Michel Kohanim Posted October 27, 2023 Share Posted October 27, 2023 @Irakandjii, We do not have any tickets from you. With kind regards, Michel Link to comment
Irakandjii Posted October 27, 2023 Share Posted October 27, 2023 (edited) Hi I show [Ticket #22965] Poloy dropped off line Oct 20, cannot get reconnected The original ticket and 2 additional informations of my progress Edited October 27, 2023 by Irakandjii 1 Link to comment
Irakandjii Posted October 27, 2023 Share Posted October 27, 2023 My thanks to UD. The system is back up and running! It was not something I could have done, so no point in elaborating other that it is fixed in an exceptionally professional manner 4 Link to comment
Geddy Posted October 31, 2023 Share Posted October 31, 2023 On 10/26/2023 at 9:09 PM, DSwallow said: nothing seems to bring the IP back in the GUI or makes eisy.local work again Try deleting the .state files from UDI. Also clear Java Cache (temporary internet files) and download a new start.jnlp file from the UDI site (click on "My ISY" on the top right). https://wiki.universal-devices.com/index.php?title=Main_Page#Admin_Console_Minimized/Invisible_and_Cannot_be_Restored (not the same problem, but it's where stored information is kept) The issue of reliably getting the friendly URL to display (I've found anyway) is a local network issue. Either router or device times out during the handshake and cannot get it to reliably show. I'm sure anybody with more network experience will contest this, but from personal experience I've seen some routers never auto find, sometimes auto find, or always auto find the URL. Because of the issues people have had over the last year I've tested with some "old" routers I had access to and the process was fairly inconsistent. Some of the worst offenders were "mesh" router systems. Also, some people have reported that IoX Finder window sometimes will report both the IP and the Friendly URL address. That's fine, and has been confirmed as "normal" by UDI. Both go to the same device and since they are discovered automatically are unable to be deleted. Once you have either/or in the IoX Finder window you can SAVE the list locally and then LOAD it should the list ever not populate. On 10/26/2023 at 9:09 PM, DSwallow said: Reading through this thread I see an earlier version seemed to have some similar problems with regard to showing 0.0.0.0 as the IP. I think the steps above might help this issue too. At least clearing the Java Cache and starting admin console fresh might help. One last question - are you experiencing any of this on a laptop that you sometimes use outside of the home/network or with VPN? I've found if I'm on my laptop and travel with it and try to log into the ISY my "local" addresses will drop off the list while I'm gone. Typically they will auto discover next time I'm in the home network. 1 Link to comment
DSwallow Posted October 31, 2023 Share Posted October 31, 2023 So I fiddled some today determined to see what's going on. When the IoX launcher starts up, the EISY is responding to a broadcast UDP query. But it's responding with the address that I see in the UI... https://0.0.0.0:8443, which is most likely being ignored by the IoX Launcher client so nothing gets displayed. If UD can get the reason behind 0.0.0.0 instead of the real IP of the EISY appearing in that field in the UI fixed, we'll probably see resolution of eisy.local by the IoX Finder app fixed, too. 0000 a4 bb 6d d9 16 b9 00 21 b9 02 65 bf 08 00 45 00 ..m....!..e...E. 0010 04 c0 18 df 00 00 40 11 d5 0c c0 a8 03 29 c0 a8 ......@......).. 0020 03 c8 4e 44 4e 44 04 ac 35 ee 4e 45 54 42 04 00 ..NDND..5.NETB.. 0030 00 00 1f 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 21 b9 02 65 bf ...........!..e. 00a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00c0 00 00 00 00 00 00 00 00 00 00 00 00 65 69 73 79 ............eisy 00d0 3a 3d 68 74 74 70 73 3a 2f 2f 30 2e 30 2e 30 2e :=https://0.0.0. 00e0 30 3a 38 34 34 33 2f 64 65 73 63 00 00 00 00 00 0:8443/desc..... 00f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0200 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0210 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0220 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0230 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0310 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0320 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0330 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0340 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0370 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0390 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0410 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0420 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0430 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0440 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0450 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0460 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0480 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0490 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 04a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 04b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 04c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. Link to comment
