Glynr Posted April 10, 2023 Posted April 10, 2023 After purchasing the updated EISY about a month ago, I have tried often on to get it set up. I’m not able to, and I default back to my ISY set up. After purchasing the updated EISY about a month ago I have tried often on to get it set up. I’m not able to and I default back to my ISY set up So far what seems to be the biggest issue is that once I do the install it brings over all the devices, etc. but it continually goes through a loop of rebooting. Also, on the mobile app, it will bring over the devices but not control anything.
Techman Posted April 10, 2023 Posted April 10, 2023 Remove power from the EISY, then power it up, wait a minute, then press the front button ONCE. Wait about 10 minutes while the eisy updates. Clear your Java cache, including installed applications and then download the IoX Launcher from here: https://isy.universal-devices.com/start.jnlp Are you using the same PLM for both the ISY994 and the EISY? What is the firmware version on your ISY994?
Glynr Posted April 10, 2023 Author Posted April 10, 2023 Yes same PLM for both. ISY994 5.3.4 will try your suggestions.
Geddy Posted April 11, 2023 Posted April 11, 2023 @Glynr What is the firmware on the eisy? That should be brought up to current release for IoX to have a successful migration. There were some issues in earlier versions of IoX that created problems when migrating. Are you migrating any Z-Wave devices? Be sure that you've followed the migration steps as necessary to your devices: https://wiki.universal-devices.com/index.php?title=Eisy:User_Guide#Preparing_for_Migration_from_ISY-994
Glynr Posted April 11, 2023 Author Posted April 11, 2023 What is the current release for EISY Yes same PLM for both. ISY994 5.3.4 will try your suggestions.
Geddy Posted April 11, 2023 Posted April 11, 2023 On 4/11/2023 at 6:19 PM, Glynr said: What is the current release for EISY Expand link in prior post takes you to the "Current Release" area of the forums. This is the list of all current releases. Looks like 5.5.9 is current release for IoX (eisy/Polisy).
