upgrade issue
I imagine you know this already.... but just in case.
The UI notifies that and update is available.  When applying the update,  it fails with the following error:
Platform not recognized - freebsd
You can get around this with:
sudo pkg update && sudo pkg upgrade
After that - you can install Polys as well...   :)
Had the same issue.  I ssh'd in and did the upgrade and it went fine.  But now polyglot is not running on it.  I can ssh into the polisy, but I don't know how to reinstall or whatever needs to happen.  I tried the same commands I used to download polyglot on my raspberry pi but it says the commands are not recognized.
Yeah - it’s FreeBSD based - not Debian. It uses pkg for package management instead of apt.
Chances are it is running but on a changed port. Did you try https and the IP address (no port)?
bingo.  On port 443.
OK, looks like it is working.  I restored backup from my rpi and it appears to be working.  I am running the husqvarna automower, blue iris, and harmony node servers.  Is there any reason to put it back on port 3000 or should I just leave it?
EDIT:
Also, odd thing, when I plugged in polisy and logged in for the first time, the dashboard claimed the up time was 3 weeks and something.
Edited by apostolakisl
EDIT:
Apparently the port change doesn't work from the PG Console.
Hi
I did an upgrade to 2.2.5. All is fine except I have a new error for WEMO. On the previous release it basically started up and sat idle. Now it comes up and keeps trying to reconnect.
2019-10-31 00:00:36,527 [Controller] [INFO ] Updating All Drivers to ISY for Wemo Node Server(wemons) 2019-10-31 00:00:36,534 [Controller] [INFO ] Updating All Drivers to ISY for Wemo Node Server(wemons) 2019-10-31 14:16:20,932 [MainThread] [INFO ] Received Config from STDIN. 2019-10-31 14:16:20,936 [MainThread] [INFO ] UDI Polyglot v2 Interface 2.0.31 Starting... 2019-10-31 14:16:20,937 [MainThread] [INFO ] Wemo node server running on Python version sys.version_info(major=3, minor=7, micro=5, releaselevel='final', serial=0) 2019-10-31 14:16:22,496 [MainThread] [DEBUG] Getting Poly 2019-10-31 14:16:22,511 [MainThread] [DEBUG] Starting Poly 2019-10-31 14:16:22,514 [Interface ] [INFO ] Connecting to MQTT... localhost:1883 2019-10-31 14:16:22,515 [MainThread] [DEBUG] Getting Control 2019-10-31 14:16:22,519 [MainThread] [INFO ] Wemo Controler Initialized 2019-10-31 14:16:22,521 [MainThread] [DEBUG] Starting Control 2019-10-31 14:16:22,866 [Interface ] [INFO ] MQTT Connected with result code 0 (Success) 2019-10-31 14:16:22,868 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/ns/5 - MID: 1 Result: 0 2019-10-31 14:16:22,869 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2019-10-31 14:16:22,870 [Interface ] [INFO ] Sent Connected message to Polyglot 2019-10-31 14:16:25,594 [NodeServer] [INFO ] Starting Wemo Node Server 2019-10-31 15:21:35,956 [Interface ] [INFO ] MQTT Unexpected disconnection. Trying reconnect. 2019-10-31 15:21:35,961 [Interface ] [ERROR] MQTT Connection error: An exception of type ConnectionRefusedError occured. Arguments: (61, 'Connection refused') 2019-10-31 15:21:43,074 [Interface ] [INFO ] MQTT Connected with result code 0 (Success) 2019-10-31 15:21:43,076 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/ns/5 - MID: 5 Result: 0 2019-10-31 15:21:43,077 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 6 Result: 0 2019-10-31 15:21:43,078 [Interface ] [INFO ] Sent Connected message to Polyglot 2019-10-31 15:21:44,888 [MainThread] [INFO ] Received Config from STDIN. 2019-10-31 15:21:44,891 [MainThread] [INFO ] UDI Polyglot v2 Interface 2.0.31 Starting... 2019-10-31 15:21:44,892 [MainThread] [INFO ] Wemo node server running on Python version sys.version_info(major=3, minor=7, micro=5, releaselevel='final', serial=0) 2019-10-31 15:21:46,263 [MainThread] [DEBUG] Getting Poly 2019-10-31 15:21:46,278 [MainThread] [DEBUG] Starting Poly 2019-10-31 15:21:46,280 [Interface ] [INFO ] Connecting to MQTT... localhost:1883 2019-10-31 15:21:46,281 [MainThread] [DEBUG] Getting Control 2019-10-31 15:21:46,285 [MainThread] [INFO ] Wemo Controler Initialized 2019-10-31 15:21:46,286 [MainThread] [DEBUG] Starting Control 2019-10-31 15:21:46,462 [Interface ] [INFO ] MQTT Connected with result code 0 (Success) 2019-10-31 15:21:46,464 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/ns/5 - MID: 1 Result: 0 2019-10-31 15:21:46,465 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2019-10-31 15:21:46,466 [Interface ] [INFO ] Sent Connected message to Polyglot 2019-10-31 15:21:46,484 [Interface ] [INFO ] MQTT Unexpected disconnection. Trying reconnect. 2019-10-31 15:21:48,125 [Interface ] [INFO ] MQTT Connected with result code 0 (Success) 2019-10-31 15:21:48,127 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/ns/5 - MID: 8 Result: 0 2019-10-31 15:21:48,127 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 9 Result: 0 2019-10-31 15:21:48,128 [Interface ] [INFO ] Sent Connected message to Polyglot 2019-10-31 15:21:48,210 [Interface ] [INFO ] MQTT Unexpected disconnection. Trying reconnect. 2019-10-31 15:21:50,034 [Interface ] [INFO ] MQTT Connected with result code 0 (Success) 2019-10-31 15:21:50,035 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/ns/5 - MID: 4 Result: 0 2019-10-31 15:21:50,036 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 5 Result: 0 2019-10-31 15:21:50,037 [Interface ] [INFO ] Sent Connected message to Polyglot 2019-10-3
Update. I deleted WEMO and uninstalled. Did A reinstall and it looks better but with just one error.