RRalston Posted October 31, 2023 Share Posted October 31, 2023 (edited) I think you may be having trouble with a service called mDNS [multicast DNS], which uses port 5353 IN/OUT to create local records to simulate a DNS server on the local network. I found this was causing me trouble related to the eisy.local:8443 name resolution. If you have a local host firewall, it may be blocking these ports and services. Windows svchost.exe is directly involved with this. You can search for mDNS and find many articles, but here is a reasonable post: https://stevessmarthomeguide.com/multicast-dns/ Rob Edited October 31, 2023 by RRalston added svchost.exe info Link to comment
DSwallow Posted October 31, 2023 Share Posted October 31, 2023 (edited) 20 minutes ago, RRalston said: I think you may be having trouble with a service called mDNS [multicast DNS], which uses port 5353 IN/OUT to create local records to simulate a DNS server on the local network. I found this was causing me trouble related to the eisy.local:8443 name resolution. If you have a local host firewall, it may be blocking these ports and services. You can search for mDNS and find many articles, but here is a reasonable post: https://stevessmarthomeguide.com/multicast-dns/ Rob Exploring mDNS was among the many things I went through today; the EISY isn't using mDNS or at least if they think they are, their service is dead and they aren't listening on the port. It's listening via UDP and responding to requests that the IoX Finder is sending out; I captured the whole exchange in Wireshark and examined it. Now IoX Finder is also making a variety of other sorts of queries, and I see all sorts of devices on my network responding, including mDNS and NETBIOS name queries. But the only thing coming from the EISY is the UDP packet data I posted above. I can interact from my desktop using mDNS with all sorts of devices on my same network. Nothing is getting blocked there. Here's all the mDNS related packets that occurred during my test: 192.168.3.200 is my desktop 192.168.3.41 is the EISY 192.168.3.1 is my gateway/router 192.168.3.7 is my DNS No. Time Source Destination Protocol Length Info 1287 4.953985 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 A eisy.local, "QM" question 1288 4.954681 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 A eisy.local, "QM" question 1289 4.955198 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 AAAA eisy.local, "QM" question 1290 4.955599 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 AAAA eisy.local, "QM" question 1291 4.956055 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1292 4.956230 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1293 4.956484 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1294 4.956484 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1295 4.956645 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1296 4.956849 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1297 4.956849 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1298 4.957047 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1303 4.971808 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 A eisy.local, "QM" question 1304 4.972317 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 A eisy.local, "QM" question 1305 4.972670 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1306 4.972670 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1307 4.972834 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 AAAA eisy.local, "QM" question 1308 4.973143 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1309 4.973252 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1310 4.973287 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 AAAA eisy.local, "QM" question 1311 4.973718 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1312 4.973718 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1313 4.974039 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1314 4.974215 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1315 5.122854 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 1318 5.173124 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 1346 5.960090 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 A eisy.local, "QM" question 1347 5.960611 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 A eisy.local, "QM" question 1348 5.960990 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 AAAA eisy.local, "QM" question 1349 5.961018 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1350 5.961018 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1351 5.961399 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 AAAA eisy.local, "QM" question 1352 5.961518 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1353 5.961605 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1354 5.961832 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1355 5.961943 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1356 5.962350 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1357 5.962440 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1358 5.975741 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 A eisy.local, "QM" question 1359 5.976209 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 A eisy.local, "QM" question 1360 5.976592 192.168.3.200 224.0.0.251 MDNS 70 