HomeKit or Home Assistant Integrations - Advantages? (What's the point?)
SJK
General question: What's the advantage of integrating HomeKit (Apple) to IoX? I'm not sure what I'm missing out on by not doing this and interested in the killer functionality this provides given all the talk re: Matter, etc.  With the pending January update just announced, I'm thinking the advantage is even less. I'd understand if someone started with a HomeKit environment and fell into IoX, but not the other way around.
I have an Insteon-heavy environment, so IoX is ideal there. I have branched out into Zigbee 3.0 (Hue bulbs, Sonoff switches, GLEDOPTO devices for LED strips and architectural lighting) but also use Polyglot for UniFi, Venstar, Elk, and CAO/Wireless Tags integrations. An eISY and a Polisy running IoX and Polyglot are my only hubs.
The admin console programming setup is very flexible- things often require multiple small programs making sort of a web of interactions (vs a HomeAssistant script for example) but it's intuitive. Any limitations I've run into when trying to accomplish something is more often hardware-based, rather than IoX capabilities itself- with a few exceptions of trying out some cheap "unsupported" devices. Perhaps that's it? People using a mishmash of cheap consumer devices of the week that are supported in HK or HA and may not have made it into IoX yet?
I'm not currently using ZWave at this house but am in commercial settings.
So what's the advantage? A prettier UI from Apple instead of UDMobile? Even there, UDMobile is awesome- I've built a massive interface for my iPhone allowing me to control multiple IoX systems at multiple in one place. And I try to automate most actions so I don't need to fiddle around in the app to live my life- my home just does it's thing and responds to presence, motion, climate/weather/luminance, etc. I use Insteon keypads for most manual interaction and am installing a wall-mounted iPad to run UDMobile and a web browser for other home services (calendar/shopping list, etc). I'd rather not have to whip out my iPhone as I walk around my house to trigger events.  I interact with Elk directly for security when home, which IoX monitors to trigger some routines, and UDMobile if I need to interact with or monitor the security system when away from the premises.
I'm using UniFi protect for cameras (and access at commercial settings) but they have their own apps and I don't really need them to integrate with IoX. and then I could integrate an RSTP camera stream to UDMobile if desired (not sure of that other than quick access to a key feed or two in case of an alarm event rather than switching apps- maybe).
Sonos and Roku aren't well integrated into IoX via Polyglot- always ran into issues with them (some self-inflicted based upon enforced network segmentation)- but then Sonos has an app if I want to interact with it, and I can use the IoX network module if I want to program a specific action such as pressing an Insteon key to turn on the radio while cooking, etc.
What are people doing with HomeKit and HomeAssistant if they've got a mature IoX setup?
Edited by SJK
Clarification of home interfaces
It's probably just to widen the market for the eisy. The world of home automation has evolved from the early geeks who probably started with X10 (...I plead guilty) and has slowly "cunsumerized" itself with shrink wrapped products like Alexa, smart thermostats, and Homekit. Apple users aren't usually techno geeks: they're more often drawn to the slick look of the products and just want it to work. But once we get into home automation, some of us will want more than just a fancy remote control with pre-programmed routines. More often than not, those users will likely also not want to lose their initial investment, but rather add to it. Insteon was successful because it also worked with X10. Now someone who got into automation with Apple products can go the next step and expand into full programmability with the eisy.
Just wait and see what happens after UDI opens up the iSY to every HTML geek in the world.
I suspect ISY will constantly explode, with amazing things, yet to come, everytime some new 10 year old kid learns HTML5 programming,
Agree - I started with this 20 years ago now with Insteon V1 and and Elk integration using the X10 commands and some dedicated hardware interface between the two. Now 2 homes and 2 businesses later I'm on my 5th and final buildout with my preferred kit.
So as I said- dipped toes into water with HomeKit (or spent the time in HA rabbit holes)- can keep it, but not any killer feature to layer on top of a polished IoX setup.
It's just hard to follow with all the Matter this and Thread that hype- sounds great for interoperability in simple setups, but IoX already is integrating and translating between vendors and protocols just fine.
Home assistant integration advantage is you can then use home assistant as main system while having support for old IoX setup, in my case Insteon. I use my polisy just to bridge over Insteon into HA. I could use native Insteon integration but since I already have polisy setup it’s easier. If polisy ever dies I could just put a plm on my home assistant but I’ll probably get Eisy. One of the few things that IoX does better than HA is Insteon support. With 2025 matter Insteon bridge update there should be no need to use the isy integration in home assistant since HA supports Matter (but I still recommend since it works so well). However if you are not using home assistant and just want HomeKit support for Insteon from isy then this seems like the way.
HomeKit advantage is you can use Siri, and also HomeKit is integrated deep into every Apple device like iPhones, iPads, Apple Watch, appletv etc. If you don’t use Apple devices then this is of no benefit but if you do you are missing out. Just because you have HomeKit support doesn’t mean you cannot use other preferred interfaces or apps for specific things, but why not have it ? There are no negative side effects to having devices in HK via a bridge! Home Assistant has a HomeKit bridge integration which allows you to make nearly any device in HA work with HomeKit.
Edited by brians
  • 3 weeks later...
Love the recent announcement re Matter support, but question still is
a) Can we see all eisy devices in HomeKit app?
Or it just that eisy can add matter devices ?
  • 3 weeks later...
My 2 cents on this question.
As it turns out a large number of devices come only with Apple or Android support.  Importantly, if the device is new there are no published API's so you end up with a mess that is extremely difficult to integrate early in the product life cycle. Hence UD Mobile tends to lag behind some of my needs.
I am predominantly a PC user for compute / programming, yet tend to communicate and consume information on Apple devices.  (Apple TV, Phone, Watch, iPad and a MacBook) HomeKit provides notification on all of these devices at once so missing an alert is significantly minimized. I can also respond to these notifications from anywhere with the security of the Apple interface.
I have found that support for Apple HomeKit is increasing and by using Apple Shortcuts I can generally address my integration & Siri needs.
So once EISY supports HomeKit, Matter etc.  I will be able to connect my frontend (All Apple devices as clients) to my backend (server EISY) and hopefully move towards even deeper levels of integration via UD Mobile etc.
I have found the Cellular network connection to my Apple watch very powerful and much loved.  Once I leave the house without the darn iPhone I can remain connected to my infrastructure.
PS (I still think of an iPhone as a bulky leash (to the workplace) that has a tendency to fall out of my shirt pocket, often into water <mumbles expletives>).
Edited by Irakandjii
spelling
