January 23, 20206 yr I just looked at the Polisy Configuration page and noticed that while I have the correct timezone listed, all of the network configuration items are missing. (See screen shot) All of my nodeservers are operating properly and a check for updates returns the message, "No updates available" This is not a big issue for me as my system is operating properly. I just wanted to get this experience reported. polyglot_2020-1-23_121905.txt Edited January 24, 20206 yr by gviliunas
January 24, 20206 yr @gviliunas, And why would you want that? Please do another update. You need udx 1.0.26_15. With kind regards, Michel
January 24, 20206 yr 12 hours ago, Michel Kohanim said: @gviliunas, And why would you want that? Please do another update. You need udx 1.0.26_15. With kind regards, Michel @Michel Kohanim, How do you tell what udx version you are on? Is the version number shown anywhere? Also, how do we know when there is an udx update available? Edited January 24, 20206 yr by DennisC Added question.
January 24, 20206 yr 1 hour ago, DennisC said: How do you tell what udx version you are on? Is the version number shown anywhere? If you know how to ssh into your Polish, you can get this information from the command line: pkg info udx [admin@polisy ~]$ pkg info udx udx-1.0.26_15 Name : udx Version : 1.0.26_15 Installed on : Thu Jan 23 10:44:12 2020 PST Origin : misc/udx Architecture : FreeBSD:12:amd64 Prefix : /usr/local Categories : misc Licenses : BSD Maintainer : michel@universal-devices.com WWW : https://www.universal-devices.com/ Comment : Polisy Admin Service Shared Libs required: libmongoc-1.0.so.1 libbson-1.0.so.1 libmosquitto.so.1 Annotations : FreeBSD_version: 1201000 repo_type : binary repository : udi Flat size : 2.24MiB Description : UDX HW/Admin Service for Universal Devices Polisy WWW: https://www.universal-devices.com/ [admin@polisy ~]$
January 24, 20206 yr Author @Michel Kohanim I tried asking for updates from both the web UI and from ssh (pkg update, etc) and no updates were available. Then I tried stopping the udx service and uninstalling / reinstalling udx. As it turns out, I already had udx-1.0.26_15 installed. I started the service and now I have the network settings back. Something must have gone wrong with the UI called update that I did a few days ago. In any event, all good now. Thanks for your help. Here is the ssh session Welcome to Polisy! [admin@polisy ~]$ sudo pkg update && sudo pkg upgrade Password: Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting)Your packages are up to date. [admin@polisy ~]$ sudo service udx stop Stopping udx. Waiting for PIDS: 1034. [admin@polisy ~]$ sudo pkg delete udx Checking integrity... done (0 conflicting) Deinstallation has been requested for the following 1 packages (of 0 packages in the universe): Installed packages to be REMOVED: udx-1.0.26_15 Number of packages to be removed: 1 The operation will free 2 MiB. Proceed with deinstalling packages? [y/N]: y [1/1] Deinstalling udx-1.0.26_15... [1/1] Deleting files for udx-1.0.26_15: 100% [admin@polisy ~]$ sudo pkg install udx Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking integrity... done (0 conflicting) The following 1 package(s) will be affected (of 0 checked): New packages to be INSTALLED: udx: 1.0.26_15 [udi] Number of packages to be installed: 1 The process will require 2 MiB more space. Proceed with this action? [y/N]: y [1/1] Installing udx-1.0.26_15... [1/1] Extracting udx-1.0.26_15: 100% [admin@polisy ~]$ sudo service udx start Starting udx. [admin@polisy ~]$
January 24, 20206 yr 32 minutes ago, gviliunas said: @Michel Kohanim I tried asking for updates from both the web UI and from ssh (pkg update, etc) and no updates were available. Then I tried stopping the udx service and uninstalling / reinstalling udx. As it turns out, I already had udx-1.0.26_15 installed. I started the service and now I have the network settings back. Something must have gone wrong with the UI called update that I did a few days ago. In any event, all good now. Thanks for your help. Here is the ssh session Welcome to Polisy! [admin@polisy ~]$ sudo pkg update && sudo pkg upgrade Password: Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting)Your packages are up to date. [admin@polisy ~]$ sudo service udx stop Stopping udx. Waiting for PIDS: 1034. [admin@polisy ~]$ sudo pkg delete udx Checking integrity... done (0 conflicting) Deinstallation has been requested for the following 1 packages (of 0 packages in the universe): Installed packages to be REMOVED: udx-1.0.26_15 Number of packages to be removed: 1 The operation will free 2 MiB. Proceed with deinstalling packages? [y/N]: y [1/1] Deinstalling udx-1.0.26_15... [1/1] Deleting files for udx-1.0.26_15: 100% [admin@polisy ~]$ sudo pkg install udx Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking integrity... done (0 conflicting) The following 1 package(s) will be affected (of 0 checked): New packages to be INSTALLED: udx: 1.0.26_15 [udi] Number of packages to be installed: 1 The process will require 2 MiB more space. Proceed with this action? [y/N]: y [1/1] Installing udx-1.0.26_15... [1/1] Extracting udx-1.0.26_15: 100% [admin@polisy ~]$ sudo service udx start Starting udx. [admin@polisy ~]$ Had a similar issue but didn't require uninstalling and reinstalling, just a `sudo service udx restart`
January 24, 20206 yr Author @cswelinThat is strange. I didn't try the udx restart but I did reboot polisy by power cycling before trying an uninstall / reinstall of udx. I would have thought that the power-cycle would have done a udx restart.
January 24, 20206 yr 7 hours ago, Bumbershoot said: If you know how to ssh into your Polish, you can get this information from the command line: pkg info udx [admin@polisy ~]$ pkg info udx udx-1.0.26_15 Name : udx Version : 1.0.26_15 Installed on : Thu Jan 23 10:44:12 2020 PST Origin : misc/udx Architecture : FreeBSD:12:amd64 Prefix : /usr/local Categories : misc Licenses : BSD Maintainer : michel@universal-devices.com WWW : https://www.universal-devices.com/ Comment : Polisy Admin Service Shared Libs required: libmongoc-1.0.so.1 libbson-1.0.so.1 libmosquitto.so.1 Annotations : FreeBSD_version: 1201000 repo_type : binary repository : udi Flat size : 2.24MiB Description : UDX HW/Admin Service for Universal Devices Polisy WWW: https://www.universal-devices.com/ [admin@polisy ~]$ Thanks for the information. I tried updating Polisy this morning. Within Polisy, I had 45 updates, all of which failed. When I ssh in, there were 8 updates, which I did. Eventually, we will need a reliable way of knowing that updates, especially to udx, are available.