Standard query 0x0000 AAAA eisy.local, "QM" question 1361 5.976656 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1362 5.976752 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 A eisy.local, "QM" question 1363 5.977016 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 90 Standard query 0x0000 AAAA eisy.local, "QM" question 1364 5.977054 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1365 5.977054 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 A eisy.local, "QM" question 1366 5.977383 192.168.3.194 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1367 5.977500 192.168.3.193 224.0.0.251 MDNS 70 Standard query response 0x0000 AAAA eisy.local, "QM" question 1368 5.977786 fe80::218:ddff:fe04:accc ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1369 5.977958 fe80::218:ddff:fe04:a59f ff02::fb MDNS 90 Standard query response 0x0000 AAAA eisy.local, "QM" question 1545 6.033822 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 1546 6.047189 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 2156 9.815478 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 A polisy.local, "QM" question 2157 9.816010 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 A polisy.local, "QM" question 2159 9.816461 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2160 9.816461 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2161 9.816473 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 AAAA polisy.local, "QM" question 2162 9.816866 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 AAAA polisy.local, "QM" question 2163 9.817130 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2164 9.817130 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2165 9.817403 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2166 9.817403 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2167 9.817735 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2168 9.817735 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2170 9.818937 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 A polisy.local, "QM" question 2171 9.819306 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 A polisy.local, "QM" question 2172 9.819703 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 AAAA polisy.local, "QM" question 2173 9.819847 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2174 9.819847 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2175 9.820039 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2176 9.820039 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2177 9.820054 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 AAAA polisy.local, "QM" question 2178 9.820741 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2179 9.820741 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2180 9.820979 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2181 9.820979 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2185 10.004862 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 2186 10.041436 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 2383 10.827370 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 A polisy.local, "QM" question 2384 10.827868 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 A polisy.local, "QM" question 2385 10.828243 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 A polisy.local, "QM" question 2386 10.828278 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2387 10.828660 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 A polisy.local, "QM" question 2388 10.828791 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2389 10.829030 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 AAAA polisy.local, "QM" question 2390 10.829078 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2391 10.829431 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2392 10.829451 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 AAAA polisy.local, "QM" question 2393 10.829557 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2394 10.829761 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2395 10.829830 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2396 10.829861 192.168.3.200 224.0.0.251 MDNS 72 Standard query 0x0000 AAAA polisy.local, "QM" question 2397 10.830241 fe80::10c6:6196:1ef5:1575 ff02::fb MDNS 92 Standard query 0x0000 AAAA polisy.local, "QM" question 2398 10.830284 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 A polisy.local, "QM" question 2399 10.830501 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2400 10.830629 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 A polisy.local, "QM" question 2401 10.830802 192.168.3.194 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2402 10.830802 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2403 10.831326 fe80::218:ddff:fe04:accc ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2404 10.831511 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2405 10.831951 192.168.3.193 224.0.0.251 MDNS 72 Standard query response 0x0000 AAAA polisy.local, "QM" question 2406 10.832119 fe80::218:ddff:fe04:a59f ff02::fb MDNS 92 Standard query response 0x0000 AAAA polisy.local, "QM" question 2409 10.960505 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 2410 10.960887 192.168.3.149 224.0.0.251 MDNS 89 Standard query response 0x0000 A, cache flush 