Numeric Values after Updating IoX6.0
@Jimbo.Automates ,
Not sure if this is an issue with UD Mobile or Elk plugin, but after updating to IoX 6.0, UD Mobile is displaying numeric values for certain fields, including Armed Status, Arm Up State, Chime Mode, Physical & Logical Status, as well as some others.
I have synchronized, rebooted eisy, and synchronized again with no change. Please see screenshots.
Thanks for your help.
I just updated to IoX 6.0 as well and ran into the same problem. I use the Alarm system status (Disarmed, Armed, etc.) in my Favorites to show the Armed status of the system and it use to show the status as Armed Away/Armed Stay/Disarmed/etc. Now it only displays a number. This problem would be solvable using Advanced Status except there is no way to do a comparison against the number value that is returned.
Mike
See how I did it from the attached screenshot.
See how I did it from the attached.
Okay, that fixed it. Before 6.0 I didn't need to explicitly set the displayed text in Advanced Status.
Thanks for the response!
Mike
Sure . that's a work around.. BUT WHY DO WE NEED ONE?
this has been a known problem since late October. It fixed itself for a while and then broke again with the last updated.
And NOTHING works right if you are remote... no zwave status, lots of Insteon blanks...
I am sorry to say, but I am reaching the conclusion that UDI has bitten too much too fast and when they fix one thing or add a new feature / complexity, they break something else.
I am running out of time to do "work arounds" and will keep waiting of fixing, imploring UDI to stop advancing until they are stable again.. It's been 2+ years of instability on all fronts.
59 minutes ago, JSchumann said:
How do I get to mapped values on UDM?
Bring up the device you want to map, tap on the three dots at the top right, and select "Configure Advanced Status Color, etc". You'll get the mapped values screen.
The Mapped Status problem seems to be fixed in IoX ver. 6.0.3. Once I did this update and restarted the affected Plugins everything is back to normal.
Mike
Funny, beginning sometime in the last few days, suddenly ELK is reporting actual statuses vs numbers again in UDM..So they must have fixed something on their end, as I haven't done any updates on purpose, but dont know if the UDM app on iPhone did an automatic update or not.
Progress for LOCAL. connections.
Remote connections also fixed ELK status, but Z-wave devices and about ¼ of my Insteon devices still dont report statuses automatically.
