Hi,
I use and enjoy my ISY devices every day.
Get this message when trying to update/upgrade Polisy from ssh/command line - see below
Last login: Tue Nov  3 02:00:53 2020 from 192.168.1.66 FreeBSD 12.1-RELEASE-p1 r355229 POLISY
Welcome to Polisy!
[admin@polisy ~]$ sudo pkg update
Password:
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
Fetching meta.conf: 100%    163 B   0.2kB/s    00:01
Fetching packagesite.txz: 100%   98 KiB  99.9kB/s    00:01
Processing entries:   0%
Newer FreeBSD version for package p5-Locale-libintl:
To ignore this error set IGNORE_OSVERSION=yes
- package: 1202000
- running kernel: 1201000
Ignore the mismatch and continue? [y/N]:
Suggestions?
15 minutes ago, whywork said:
Hi,
Welcome to Polisy!
Password:
- package: 1202000
Suggestions?
I read somewhere on this forum that the Polisy will update itself upon boot.  I ran across this same issue recently (possibly with the same package, I don't recall) so I tested this by rebooting my Polisy.  The issue went away.  My guess is that it's probably fine to choose "y", but I stayed within the UDI web interface (by rebooting from the menu).
EDIT: I just checked, it was the same package.
Edited by Bumbershoot
1 hour ago, whywork said:
Hi,
Welcome to Polisy!
Password:
- package: 1202000
Suggestions?
There are no updates for polisy at this time
Hello everyone,
You should be able to use sudo pkg upgrade to upgrade all packages to 12.2 version. Also, as @xKing would suggest: Rule of thumb - don’t argue with pkg ! In short, when you are asked to ignore, choose N.
Hi @Michel KohanimThanks for looking into this. I tried sudo pkg upgrade. It did not appear to upgrade anything but I do not get the version mis-match error.
Should the freebsd version be:  12.1-RELEASE-p10 ?
[admin@polisy ~]$ sudo pkg upgrade
udi repository is up to date.
All repositories are up to date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[admin@polisy ~]$
[admin@polisy ~]$
[admin@polisy ~]$ freebsd-version
12.1-RELEASE-p10
@Michel Kohanim
The UI upgrade check does not complain but suspiciously, after I click to check for upgrade, I never get the green-banner message that "No upgrades were available.
I only get the green banner "Sent upgrade check to Polisy..." After a few seconds, this message clears.
On 11/4/2020 at 11:38 AM, gviliunas said:
@Michel Kohanim
Ah ha...I rebooted Polisy and now get the proper "No updates available ...: message.
Everything working great!  Thanks for your help
I reported this issue a week ago to Michel.  I have done testing since.  If I check for updates now it works but every morning when I get up I dont get the green bar.  But if I reboot polisy then I get the green NO UPDATES AVAILABLE bar.   Try again later in the day or at night its fine, but the next morning same thing.  No bar.
This started after the last Polisy updates I ran about 1-2 weeks ago.
Maybe I declared victory too early.... I am actually seeing the same behavior as @macjeff. After a Polyglot restart, you get the green "No updates available..."  bar  BUT, one day later, the bar no longer appears. Past history has been for updates to be released at least every week. I plan to wait a few weeks and see if any updates are received and successfully installed.
@Michel Kohanim, You mentioned optionally upgrading to freebsd 12.2. I started down that path using freebsd-update but received a warning that I would be overwriting the "polisy" kernel with a generic version. I stopped when I saw the warning. Do you have a procedure to safely perform FreeBSD upgrades?
Edited by gviliunas
Same problem as @gviliunas but also would add that the 'Settings Polisy Configuration' never loads. However all works fine after a Polisy power reset.  Reboot from the menu doesn't seem to work either.
Thanks Gary
Something still funny.
sudo pkg upgrade yesterday. After a cold boot today:  - version mismatch remains
Last login: Thu Nov  5 05:17:39 2020 from 192.168.1.66
Welcome to Polisy!
Password:
Fetching packagesite.txz: 100%   97 KiB  99.5kB/s    00:01
- package: 1202000
pkg: repository udi contains packages for wrong OS version: FreeBSD:12:amd64
Processing entries: 100%
Unable to update repository udi
Error updating repositories!