192.168.3.149 In fact, during the entire test, there was only one single packet on the network from the EISY -- its response to the UDP query that also went out when the IoX Finder was launched: No. Time Source Destination Protocol Length Info 1317 5.143901 192.168.3.41 192.168.3.200 UDP 1230 20036 → 20036 Len=1188 In any event, whether the EISY is supposed to support responding to mDNS queries or not, it probably would respond exactly the same way it's responding to this UDP query... with the IP address it thinks it knows -- 0.0.0.0 -- so that really does need some attention from UD I think; then we'll probably see this function reliably. Here's the UDP query that the EISY is responding to, BTW: Frame 1316: 66 bytes on wire (528 bits), 66 bytes captured (528 bits) on interface \Device\NPF_{3EDCBF5C-B1CB-405D-A067-D90E0C99C4C2}, id 0 Section number: 1 Interface id: 0 (\Device\NPF_{3EDCBF5C-B1CB-405D-A067-D90E0C99C4C2}) Encapsulation type: Ethernet (1) Arrival Time: Oct 31, 2023 13:59:23.776860000 Eastern Daylight Time [Time shift for this packet: 0.000000000 seconds] Epoch Time: 1698775163.776860000 seconds [Time delta from previous captured frame: 0.020832000 seconds] [Time delta from previous displayed frame: 0.020832000 seconds] [Time since reference or first frame: 5.143686000 seconds] Frame Number: 1316 Frame Length: 66 bytes (528 bits) Capture Length: 66 bytes (528 bits) [Frame is marked: False] [Frame is ignored: False] [Protocols in frame: eth:ethertype:ip:udp:data] [Coloring Rule Name: UDP] [Coloring Rule String: udp] Ethernet II, Src: Dell_d9:16:b9 (a4:bb:6d:d9:16:b9), Dst: Broadcast (ff:ff:ff:ff:ff:ff) Destination: Broadcast (ff:ff:ff:ff:ff:ff) Source: Dell_d9:16:b9 (a4:bb:6d:d9:16:b9) Type: IPv4 (0x0800) Internet Protocol Version 4, Src: 192.168.3.200, Dst: 192.168.3.255 0100 .... = Version: 4 .... 0101 = Header Length: 20 bytes (5) Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT) Total Length: 52 Identification: 0xd949 (55625) 000. .... = Flags: 0x0 ...0 0000 0000 0000 = Fragment Offset: 0 Time to Live: 128 Protocol: UDP (17) Header Checksum: 0x0000 [validation disabled] [Header checksum status: Unverified] Source Address: 192.168.3.200 Destination Address: 192.168.3.255 User Datagram Protocol, Src Port: 20036, Dst Port: 20036 Source Port: 20036 Destination Port: 20036 Length: 32 Checksum: 0xf369 [unverified] [Checksum Status: Unverified] [Stream index: 45] [Timestamps] UDP payload (24 bytes) Data (24 bytes) Data: 4255524e5200000000000000000000000000000000000000 [Length: 24] 0000 ff ff ff ff ff ff a4 bb 6d d9 16 b9 08 00 45 00 ........m.....E. 0010 00 34 d9 49 00 00 80 11 00 00 c0 a8 03 c8 c0 a8 .4.I............ 0020 03 ff 4e 44 4e 44 00 20 f3 69 42 55 52 4e 52 00 ..NDND. .iBURNR. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 .. Edited October 31, 2023 by DSwallow Link to comment
Geddy Posted October 31, 2023 Share Posted October 31, 2023 @DSwallow seems like you've got more experience to try to troubleshoot stuff and digging deeper than most would go. If this is an issue causing you not to be able to access the eisy then I would suggest you open a support ticket for specific help from UDI rather than user-to-user support mostly found here. Their troubleshooting process might be better suited to fixing what might be causing this for you. https://www.universal-devices.com/my-tickets Link to comment
DSwallow Posted October 31, 2023 Share Posted October 31, 2023 1 hour ago, Geddy said: @DSwallow seems like you've got more experience to try to troubleshoot stuff and digging deeper than most would go. If this is an issue causing you not to be able to access the eisy then I would suggest you open a support ticket for specific help from UDI rather than user-to-user support mostly found here. Their troubleshooting process might be better suited to fixing what might be causing this for you. https://www.universal-devices.com/my-tickets Yeah, I know. I'll get there and open a ticket soon. But one more little investigative nugget to follow... Link to comment
DSwallow Posted November 1, 2023 Share Posted November 1, 2023 SO, I looked through some logs on the EISY and found a clue about what's likely leading to the issue of the IP not being available by whatever code needs it to respond to things like displaying in the Java UI or replying to network queries to resolve eisy.local. From /var/udx/logs/debug.log, the latest boot includes these messages with regard to nics/network operations: 2023-10-31 12:49:03 - Warn| NetMgr [T:35250049024] couldn't find any wlan devices (../src/Device/Net/UDXNetworkManager.cpp@254:addWiFiDevices()) 2023-10-31 12:49:03 - Info| NetMgr [T:35250049024] re0 is a hardware link/Ethernet. checking to see if WiFi (../src/Device/Net/UDXNetworkManager.cpp@180:addInterface()) 2023-10-31 12:49:03 - Info| Config [T:35250049024] OID = net.re.0.%parent (../src/Config/UDXConfigRecords.cpp@101:getWlanParent()) 2023-10-31 12:49:03 - Error|SysCall [T:35250049024] [1]: command failed sysctl net.re.0.