200 - http://192.168.1.20:80/rest/profiles/ns/0/connection/
2019-10-30 16:48:22 [polyglot] info: NS: Registered new unmanaged NodeServer: Ring(1)
2019-10-30 16:48:22 [polyglot] info: NS: Registered new unmanaged NodeServer: isylink(2)
2019-10-30 16:48:22 [polyglot] info: NS: Registered new unmanaged NodeServer: Push(3)
2019-10-30 16:48:22 [polyglot] info: NS: Registered new unmanaged NodeServer: LiFX(4)
2019-10-30 16:48:22 [polyglot] info: NS: Registered new unmanaged NodeServer: Camera(5)
2019-10-30 16:48:23 [polyglot] info: NS: Registered new unmanaged NodeServer: WirelessTag(6)
2019-10-30 16:48:23 [polyglot] info: NS: Registered new unmanaged NodeServer: ISY Portal(7)
2019-10-30 16:48:23 [polyglot] info: NS: Registered new unmanaged NodeServer: Sonos(8)
2019-10-30 16:48:23 [polyglot] info: NS: Registered new unmanaged NodeServer: DarkSky(9)
2019-10-30 16:48:32 [polyglot] debug: {"node":"polyglot_frontend-cDOoa","restartPolyglot":{}}
2019-10-30 16:48:32 [polyglot] info: Caught SIGTERM/SIGINT Shutting down.
2019-10-30 16:48:32 [polyglot] debug: All NodeServers stopped.
2019-10-30 16:48:32 [polyglot] info: MQTT Client Services Stopping Gracefully.
2019-10-30 16:48:32 [polyglot] info: HTTP Interface Service: Stopping
2019-10-30 16:48:32 [polyglot] info: Aedes MQTT Broker Service: Stopping
2019-10-30 16:48:32 [polyglot] error: unhandledRejection REPORT THIS!: MongoError: pool destroyed
    at Pool.write (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/connection/pool.js:860:12)
    at _command (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/wireprotocol/command.js:107:10)
    at command (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/wireprotocol/command.js:25:5)
    at Object.query (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/wireprotocol/query.js:57:3)
    at Server.query (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/topologies/server.js:640:16)
    at FindOperation.execute (/snapshot/polyglot-v2/node_modules/mongodb/lib/operations/find.js:24:12)
    at topology.selectServer (/snapshot/polyglot-v2/node_modules/mongodb/lib/operations/execute_operation.js:167:15)
    at Server.selectServer (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/topologies/server.js:828:3)
    at Server.selectServer (/snapshot/polyglot-v2/node_modules/mongodb/lib/topologies/topology_base.js:363:32)
    at executeWithServerSelection (/snapshot/polyglot-v2/node_modules/mongodb/lib/operations/execute_operation.js:150:12)
    at executeOperation (/snapshot/polyglot-v2/node_modules/mongodb/lib/operations/execute_operation.js:81:16)
    at Cursor._initializeCursor (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/cursor.js:545:7)
    at Cursor._initializeCursor (/snapshot/polyglot-v2/node_modules/mongodb/lib/cursor.js:191:11)
    at nextFunction (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/cursor.js:748:10)
    at Cursor._next (/snapshot/polyglot-v2/node_modules/mongodb/lib/core/cursor.js:202:5)
    at fetchDocs (/snapshot/polyglot-v2/node_modules/mongodb/lib/operations/to_array.js:27:14)
2019-10-30 16:48:32 [polyglot] debug: MongoDB: Disconnected from database.
2019-10-30 16:48:34 [polyglot] debug: Created PID file: /var/polyglot/polyglot.pid
2019-10-30 16:48:37 [polyglot] info: Starting Polyglot....
2019-10-30 16:48:37 [polyglot] info: Settings: Polyglot Version 2.2.5
2019-10-30 16:48:37 [polyglot] info: Settings: Retrieved config from database
2019-10-30 16:48:37 [polyglot] info: Running in Polisy mode
2019-10-30 16:48:37 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
2019-10-30 16:48:37 [polyglot] debug: TLS: Found Keys and Certificate data in database. Exporting to /var/polyglot/ssl/
2019-10-30 16:48:37 [polyglot] debug: Checking for DB Maintenence needs...
2019-10-30 16:48:37 [polyglot] debug: DB Version Found: 2 no maintenence necessary.
2019-10-30 16:48:37 [polyglot] info: Aedes MQTT Broker Service: Started on port 1883
2019-10-30 16:48:38 [polyglot] info: MQTT Client Service: Started
2019-10-30 16:48:38 [polyglot] info: HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 443
2019-10-30 16:48:38 [polyglot] debug: NodeServer Ring [1] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer isylink [2] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer Push [3] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer LiFX [4] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer Camera [5] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer WirelessTag [6] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer ISY Portal [7] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer Sonos [8] added to running config.
