New eisy Model, home r2, 994 upgrade Path offer
I've seen a few posts from 994 users asking about upgrading to eisy. There's another version of eisy hardware just released, read the link for the differences. There's also a new 994 upgrade path discount offer good through 11/21.
Universal Devices
No image preview
Introducing eisy | home r2!
eISY, ev, iot, matter, node server, plugin, powerwall, smartgrid, storage, tesla
Very much seems like MeLE stopped making the old hardware, so just pick and validate a new one. It's a big advantage of moving off of the ISY994 and later apu2 (Polisy) hardware, it's quite easy to move to a new platform as hardware ages.
The CPU is of course tons faster in IPC (the N150 has a new core design from Alder Lake), so that's a good thing, as is lower power consumption from the new process node.
Did notice a few things in the email information.
The new R2 has wi-fi 5.0 and Bluetooth 5.1 and the older wi-fi 6.0 and Bluetooth. May not make much difference for some while it may for others.
don't think i've ever been anywhere close to wifi 5/6 bandwidth limited, though 6 vs 5 might have some security benefits. i run wired, so don't really care. not sure what the eisy uses bluetooth for, aside from initial setup i guess, but i don't use audio on the eisy, and the major performance difference between BT 5.1 and 5.2 is apparently audio-focused. meh.
the power reduction is attractive... the v1 tends to run fairly warm to my touch. moving to this platform was probably good for hardware portability, but i never thought a boost in processing power over the 994 was... necessary for my needs, so any reduction in power, even if it's a reduction in MIPS or whatever (not the case here, i guess), is welcome.
so: cheaper, lower power hardware is the trend i like to see. unless someone explains why i'm wrong, i don't think bluetooth versions matter. i think i would have preferred wifi 6 over 5, but it'd depend on details i haven't tracked down, and i won't, because i view this device as infrastructure, and in my house, infrastructure is hard wired.
i don't see a compelling reason to "upgrade" from v1 to v2. if i get a chance to migrate my v1 into a family member's house, i'll take the opportunity then to move myself to v2.
For the eisy network applications I can think of, WiFi 5 or 6 bandwidths are both like bringing a nuke to a fist fight... meaning WAY more than necessary for rest, mqtt, etc. There is a security difference but can only be exploited by your neighbors or someone parked in your driveway,
Since Wi-Fi 5 barely has support in FreeBSD 15, we're probably 3-4 years away at least until either of these changes make a difference in how the device behaves.
However, if it really bugs you, you can always just take the WiFi card out of the old eisy and put it in the new one, it's just an E-key M.2 card if memory serves.
Doesn't bother me. I just wanted to point it out.
I am 100% happy with my ISY994i as it does everything I need.
WiFi 5, WiFi 6 ... I cannot (in a million years!) imagine either would make a difference for eisy, ISY994, or other home-automation.
But just in case ... my home has been on WiFi 7 (Ubiquiti) for a while now.
So, shocker, Wi-Fi 7 does make a difference for home automation. There's an update in the spec where devices can sleep and be woken, unlike on previous versions where every device constantly sent beacons and filled up the airwaves. This lets you put more HA devices onto Wi-Fi.
But the Wi-Fi 6 in the current eisy only runs at Wi-Fi 5 anyway.
Edited by jec6613
Does anyone even use the wifi capability of their eisy?
The biggest single improvement of the new R2 is probably the reduced power consumption. There have been reports of these little boxes getting quite hot when installed in confined spaces.
  • 3 weeks later...
I upgraded from an ISY994i to Eisy about a year ago. Didn't notice any difference in performance. Several weeks ago my Eisy stopped running programs and responding to Alexa commands. I went to check it and the box was very hot. I spent a few hours rebooting and trying to debug. It did notice an update was available, which restored its functionality (and now requires me to log on to Admin Console with my portal ID and passwords, which takes twice as long).
I don't really know what "locked up" in the Eisy but it was very hot, and I fear it may have shortened its lifespan.
In the last 2 weeks I've had wierd problems occur with an IOLinc that has been working for years suddenly getting communication errors. I moved it closer to the PLM (on the same power strip actually) and then it worked fine. I moved it back to its original location (15 feet away) and it failed again. Like I said, it has been working for years without an issue. Nothing else has been changed in that room. My PLM is over 10 years old and everything else in the house is working fine.
I wouldn't necessarily put the blame on the eisy for iolinc. The iolinc is single band, meaning it doesn't get wireless Insteon signals and is vulnerable to powerline noise,
It's possible/likely that some powerline change, something new plugged in to your house has caused that
This is where I am at as well. However I would like to be able to purchase newer Insteon I3 devices as replacements when device failures occur.
I currently have one older switchlinc 2476S with the failing pushbutton issue I want to replace. I would prefer the I3 device but will need to stick with the 2477S due to my ISY994. Seems a shame not to invest in newer Insteon components when replacements are required.
For me and my ISY994i, the path forward is to replace Insteon with Z-Wave when devices become questionable.
I was just browsing the aartech site (official distributor for UDI products in Canada). The price really shot up with the new eisy r2. It's $589 in Canadian dollars. Ouch.
35 minutes ago, GPritchard said:
And with Shipping, plus taxes - the Aartech pricing pushes us close to C$1k ☹️ Too much
I have thought about the eISY many times but everytime I add up the aartech.ca price and include the matter dongle (still using my old PLM) and add taxes, and shipping, it gets to be $1000 and way too big of a jumps since my $99 ISY introduction.
Same experience roughly the same time. A hard reboot got it going again and I believe I did a fw update after.
I put it off as a fw glitch.
Yup, this has become an expensive sport.