%parent (../src/Kernel/SystemCall.cpp@185:execWithOutput()) 2023-10-31 12:49:03 - Info| NetMgr [T:35250049024] re0 is not a WiFi device (../src/Device/Net/UDXNetworkManager.cpp@211:addInterface()) 2023-10-31 12:49:03 - Info| NetMgr [T:35250049024] setting IPV4 inet for re0 (../src/Device/Net/UDXNetworkManager.cpp@110:addInterface()) 2023-10-31 12:49:03 - Warn| NetMgr [T:35250049024] lo0 is loopback. ignoring (../src/Device/Net/UDXNetworkManager.cpp@147:addInterface()) 2023-10-31 12:49:03 - Warn| NetMgr [T:35250049024] ignoring lo0 (loopback, tap/tun/wifibox (../src/Device/Net/UDXNetworkManager.cpp@97:addInterface()) 2023-10-31 12:49:03 - Warn| NetMgr [T:35250049024] ignoring lo0 (loopback, tap/tun/wifibox (../src/Device/Net/UDXNetworkManager.cpp@97:addInterface()) 2023-10-31 12:49:03 - Warn| NetMgr [T:35250049024] ignoring lo0 (loopback, tap/tun/wifibox (../src/Device/Net/UDXNetworkManager.cpp@97:addInterface()) 2023-10-31 12:49:03 - Info| NetMgr [T:35250049024] setting interface state information if any (../src/Device/Net/UDXNetworkManager.cpp@425:registerAllDevices()) 2023-10-31 12:49:03 - Info| Config [T:35250049024] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:03 - Info| Config [T:35250049024] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:03 - Warn|Network [T:35250049024] re0 is disabled. Ignoring (../src/Device/Net/UDXNetworkInterface.cpp@321:refresh()) 2023-10-31 12:49:03 - Info| Config [T:35250049024] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:03 - Info| Config [T:35250049024] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:03 - Warn| NetMgr [T:35250049024] re0 is not running (../src/Device/Net/UDXNetworkManager.cpp@448:registerAllDevices()) 2023-10-31 12:49:03 - Info| Serial [T:35250049024] starting to look for serial devices (../src/Device/Serial/UDXSerialPortManager.cpp@42:registerAllDevices()) 2023-10-31 12:49:05 - Info| NetMgr [T:35250057984] refreshing IPV4 inet for re0 (../src/Device/Net/UDXNetworkManager.cpp@342:refreshInterface()) 2023-10-31 12:49:05 - Info| NetMgr [T:35250057984] refreshing IPV4 inet for lo0 - Loopback. Ignoring (../src/Device/Net/UDXNetworkManager.cpp@354:refreshInterface()) 2023-10-31 12:49:05 - Info| NetMgr [T:35250057984] refreshing IPV4 inet for lo0 - Loopback. Ignoring (../src/Device/Net/UDXNetworkManager.cpp@354:refreshInterface()) 2023-10-31 12:49:05 - Warn| NetMgr [T:35250057984] refreshing IPV4 inet for lo0 - Loopback. Ignoring (../src/Device/Net/UDXNetworkManager.cpp@339:refreshInterface()) 2023-10-31 12:49:05 - Info| Config [T:35250057984] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:05 - Info| Config [T:35250057984] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:05 - Warn|Network [T:35250057984] re0 is disabled. Ignoring (../src/Device/Net/UDXNetworkInterface.cpp@321:refresh()) 2023-10-31 12:49:05 - Info| Config [T:35250057984] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:05 - Info| Config [T:35250057984] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-31 12:49:05 - Info| Config [T:35250057984] starting to parse file /var/udx/.env, delim = = (../src/Config/UDXConfig.cpp@20:parse()) 2023-10-31 12:49:05 - Info|SysConfig [T:35250057984] publish to topic = sconfig/network/nics. msg = {"NICs":[{"name":"re0","logicalName":"re0","mac":"00:21:ffffffb9:02:65:ffffffbf","isEnabledIPv4":false,"isEnabledIPv6":false,"isRunning":false,"isDHCP":false,"isRTADV":false,"isWiFi":false,"IPInfo":{"ip":"0.0.0.0","ipV6":"::","mask":"255.0.0.0","gateway":"0.0.0.0","gatewayV6":"::"}}],"root":{"uuid":"00:21:b9:02:65:bf","serial":"92144837862847"}} (../src/mqtt/UDXSysConfig.cpp@770:udxPublishMessage()) 2023-10-31 12:49:05 - DBG3| MQTTc [T:35250057984] MQTTLogEvent level=16, desc=Client null sending PUBLISH (d0, q0, r0, m12, 'sconfig/network/nics', ... (347 bytes)) (../src/System/UDXMQTTc.cpp@618:on_log()) 2023-10-31 12:49:05 - Info| MQTTc [T:35250057984] published 11 (../src/System/UDXMQTTc.cpp@575:on_publish()) 2023-10-31 12:49:05 - Info| MQTTc [T:35250057984] published 12 (../src/System/UDXMQTTc.cpp@575:on_publish()) What's interesting here is earlier in the log file is a record of where there was a real IP address on that publish-to-topic entry: 2023-10-26 17:58:36 - Warn| NetMgr [T:35266076672] couldn't find any wlan devices (../src/Device/Net/UDXNetworkManager.cpp@254:addWiFiDevices()) 2023-10-26 17:58:36 - Info| NetMgr [T:35266076672] re0 is a hardware link/Ethernet. checking to see if WiFi (../src/Device/Net/UDXNetworkManager.cpp@180:addInterface()) 2023-10-26 17:58:36 - Info| Config [T:35266076672] OID = net.re.0.%parent (../src/Config/UDXConfigRecords.cpp@101:getWlanParent()) 2023-10-26 17:58:36 - Error|SysCall [T:35266076672] [1]: command failed sysctl net.re.0.%parent (../src/Kernel/SystemCall.cpp@185:execWithOutput()) 2023-10-26 17:58:36 - Info| NetMgr [T:35266076672] re0 is not a WiFi device (../src/Device/Net/UDXNetworkManager.cpp@211:addInterface()) 2023-10-26 17:58:36 - Info| NetMgr [T:35266076672] setting IPV4 inet for re0 (../src/Device/Net/UDXNetworkManager.cpp@110:addInterface()) 2023-10-26 17:58:36 - Warn| NetMgr [T:35266076672] lo0 is loopback. ignoring (../src/Device/Net/UDXNetworkManager.cpp@147:addInterface()) 2023-10-26 17:58:36 - Warn| NetMgr [T:35266076672] ignoring lo0 (loopback, tap/tun/wifibox (../src/Device/Net/UDXNetworkManager.cpp@97:addInterface()) 2023-10-26 17:58:36 - Warn| NetMgr [T:35266076672] ignoring lo0 (loopback, tap/tun/wifibox (../src/Device/Net/UDXNetworkManager.cpp@97:addInterface()) 2023-10-26 17:58:36 - Warn| NetMgr [T:35266076672] ignoring lo0 (loopback, tap/tun/wifibox (../src/Device/Net/UDXNetworkManager.cpp@97:addInterface()) 