2019-10-30 16:48:38 [polyglot] debug: NodeServer DarkSky [9] added to running config.
2019-10-30 16:48:38 [polyglot] debug: MongoDB: 9 NodeServer(s) retrieved from database
2019-10-30 16:48:38 [polyglot] info: MQTTS: polyglot authenticated successfully.
2019-10-30 16:48:38 [polyglot] info: MQTTS: Client Connected:
2019-10-30 16:48:38 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/connections/# QoS 0
2019-10-30 16:48:38 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/# QoS 0
2019-10-30 16:48:38 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/settings QoS 0
2019-10-30 16:48:38 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/nodeservers QoS 0
2019-10-30 16:48:38 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/log QoS 0
2019-10-30 16:48:38 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/ns/# QoS 0
2019-10-30 16:48:38 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/profile/# QoS 0
2019-10-30 16:48:38 [polyglot] debug: ISY: 200 - http://192.168.1.20:80/rest/config/
2019-10-30 16:48:39 [polyglot] info: ISY: Got Version 5.0.16
2019-10-30 16:48:39 [polyglot] debug: ISY: 200 - http://192.168.1.20:80/rest/profiles/ns/0/connection/
2019-10-30 16:48:43 [polyglot] debug: REST: SET_HSBKD Command received from ISY for n004_d073d5213fe8
2019-10-30 16:48:43 [polyglot] info: Received SET_HSBKD for n004_d073d5213fe8 however NodeServer LiFX is not connected. Ignoring.
2019-10-30 16:48:46 [polyglot] debug: REST: ACTIONS Command received from ISY for n003_humidifier
2019-10-30 16:48:46 [polyglot] info: Received ACTIONS for n003_humidifier however NodeServer Push is not connected. Ignoring.
2019-10-30 16:49:00 [polyglot] info: Successful login by admin
2019-10-30 16:49:00 [polyglot] error: MQTTS: polyglot_frontend-cDOoa authentication failed. Someone is messing with something....
2019-10-30 16:49:00 [polyglot] info: MQTTS: Client Connected:
2019-10-30 16:49:00 [polyglot] info: MQTTP: Frontend Websockets interface Disconnected.
2019-10-30 16:49:00 [polyglot] info: MQTTP: Frontend Websockets interface Connected.
2019-10-30 16:49:00 [polyglot] error: MQTTS: clientError: polyglot_frontend-cDOoa write after end
2019-10-30 16:49:00 [polyglot] info: MQTTS: Client Disconnected:
2019-10-30 16:49:01 [polyglot] error: MQTTS: polyglot_frontend-cDOoa authentication failed. Someone is messing with something....
2019-10-30 16:49:01 [polyglot] info: MQTTS: Client Connected:
2019-10-30 16:49:01 [polyglot] info: MQTTP: Frontend Websockets interface Connected.
2019-10-30 16:49:16 [polyglot] info: MQTTS: Client Disconnected:
2019-10-30 16:49:16 [polyglot] info: MQTTS: polyglot_frontend-rGDEs authenticated successfully.
2019-10-30 16:49:16 [polyglot] info: MQTTS: Client Connected:
2019-10-30 16:49:17 [polyglot] info: MQTTP: Frontend Websockets interface Connected.
All my nodeservers are reporting as "Unmanaged".  Slots 3, 4, 6 ,8 and 9 should be running on Polisy (see screenshot).
THANK YOU ALL (especially the log from @Bumbershoot), @xKing fixed it … please do:
sudo pkg update && sudo pkg upgrade
sudo service polyglot restart
The port is 443 but can be set in the Settings.
It works!!  I didn't have the database issue that @Bumbershoot had because I didn't have any nodes on the new Polisy.  I successfully added the Darksky node on the new Polisy and it showed up in the ISY.
Questions on migration from a Raspberry Pi based Polyglot install:
  1. Is the version 2.2.4 that's available using the "beta" tag in Polyglot settings stable enough to use for its Backup feature to be used in migration? (I'm currently on v2.2.3 on the RPi)
  2. Would you recommend waiting a bit to fully migrate all my nodeservers over to the new Polisy, or just go for it?
Thanks for all of your work on this everyone!  Very cool stuff!
Same as Toddimus here.
I have installed v2.4.4 in my RPi Polyglot. Seems OK but only the ecobee NS.
OK....all seems to be working and I have restored my backup from my RPi PolyGlot.
How do I disable the original Polyglot for starting on bootup to avid NS conflicts? I still need a few other ISY service programs running on the original RPI so I need to only disable Polyglot on that RPi.
Thanks in advance!!
