Panda88 Posted November 9, 2024 Posted November 9, 2024 can you send a debug log. i am guessing otherwise Quote
Panda88 Posted November 9, 2024 Posted November 9, 2024 can you send a log file this is what my mobile app shows Quote
apostolakisl Posted November 9, 2024 Author Posted November 9, 2024 I didn't do an update. I put it in the same slot as the previous, but completely different Tesla node was. Then did a fresh install of the new one. I just drove the car and it currently shows good data. I will see what happens in a bit and send a log. Quote
Panda88 Posted November 10, 2024 Posted November 10, 2024 Is it acceptable it I only allow update Data (button) on the status page? It will update data on all pages, but will be a much simpler to implement Quote
glenn_steiner Posted December 28, 2024 Posted December 28, 2024 link is bad and is: ttps://github.com/Panda88CO/udi-TeslaEV2/blob/main/README.md yes, missing an h at the beginning Quote
Panda88 Posted December 28, 2024 Posted December 28, 2024 I cannot find the bad link - which one are you referring to? I'll try to fix it Quote
Geddy Posted December 28, 2024 Posted December 28, 2024 @Panda88 I think it’s the “more info” button on the plugin page. When viewing on a mobile device it asks me if I’m trying to open another app. Quote
Panda88 Posted December 28, 2024 Posted December 28, 2024 it does not show in the released note but there have been some updates that did not populate so it may be an older version Quote
glenn_steiner Posted December 28, 2024 Posted December 28, 2024 5 hours ago, Geddy said: @Panda88 I think it’s the “more info” button on the plugin page. When viewing on a mobile device it asks me if I’m trying to open another app. Yes. Thanks for clarifying my comment. Its the more info button. Quote
apostolakisl Posted December 29, 2024 Author Posted December 29, 2024 (edited) I have updated to the latest version and this still is not working. My car is currently charging and the phone app shows it as charging and currently 75%. This is what the node says. I assume "status" should be saying 75%. And of course the other info should be saying it is charging. If I click "honk horn", it does honk the horn. So clearly it is connected in some fashion. And the climate page shows 0 degrees c in the "node connected" field. That makes no sense. My phone app shows exterior temp as 81 and interior temp as 92. EDIT: After a bit, not sure how long, it did update to say it was charging, but still reporting 0% status. Edited December 29, 2024 by apostolakisl Quote
Panda88 Posted December 29, 2024 Posted December 29, 2024 can you send me a log file? what version is it reporting? Quote
someguy Posted December 29, 2024 Posted December 29, 2024 @apostolakisl: I had a similar problem recently where none of my data was updating. I was able to fix it by using the "autheticate" button in PG3x and this fixed the issue. Quote
apostolakisl Posted January 13 Author Posted January 13 I updated the node today and now I am getting an accurate percent on the battery. Quote