2023-10-26 17:58:36 - Info| NetMgr [T:35266076672] setting interface state information if any (../src/Device/Net/UDXNetworkManager.cpp@425:registerAllDevices()) 2023-10-26 17:58:36 - Info| Config [T:35266076672] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:36 - Info| Config [T:35266076672] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:36 - Warn|Network [T:35266076672] re0 is disabled. Ignoring (../src/Device/Net/UDXNetworkInterface.cpp@321:refresh()) 2023-10-26 17:58:36 - Info| Config [T:35266076672] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:36 - Info| Config [T:35266076672] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:36 - Warn| NetMgr [T:35266076672] re0 is not running (../src/Device/Net/UDXNetworkManager.cpp@448:registerAllDevices()) 2023-10-26 17:58:36 - Info| Serial [T:35266076672] starting to look for serial devices (../src/Device/Serial/UDXSerialPortManager.cpp@42:registerAllDevices()) 2023-10-26 17:58:43 - Info| NetMgr [T:35266085632] refreshing IPV4 inet for re0 (../src/Device/Net/UDXNetworkManager.cpp@342:refreshInterface()) 2023-10-26 17:58:43 - Info| NetMgr [T:35266085632] refreshing IPV4 inet for lo0 - Loopback. Ignoring (../src/Device/Net/UDXNetworkManager.cpp@354:refreshInterface()) 2023-10-26 17:58:43 - Info| NetMgr [T:35266085632] refreshing IPV4 inet for lo0 - Loopback. Ignoring (../src/Device/Net/UDXNetworkManager.cpp@354:refreshInterface()) 2023-10-26 17:58:43 - Warn| NetMgr [T:35266085632] refreshing IPV4 inet for lo0 - Loopback. Ignoring (../src/Device/Net/UDXNetworkManager.cpp@339:refreshInterface()) 2023-10-26 17:58:43 - Info| Config [T:35266085632] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:43 - Info| Config [T:35266085632] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:43 - Warn|Network [T:35266085632] re0 is disabled. Ignoring (../src/Device/Net/UDXNetworkInterface.cpp@321:refresh()) 2023-10-26 17:58:43 - Info| Config [T:35266085632] getting network configuration for ifconfig_re0 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:43 - Info| Config [T:35266085632] getting network configuration for ifconfig_re0_ipv6 ... (../src/Config/UDXRCConfig.cpp@48:getNetworkConfig()) 2023-10-26 17:58:43 - Info| Config [T:35266085632] starting to parse file /var/udx/.env, delim = = (../src/Config/UDXConfig.cpp@20:parse()) 2023-10-26 17:58:43 - Info|SysConfig [T:35266085632] publish to topic = sconfig/network/nics. msg = {"NICs":[{"name":"re0","logicalName":"re0","mac":"00:21:ffffffb9:02:65:ffffffbf","isEnabledIPv4":false,"isEnabledIPv6":false,"isRunning":false,"isDHCP":false,"isRTADV":false,"isWiFi":false,"IPInfo":{"ip":"192.168.3.172","ipV6":"::","mask":"255.255.255.0","gateway":"0.0.0.0","gatewayV6":"::"}}],"root":{"uuid":"00:21:b9:02:65:bf","serial":"92144837862847","activeIP":"\"192.168.3.172\"","activeNic":"\"re0\""}} (../src/mqtt/UDXSysConfig.cpp@770:udxPublishMessage()) 2023-10-26 17:58:43 - DBG3| MQTTc [T:35266085632] MQTTLogEvent level=16, desc=Client null sending PUBLISH (d0, q0, r0, m12, 'sconfig/network/nics', ... (410 bytes)) (../src/System/UDXMQTTc.cpp@618:on_log()) 2023-10-26 17:58:43 - Info| MQTTc [T:35266085632] published 11 (../src/System/UDXMQTTc.cpp@575:on_publish()) 2023-10-26 17:58:43 - Info| MQTTc [T:35266085632] published 12 (../src/System/UDXMQTTc.cpp@575:on_publish()) I would sort of guess here is that there's some sort of disconnect between whatever triggers this program to be querying IP settings from the re0 interface and how they may not yet be current, like if the DHCP request just got processed and some signal is sent and then a query made and those settings received aren't quite yet wherever the program is querying them, then it just spews out an update to the MQTT service storing those settings that it read, even though they're bad. And likely anything else wanting to use or display some of those settings is querying that published topic from MQTT and using it. Might even be more plausible considering the timestamp on /var/db/dhclient.leases.re0 where a record of the dhcp client leases is kept is one second after the log output above where the bad info is reported in the log file. [admin@eisy /var/db]$ sudo stat -F /var/db/dhclient.leases.re0 ---------- 1 root wheel 1141 Oct 31 12:49:06 2023 /var/db/dhclient.leases.re0 Anyway, I then tried seeing if I could force it to update, maybe by disconnecting/reconnecting the ethernet connection. All that did was make it go unresponsive on the network; Insteon stuff was still behaving, but I could no longer connect to the IP. I had to restart the EISY to get IP connectivity back. When I then went back to the debug.log file, I saw an interesting addition to the end... it now had an IP address in the logged line sending the update to MQTT 2023-10-31 20:16:48 - Info|SysConfig [T:35277861632] publish to topic = sconfig/network/nics. msg = {"NICs":[{"name":"re0","logicalName":"re0","mac":"00:21:ffffffb9:02:65:ffffffbf","isEnabledIPv4":false,"isEnabledIPv6":false,"isRunning":false,"isDHCP":false,"isRTADV":false,"isWiFi":false,"IPInfo":{"ip":"192.168.3.41","ipV6":"::","mask":"255.255.255.0","gateway":"0.0.0.0","gatewayV6":"::"}}],"root":{"uuid":"00:21:b9:02:65:bf","serial":"92144837862847"}} (../src/mqtt/UDXSysConfig.cpp@770:udxPublishMessage()) Though looking at the earlier entry where it was also sending an IP, there are some entries that are still missing here, specifically the activeIP and activeNIC keys in that message, so I do think this is somehow part of the problem: "activeIP":"\"192.168.3.172\"","activeNic":"\"re0\"" Now, on to opening a ticket and pointing them to this info. Link to comment
