Support thread: IoX 5.5.5 Release
Question.  Chris noted above "Please upgrade packages again, PG3X & PG3 should be working again."
Are both packages required on Polisy or is PG3X only required for eisy?  I'm still having issues, Polisy reports PG3 is up to data but PG3X is not installed.
Cheers,
Ken.
Cheers,
Ken.
Where are you finding a post from Chris? The last post I can find from Chris in this thread is from Sunday.
Both are versions for Polyglot. PG3 runs on Polisy and PG3x is for eisy.
This morning I tried to upgrade and my eISY has been indicating in IoX that it is upgrading for hours - how do I stop this and re-run the update?
If this is simply a library problem that needs to be removed, I'm not sure why it's not released yet?
That just tells me there is more to the problem than a simple library needing removal. No Post Update Either. Remembering why I wanted to automate my property becomes more and more relevant as I walk my property to turn on and off locations that were automated, twice daily for the last week after swapping out all the Insteon Devices to end up completely unfunctional.
I'm hiding how happy I am...
TRI0N
If you are still in this state, I think I would use the mtifunction button to reboot. The wiki has the instructions.
I have the exact same problem.  Did you fix it, and if so how?
I did get it fixed - I tried a few different things, but I believe this was the key:
SSH in and try:
sudo service udx restart
I tried updating my Polisy from 5.5.4 to 5.5.5 via the Admin Console. I heard a bunch of beeps (not sure if 4, since the device is in a different room) shortly after. Now I can no longer access the AC, the ISY Portal shows it as not connected and PG does not seem to be running. I can still SSH in and also PG2 is up and running.
I tried power cycling it a few times and tried what had helped me in the past:
sudo pkg install -r udi pkg
sudo /usr/local/etc/udx.d/static/udxops.sh upgrade.polisy
as well as:
But no luck thus far.
I usually launch the AC uncached/directly, but now I am getting this error:
The IoX Finder cannot find the device either.
Any thoughts on how to get this fixed?
update broke me as well  SSH still works  ticket in
I am suspecting there is a bad package or something out there...
Its kinda bummer since everything in my house is somewhat down at this point and has been for a day.  I have to remember where the light switches are again ;)
Hopefully it is an easy fix.
Wishful thinking to check for a new update after hearing about some users are using a "minor release" isy-5.5.5_2 while I have isy-5.5.5_1, so I did the Update Packages in the UDAC. Oh Boy!
Now I'm getting this:
I did the update 2 hours ago...
PG3x is reporting:
No IoX was automatically discovered on your local network. Please configure it in the IoX menu to proceed.
Oh Boy!
TRI0N
If you're on a Polisy and know how to ssh into the box, then this worked for me yesterday:
There's an upstream package associated with MongoDB that breaks things, and that has caused this problem for UDI and Polisy/eisy users.
You might start reading at this post for more information:
I don't know what's going on here, but if you start reading at the post linked to below, you might see what has been happening:
The solution in my case was to issue the following command at the command line:
shbatm's change to the conf file fixed it!
It actually came back online virtually instantly, but I went ahead and rebooted the Polisy anyway once it compelted.
I assume I should just change it back now and not run the update again until this all gets sorted out?
any Linux guru out there no the command to downgrade Mongo without editing the script ?
Could you please elaborate how to do this?
(I am still dead in the water with my ISY)
Mongo is the problem. With all the Polisys, eisy, PG3, PG3x. I would wait for UD to release a fix. It could make things worse, could make things better. I did some carful backup routines and other stuff before looking at Mongo. Such as making sure I had the latest isy-5.5.5_2 pkg when I had isy-5.5.5_1 installed. That itself caused my eisy to freeze for hours until I issued a reboot and then looked at Mongo.
TRI0N
Edited by TRI0N
DO AT YOUR OWN RISK
Downgrade -f
sudo pkg upgrade -f mongo-c-driver
After I did several safety measure such as an image snap shot of my eisy to ISO saved to my RedHat Gateway and like I said I also made sure I had the latest isy-5.5.5_2 that caused problems on it's own just doing that. I then performed this step mentioned by shbatm and it did fix EVERYTHING.
eisy
isy-5.5.5_2
pg3x-3.1.22_3
udx-3.3.6
Keep in mind that Linux command line is not for beginners.
TRI0N
FreeBSD gents, not Linux.  Lots of similarities, lots of differences.
Yeah that's REAL important. Should have gone a step further and explain that both Linux and FreeBSD are just a UNIX Flavor because that would no doubt fix all these problems clients are having. I've been doing it wrong, all along...
TRI0N
I'm not trying to be a jerk, but when you start working with libraries, package managers, file layouts, etc., it can be, and some of the solutions in this thread are wandering into that territory.  But for the most part, it doesn't practically matter.
specifically this
I updated "/usr/local/etc/pkg/repos/FreeBSD.conf" to the following (change "latest" to "quarterly")
FreeBSD: { url: "https://pkg.FreeBSD.org/${ABI}/quarterly", enabled: yes, priority: 1 }
Then ran: "sudo pkg upgrade -f mongo-c-driver"
40 minutes ago, smileyw said:
specifically this
Thank you @smileyw; I found the file and changed it via VI and ran the command. I did a reboot afterwards, but I still cannot connect to the AC and the UDI Portal shows my Polisy as offline.
I am not quite sure how to understand the system message from the upgrade attempt. Did it actually work?
Edited by waffles
maybe because you typed mongo-cdriver instead of mongo-c-driver ?
Edited by brians
Awesome, @brians, thanks for catching this. My AC and the Portal are back up again!
