November 10Nov 10 I've seen a few posts from 994 users asking about upgrading to eisy. There's another version of eisy hardware just released, read the link for the differences. There's also a new 994 upgrade path discount offer good through 11/21. Universal DevicesIntroducing eisy | home r2!eISY, ev, iot, matter, node server, plugin, powerwall, smartgrid, storage, tesla
November 10Nov 10 Very much seems like MeLE stopped making the old hardware, so just pick and validate a new one. It's a big advantage of moving off of the ISY994 and later apu2 (Polisy) hardware, it's quite easy to move to a new platform as hardware ages. The CPU is of course tons faster in IPC (the N150 has a new core design from Alder Lake), so that's a good thing, as is lower power consumption from the new process node.
November 11Nov 11 Did notice a few things in the email information.The new R2 has wi-fi 5.0 and Bluetooth 5.1 and the older wi-fi 6.0 and Bluetooth. May not make much difference for some while it may for others.
November 11Nov 11 don't think i've ever been anywhere close to wifi 5/6 bandwidth limited, though 6 vs 5 might have some security benefits. i run wired, so don't really care. not sure what the eisy uses bluetooth for, aside from initial setup i guess, but i don't use audio on the eisy, and the major performance difference between BT 5.1 and 5.2 is apparently audio-focused. meh.the power reduction is attractive... the v1 tends to run fairly warm to my touch. moving to this platform was probably good for hardware portability, but i never thought a boost in processing power over the 994 was... necessary for my needs, so any reduction in power, even if it's a reduction in MIPS or whatever (not the case here, i guess), is welcome.so: cheaper, lower power hardware is the trend i like to see. unless someone explains why i'm wrong, i don't think bluetooth versions matter. i think i would have preferred wifi 6 over 5, but it'd depend on details i haven't tracked down, and i won't, because i view this device as infrastructure, and in my house, infrastructure is hard wired.i don't see a compelling reason to "upgrade" from v1 to v2. if i get a chance to migrate my v1 into a family member's house, i'll take the opportunity then to move myself to v2.
November 11Nov 11 Author For the eisy network applications I can think of, WiFi 5 or 6 bandwidths are both like bringing a nuke to a fist fight... meaning WAY more than necessary for rest, mqtt, etc. There is a security difference but can only be exploited by your neighbors or someone parked in your driveway,2 hours ago, fisix said:don't think i've ever been anywhere close to wifi 5/6 bandwidth limited, though 6 vs 5 might have some security benefits.
November 12Nov 12 On 11/11/2025 at 8:19 AM, Brian H said:Did notice a few things in the email information.The new R2 has wi-fi 5.0 and Bluetooth 5.1 and the older wi-fi 6.0 and Bluetooth. May not make much difference for some while it may for others.Since Wi-Fi 5 barely has support in FreeBSD 15, we're probably 3-4 years away at least until either of these changes make a difference in how the device behaves.However, if it really bugs you, you can always just take the WiFi card out of the old eisy and put it in the new one, it's just an E-key M.2 card if memory serves.
November 12Nov 12 Doesn't bother me. I just wanted to point it out.I am 100% happy with my ISY994i as it does everything I need.
November 12Nov 12 WiFi 5, WiFi 6 ... I cannot (in a million years!) imagine either would make a difference for eisy, ISY994, or other home-automation.But just in case ... my home has been on WiFi 7 (Ubiquiti) for a while now.
November 12Nov 12 32 minutes ago, GPritchard said:WiFi 5, WiFi 6 ... I cannot (in a million years!) imagine either would make a difference for eisy, ISY994, or other home-automation.But just in case ... my home has been on WiFi 7 (Ubiquiti) for a while now.So, shocker, Wi-Fi 7 does make a difference for home automation. There's an update in the spec where devices can sleep and be woken, unlike on previous versions where every device constantly sent beacons and filled up the airwaves. This lets you put more HA devices onto Wi-Fi.But the Wi-Fi 6 in the current eisy only runs at Wi-Fi 5 anyway. Edited November 12Nov 12 by jec6613
November 12Nov 12 Does anyone even use the wifi capability of their eisy?The biggest single improvement of the new R2 is probably the reduced power consumption. There have been reports of these little boxes getting quite hot when installed in confined spaces.
December 1Dec 1 I upgraded from an ISY994i to Eisy about a year ago. Didn't notice any difference in performance. Several weeks ago my Eisy stopped running programs and responding to Alexa commands. I went to check it and the box was very hot. I spent a few hours rebooting and trying to debug. It did notice an update was available, which restored its functionality (and now requires me to log on to Admin Console with my portal ID and passwords, which takes twice as long).I don't really know what "locked up" in the Eisy but it was very hot, and I fear it may have shortened its lifespan.In the last 2 weeks I've had wierd problems occur with an IOLinc that has been working for years suddenly getting communication errors. I moved it closer to the PLM (on the same power strip actually) and then it worked fine. I moved it back to its original location (15 feet away) and it failed again. Like I said, it has been working for years without an issue. Nothing else has been changed in that room. My PLM is over 10 years old and everything else in the house is working fine.
December 1Dec 1 Author I wouldn't necessarily put the blame on the eisy for iolinc. The iolinc is single band, meaning it doesn't get wireless Insteon signals and is vulnerable to powerline noise, It's possible/likely that some powerline change, something new plugged in to your house has caused that
December 15Dec 15 On 11/12/2025 at 9:45 AM, Brian H said:Doesn't bother me. I just wanted to point it out.I am 100% happy with my ISY994i as it does everything I need.This is where I am at as well. However I would like to be able to purchase newer Insteon I3 devices as replacements when device failures occur.I currently have one older switchlinc 2476S with the failing pushbutton issue I want to replace. I would prefer the I3 device but will need to stick with the 2477S due to my ISY994. Seems a shame not to invest in newer Insteon components when replacements are required.
December 17Dec 17 For me and my ISY994i, the path forward is to replace Insteon with Z-Wave when devices become questionable.