DSwallow Posted November 1, 2023 Share Posted November 1, 2023 (edited) I had an online session with UD support a little while ago, and ultimately the issue was caused by a delayed response to the DHCP request when the EISY boots up. The EISY has a 10 second timeout and then continues its startup/initialization, and at that time there's no IP address assigned, so it just works off the 0.0.0.0 address. The DHCP request did ultimately complete, but nothing in the EISY sees that as an event to trigger any operation to reconfigure itself appropriately. I'm told that when the lease is renewed (or if the Ethernet cable is unplugged/reconnected or the device switches over to WiFi, if configured) that the EISY would see the event triggered and go through the same process of initializing, though may still encounter the DHCP delay and continue having the same IP address issue, and not resolving eisy.local. We moved the EISY to connect through the built-in switch in my router (a UDM-SE) and went through the reboot process and now saw the DHCP request get responded to immediately, the IP address was properly configured, it showed up in the UI and eisy.local resolved. Now on my side the DHCP delay was caused because my EISY was connected to a Dell PowerConnect 2848 switch, and apparently there's an issue in the way the Spanning Tree operations configure on a port when the port connects, which it does when rebooting the EISY (i.e., the ethernet port goes dark during the reboot). It then is in a learning mode on the port and blocking at least some of the packets, perhaps the broadcast ones. The solution is to enable the "Fast Link" option on the port on the switch. This leads to the port coming up in Forwarding mode immediately while the port is then monitored to ensure it isn't in a looped connection. A couple articles I discovered doing a search: https://serverfault.com/questions/305788/dell-powerconnect-2824-dhcp-takes-30-40-seconds-to-respond https://www.mcbsys.com/blog/2010/02/gigabit-switch-spanning-tree-causes-slow-logon/ The documentation from the switch about the "Fast Link" option: Fast Link — When selected, enables Fast Link mode for the port. If Fast Link mode is enabled for a port, the Port State is automatically placed in the Forwarding state when the port link is up. Fast Link mode optimizes the time it takes for the STP protocol to converge. STP convergence can take 30-60 seconds in large networks. So, I will monitor it more closely for a while, but it does seem to be consistent and behaving now. And I'm not sure what other devices I may have that are using DHCP on that switch but I've turned on Fast Link on all the ports except those connected to other switches, so I may end up cleaning up some other odd delays in reboots/initializations. A few of you folks previously mentioned having a 0.0.0.0 IP address showing in the UI and eisy.local not resolving, so here's a few things you might try to investigate... One of the EISY services can be restarted which will re-initialize parts of the network operation so if there was an initialization delay getting an IP, once it is configured, this would configure things again. After restarting this service, I did get eisy.local resolving (though we didn't look at the UI specifically to see if the IP was there now, it probably was). sudo service ud_net_detect onerestart You can also look at the logs to see if there are entries referencing the IP address not be available: sudo vi /var/udx/logs/log Look for items like this: Wed Nov 1 19:21:46 EDT 2023|/usr/local/etc/udx.d/static/eth.ops: error, no ip address for re0 ... Wed Nov 1 19:21:47 EDT 2023|/usr/local/etc/udx.d/static/eth.ops: error, no ip address for re0 ... Wed Nov 1 19:21:48 EDT 2023|/usr/local/etc/udx.d/static/eth.ops: error, no ip address for re0 ... Wed Nov 1 19:21:49 EDT 2023|/usr/local/etc/udx.d/static/eth.ops: error, no ip address for re0 ... Side effects... when I reboot the EISY I usually have a command prompt doing a ping to watch when it is back up, and with the fixed DHCP, the operation is noticeably quicker. Without Fast Link enabled on the switch for the connected port: Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 Request timed out. Request timed out. Request timed out. Request timed out. Request timed out. Request timed out. Reply from 192.168.3.200: Destination host unreachable. Reply from 192.168.3.200: Destination host unreachable. Reply from 192.168.3.200: Destination host unreachable. Reply from 192.168.3.200: Destination host unreachable. Reply from 192.168.3.200: Destination host unreachable. Reply from 192.168.3.200: Destination host unreachable. Reply from 192.168.3.200: Destination host unreachable. Reply from 192.168.3.41: bytes=32 time=1529ms TTL=64 Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 With Fast Link enabled: Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 Request timed out. Request timed out. Request timed out. Request timed out. Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 Reply from 192.168.3.41: bytes=32 time<1ms TTL=64 Edited November 2, 2023 by DSwallow 3 Link to comment