[admin@polisy ~]$
Thanks for your help @Michel KohanimThe upgrade was successful. 5 packages were upgraded successfully.
Installed packages to be UPGRADED:
        boost-libs: 1.72.0_2 -> 1.72.0_3 [udi]
        git: 2.28.0 -> 2.29.2 [udi]
        icu: 67.1,1 -> 68.1,1 [udi]
        node: 15.0.1 -> 15.0.1_1 [udi]
        sqlite3: 3.33.0,1 -> 3.33.0_1,1 [udi]
Number of packages to be upgraded: 5
After a reboot, Polisy is running version 2.2.9-5 normally.
Checking for updates does result in the "No updates available green banner..."
@Michel Kohanim
[admin@polisy ~]$ uname -a
FreeBSD polisy 12.1-RELEASE-p10 FreeBSD 12.1-RELEASE-p10 r365882 POLISY  amd64
[admin@polisy ~]$
Hmmm Did this upgrade to 12.2?
Here is the full upgrade output:
[admin@polisy ~]$ curl -s https://pkg.isy.io/script/update121.sh | sudo bash
Installing FreeBSD-base updates
udi repository update completed. 356 packages processed.
Checking for upgrades (5 candidates): 100%
Processing candidates (5 candidates): 100%
The following 5 package(s) will be affected (of 0 checked):
The operation will free 11 MiB.
36 MiB to be downloaded.
[1/5] Fetching sqlite3-3.33.0_1,1.txz: 100%    1 MiB   1.5MB/s    00:01
[2/5] Fetching node-15.0.1_1.txz: 100%    7 MiB   7.4MB/s    00:01
[3/5] Fetching icu-68.1,1.txz: 100%   10 MiB  10.8MB/s    00:01
[4/5] Fetching git-2.29.2.txz: 100%    5 MiB   5.2MB/s    00:01
[5/5] Fetching boost-libs-1.72.0_3.txz: 100%   12 MiB  13.1MB/s    00:01
[1/5] Upgrading sqlite3 from 3.33.0,1 to 3.33.0_1,1...
[1/5] Extracting sqlite3-3.33.0_1,1: 100%
[2/5] Upgrading icu from 67.1,1 to 68.1,1...
[2/5] Extracting icu-68.1,1: 100%
[3/5] Upgrading node from 15.0.1 to 15.0.1_1...
[3/5] Extracting node-15.0.1_1: 100%
[4/5] Upgrading git from 2.28.0 to 2.29.2...
===> Creating groups.
Using existing group 'git_daemon'.
===> Creating users
Using existing user 'git_daemon'.
[4/5] Extracting git-2.29.2: 100%
[5/5] Upgrading boost-libs from 1.72.0_2 to 1.72.0_3...
[5/5] Extracting boost-libs-1.72.0_3: 100%
pkg: No packages available to install matching 'FreeBSD-*' have been found in the repositories
lookig for .pkgnew files...
Preserving files that are unique to Polisy
lookig for any left over .pkgnew files...
Upgrade complete, please reboot using: sudo shutdown -r now
[admin@polisy ~]$ sudo shutdown -r now
Edited by gviliunas
Include full upgrade script results
@Michel Kohanim Command was successful but nothing was upgraded:
[admin@polisy /usr/local/etc/pkg/repos]$ sudo pkg upgrade
Password:
[admin@polisy /usr/local/etc/pkg/repos]$ uname -a
IS it possible that the FreeBSD url in update121.sh is incorrect?  If I go to "https://pkg.isy.io/FreeBSD-base/\${ABI}/latest" I get a 404.
I am guessing that the url needs to have    ".../FreeBSD:12:amd64/"   in the path
Edited by gviliunas
Question FreeBSD url validity
  • 3 weeks later...
any update on this.  Now been a month and if I reboot polisy I can check for updates and get no response.  I used to get a banner that says Success- No Updates Available or maybe 1-5 minor updates available.   I even did an UPDATE polisy and no response there either.  I used to get a response there too.
Once I reboot it works and I can try again later and it works but the next day every time it wont work.   And I have confirmed I am not the only one seeing this problem.
So the workaround is just to reboot polisy.
I can confirm NodeServer updates are working as they should.
      38.2k
      381.2k
