Wednesday at 10:07 PM5 days Just an advisory about an annoying UI update experience:After a reboot that upgraded IoX to 6.0.3_3, I noticed other packages that needed updating, including eisy-ui from 0.7.2 to 0.8.5. A couple observations:The other updates finished quickly, eisy-ui update took much longer. Eventually the UI said it required a reboot, but the System menu item was unavailable (it said "API not available" when I tried to select it). I had to reboot eisy from the mobile app because the web browser wouldn't display the Reboot ISY button.With the new version, when I first logged in on both Chrome and Firefox, the home screen was black--no menu items, just a black screen and my mouse pointer. It required a refresh to see the contents of the home screen. I thought it was a one-time issue, but it still happens when I haven't logged in to eisy for a few hours.
Wednesday at 10:23 PM5 days After the update packages did you clear your java cache and download the IoX Launcher
Wednesday at 10:56 PM5 days It would really help if UDI came up with a way of indicating the progress of an update. The uncertainty and varying update speed isn't very helpful at seeing if things are proceeding properly.
Wednesday at 11:15 PM5 days Author Unfortunately experiences like this have relegated my eisy to Insteon and occasional ZWave debugging duty. Everything else has moved to Home Assistant. With all due respect to the excellent support of UD and this forum, with UD there always seems to be something or some series of things I was supposed to do before or after an update besides just clicking Update, usually something I find out after it goes sideways. Although in this case I couldn't have avoided the API error, and error messages during updates are all too common. Edited Wednesday at 11:16 PM5 days by landolfi
Thursday at 02:28 AM5 days 4 hours ago, landolfi said:Just an advisory about an annoying UI update experience:After a reboot that upgraded IoX to 6.0.3_3, I noticed other packages that needed updating, including eisy-ui from 0.7.2 to 0.8.5. A couple observations:The other updates finished quickly, eisy-ui update took much longer. Eventually the UI said it required a reboot, but the System menu item was unavailable (it said "API not available" when I tried to select it). I had to reboot eisy from the mobile app because the web browser wouldn't display the Reboot ISY button.With the new version, when I first logged in on both Chrome and Firefox, the home screen was black--no menu items, just a black screen and my mouse pointer. It required a refresh to see the contents of the home screen. I thought it was a one-time issue, but it still happens when I haven't logged in to eisy for a few hours.UD support is aware of both of these issues. I reported them this morning and was told they are looking in to #1 and #2 is a known issue.
Thursday at 03:22 PM5 days Solution 17 hours ago, landolfi said:Just an advisory about an annoying UI update experience:After a reboot that upgraded IoX to 6.0.3_3, I noticed other packages that needed updating, including eisy-ui from 0.7.2 to 0.8.5. A couple observations:The other updates finished quickly, eisy-ui update took much longer. Eventually the UI said it required a reboot, but the System menu item was unavailable (it said "API not available" when I tried to select it). I had to reboot eisy from the mobile app because the web browser wouldn't display the Reboot ISY button.With the new version, when I first logged in on both Chrome and Firefox, the home screen was black--no menu items, just a black screen and my mouse pointer. It required a refresh to see the contents of the home screen. I thought it was a one-time issue, but it still happens when I haven't logged in to eisy for a few hours.The reboot API has changed named between version. So it looks like the eisy-ui server got updated, and the UI was out of sync. A refresh of the page would have fixed it.The black screen issue following login will be fixed in the next release.