Illusion Posted November 5, 2023 Share Posted November 5, 2023 (edited) Daylight Saving Time ended last night. Woke up this morning and none of the stuff that should have happened happened. Programs not running. Open admin console and find that all 300 programs are set to 'Not Enabled'. Required manual intervention of 'Restart IoX' to correct. Edited November 5, 2023 by Illusion Link to comment
DennisC Posted November 5, 2023 Share Posted November 5, 2023 8 minutes ago, Illusion said: Daylight Saving Time ended last night. Woke up this morning and none of the stuff that should have happened happened. Programs not running. Open admin console and find that all 300 programs are set to 'Not Enabled'. Try power cycling your unit. IF that doesn't work, try restoring a backup. Link to comment
btreinders Posted November 5, 2023 Share Posted November 5, 2023 My Polisy has sunrise and sunset off by an hour this morning as well. Link to comment
DennisC Posted November 5, 2023 Share Posted November 5, 2023 (edited) 6 minutes ago, btreinders said: My Polisy has sunrise and sunset off by an hour this morning as well. I would suggest power cycling Polisy. Mine was fine this morning. Also, verify you are on the latest build, v5.7.0_5. You can run: https://xxx.xxx.x.xxx:8443/WEB/sysconfig.txt Substitute your IP address for "x". You may need to click through some warnings. You can use Ctrl + F to search for ISY to locate your version. Edited November 5, 2023 by DennisC Spelling + added info Link to comment
btreinders Posted November 5, 2023 Share Posted November 5, 2023 On the latest version for sure and just pulled power for a minute and then booted it back up. No joy. Still has both one hour off. Has them both an hour early. Link to comment
GJ Software Products Posted November 5, 2023 Share Posted November 5, 2023 Similar issues with my eisy after the time change. Programs quit running and I had to manually trigger them and they had been running since 11/3 6:55 after I installed PG3 3.2.14 and rebooted. I rebooted again this AM and what was interesting is that UD Mobile reported the update was complete, again. But it appears the reboot after the time change fixed everything. Link to comment
Illusion Posted November 5, 2023 Share Posted November 5, 2023 4 hours ago, btreinders said: On the latest version for sure and just pulled power for a minute and then booted it back up. No joy. Still has both one hour off. Has them both an hour early. In response to your post I looked, and sure enough, my sunrise and sunset are both an hour early... Link to comment
vbPhil Posted November 5, 2023 Share Posted November 5, 2023 14 minutes ago, Illusion said: In response to your post I looked, and sure enough, my sunrise and sunset are both an hour early... I had a similar problem long time ago for my location in Albuquerque. UDI had to change the rules. The list of Locations shown when selecting the AC Change Location button is wrong for Albuquerque. It shows the Albuquerque Daylight Saving Rule is America/Phoenix, it should be America/Denver. Phoenix does not change to Daylight Saving. I wonder when that rule was changed. I've never had this problem before. Link to comment
GJ Software Products Posted November 5, 2023 Share Posted November 5, 2023 Yep, I just went & looked at mine and they are both an hour early too. I'm looking at a photocell (actually the average of 2) for my exterior lighting control so this shouldn't hurt me as my system stands at the moment. Link to comment
Michel Kohanim Posted November 5, 2023 Share Posted November 5, 2023 Hello all, Apologies for the problems. The UI in the Admin Console is definitely incorrect. This said, the program should be fine. Does anyone have any example (screenshot) of programs having the wrong next runtime (ether sunset/sunrise or both)? With kind regards, Michel 1 Link to comment
tlightne Posted November 5, 2023 Share Posted November 5, 2023 My sunset programs ran at the correct sunset time with the UI showing sunset as 1 hour early.. Link to comment
Techman Posted November 5, 2023 Share Posted November 5, 2023 My programs ran at the correct time. It appears that the UI sunrise / sunset display is incorrect. Link to comment
GJ Software Products Posted November 5, 2023 Share Posted November 5, 2023 @Michel Kohanim I didn't take a screen-shot What I encountered this AM is my exterior lights didn't go off, and when I dug into it all the last & next run times were blank. I look at a photocell & turn the lights on and off. Somewhat similar to the problem I had when programs flagged run at startup never ran that Chris took a look remoting in and saw enough to understand and it appeared to be fixed now in earlier updates. But after I rebooted it fixed itself this time. They all worked Fri. night & Sat. AM & PM without intervention but something to do with the time changed cleared all the last/next run times... ??? Link to comment
mmb Posted November 6, 2023 Share Posted November 6, 2023 9 hours ago, btreinders said: My Polisy has sunrise and sunset off by an hour this morning as well. Checked my Polisy, my display is off by 1 hour as well. Link to comment