2019-10-31 15:45:55,897 [MainThread] [INFO ] Received Config from STDIN. 2019-10-31 15:45:55,898 [MainThread] [INFO ] UDI Polyglot v2 Interface 2.0.31 Starting... 2019-10-31 15:45:55,899 [MainThread] [INFO ] Wemo node server running on Python version sys.version_info(major=3, minor=7, micro=5, releaselevel='final', serial=0) 2019-10-31 15:45:56,788 [MainThread] [DEBUG] Getting Poly 2019-10-31 15:45:56,799 [MainThread] [DEBUG] Starting Poly 2019-10-31 15:45:56,801 [Interface ] [INFO ] Connecting to MQTT... localhost:1883 2019-10-31 15:45:56,802 [MainThread] [DEBUG] Getting Control 2019-10-31 15:45:56,805 [MainThread] [INFO ] Wemo Controler Initialized 2019-10-31 15:45:56,806 [MainThread] [DEBUG] Starting Control 2019-10-31 15:45:56,831 [Interface ] [INFO ] MQTT Connected with result code 0 (Success) 2019-10-31 15:45:56,833 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/ns/5 - MID: 1 Result: 0 2019-10-31 15:45:56,833 [Interface ] [INFO ] MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2019-10-31 15:45:56,834 [Interface ] [INFO ] Sent Connected message to Polyglot 2019-10-31 15:45:56,948 [Interface ] [INFO ] Adding node Wemo Node Server(wemons) 2019-10-31 15:45:56,949 [Interface ] [INFO ] Waiting on Controller node to be added....... 2019-10-31 15:45:56,950 [NodeServer] [INFO ] Starting Wemo Node Server
Thanks Gary
Edited by garybixler
I'm no expert, but I'm just going to leave Polyglot on 443.  Less to remember, and since this is a dedicated device, I likely won't have a bunch of services scattered around on a bunch of different ports.  NodeLink is the only other service that comes to mind, and that can run on port 80 as far as I'm concerned.
I received my Polisy on Monday and have been buried on-call for my job but I'm surfacing now and anxious to get started.
Given all that I haven't had time to read on the forum I feel like I'm been out a month but this post was helpful finding the port 443 after upgrade.
Now when I attempt to login, it tells me the password is wrong. I don't think I've changed it from the original. Is there a way to "factory reset" the Polyglot password via SSH to get me?
Edited by DaveStLou
I have found that using the port extension on the URL won't connect me. I just use https://192.168.0.xxx and I am in.
The Polyglot password change doesn't work in v2.2.5,  Still using admin/admin
SSH login is admin/admin.
caps lock?  Of course you would see that in the username part, but anyway.
Interesting that the user/pass change function isn't working.  Others have commented that changing the port doesn't work either.  I haven't tried to change either of them.  The settings page on the UI seems to be having issues.  It does at least hold the ISY user/password.  Though I did not set it, I uploaded that from my raspi version.
I tried those suggestions too. I even copied the Username just to be sure I wasn't mistyping.
Not sure how it changed. Disappointing that I can't work on it now after waiting to get to it all week.
Can you still SSH into polisy using admin/admin?  Assuming you can, you should be able to remove whatever file contains all the configurations and start over.
Yes I can get in via SSH. Can anyone tell me what file to delete or change to start over and reset the credentials for polyglot? I have no nodeservers installed so I have nothing to lose. Just need directions
And mine showed 4 days and some hours.
