Hi there,
I want to upgrade to 2.7.7 from 2.7.6, but can't find the link for the download. I don't want to try 2.7.8 yet, as I have a large setup.
Can anyone point me to the 2.7.7 download link?
Cheers!
Hi there,
Cheers!
Never mind, I figured it out javascript:emoticon(':D')
Cheers!
It actually just started working! Not sure what the issue was before.
Still going to wait to upgrade to 2.7.8 until a fix is available.
Hello sk8er02,
Apologies for the inconvenience. Thanks to hart2hart, the system crash has been reproduced and we are now working on a fix.
As far as the network module, please ensure that your Network Module is still installed (Help | About). If not, please send your uuid to tech@universal-devices.com so that we can resolve this issue immediately.
When you refer to a "Larger installation" of greater than 75 nodes in the Known Bugs, is this only in order to do the update or does the 2.7.8 not support greater than 75 nodes?
In other words, I am planning to add another 18 devices to an already-upgraded, functional 2.7.8 firmware system. This will bring me close (perhaps over) to the 75 nodes. Will I have issues with the updated firmware? Should I downdrade to 2.7.7 prior to adding all new devices?
Also, just to clarify what is meant by a node...is a KPL a single node device with multiple groups, or would 1 8-button KPL be counted as 8 nodes?
This clarification in how the nodes are counted may make this a non-issue for me.
Thanks in advance...
Hi there,
Cheers!
Cheers!
Whoops. I don't think the link that I found has the latest 2.7.7 build. Can anyone direct me properly?
Cheers!
mbrett,
Would you be kind enough to test the following account settings:
server: smtp.gmail.com
port:587
userid: isyalerts@gmail.com
password: holamola
From: this is an optional field; you can leave it blank
TLS: checked
gfridland,
I would wait for 2.7.9 just to be on the safe side. All reported bugs (except EZSnSRF issue) have already been fixed so we should have 2.7.9 out by the weekend.
Good question considering that I'm running 2.7.8 with 137+ devices and it works fine. What is the definition of a node and how is it calculated?
Joe
Michel,
Thanks for the update on 2.7.9...I will look forward to this release.
Can you please clarify the definition of a node?
For example, one 8 button KPL is 1 node or 8 nodes? Same with a motion sensor...1 node or 3 nodes (motion, dusk/dawn, low battery)
Thanks again!
Joe
Nodes are generally how many scenes a device can control. A responder only device is also a node.
Nodes:
A SwitchLinc is 1 node
LampLinc, 1 node
6-button KPL = 5 nodes
An 8-button KPL is 8 nodes
MotionSensor, 3 nodes
IOLinc 2 nodes
etc.
An ISY scene is a node
A scene with another controller is a node, but is already counted from the controller.
Not Nodes (for example):
iLinc
InterfaceGo
IES touchscreen
Rand
So basically, if I count all the "lines" in My Lighting, this would be my total nodes...Right?
If this is correct, then I currently have 71 nodes.
I am planning to add 36 more nodes.
Therefore, I should wait for the 2.7.9?
Joe
Nodes:
LampLinc, 1 node
IOLinc 2 nodes
etc.
iLinc
InterfaceGo
IES touchscreen
Rand
Rand:
So according to my calculations I have 223 nodes being run by an ISY 99 Pro IR with 2.7.8 and everything is working perfectly...Go figure.
Joe
Joe (Brignolo)...
Just a question, did you successfully upgrade from 2.7.7 to 2.7.8?
I presume that if you have 137+ devices, and some devices have multiple nodes, you have more than 137 nodes and, apparently, had no problems on the upgrade.
Joe (Brignolo)...
gfridland:
Yes, I ugraded from 2.7.7 to 2.7.8 without any issues. I have 223 nodes.
Joe
OK, it has been awhile since I upgraded my ISY (on ver 2.7.6) but I want to eliminate the clock reset issue previously documented in other threads. However, my pea sized brain cannot recall where to find the downloads for the new firmware. Where might I find the 2.7.7 firmware links on this site?
thanks for the assistance. :D
To get "invited" to load the alpha versions you have to get on UDI's email list.
Just installed 2.7.9 and it fixed the EZSnSRF issues. Everything works again. Thank you. Great job. Only small issue is that when you add a group of thermostats to a scene, the setpoints displayed are incorrect. This does not effect anything, because I control the thermostats individually, but the scene aggregation is not quite right. Silly issue and not a big deal.
      37.8k
      377.3k
