January 5Jan 5 One of my old switches (pic attached) has recently starting randomly switching off and a few seconds later turns back on. It can be anywhere from a a few minutes to 20 to 30 minutes and it happens again. I have about 25 of these and this is the only one with this issue. I'm a LONG time Insteon user and am stumped what the problem could be.Any ideas what could be causing this?
January 6Jan 6 That's an oldy, single band. I had several them at my last house, one at the far reaches of my electrical system. They get flaky after time or power events like brown/black outsTry a restore deviceIf that doesn't work, factory reset and and restore device
January 6Jan 6 17 hours ago, johnmsch said:One of my old switches (pic attached) has recently starting randomly switching off and a few seconds later turns back on. It can be anywhere from a a few minutes to 20 to 30 minutes and it happens again. I have about 25 of these and this is the only one with this issue. I'm a LONG time Insteon user and am stumped what the problem could be.Any ideas what could be causing this?Now that's an oldie. Not necessarily a goodie. I didn't realize that Smartlabs was making the Togglelinc back in '06. Insteon devices from that time frame had power supplies based on a Microchip App Note 954 located here: https://ww1.microchip.com/downloads/en/appnotes/00954a.pdf They had a habit of burning up the filter cap/zener due to powerline voltages/spikes. Another issue was with the micro switch contacts themselves.Since the device is a relay switch, I'd guess that the 470uF cap (c2??) is breaking down (power supply drop out). You could open and inspect, but to be honest, these devices are probably at the end of their useful life. The relay units are not bad to open up (no Triac soldered to the heat sink). I still have a number in service, but when they die, will retire them.The good news is that you apparently have very well regulated power as well as rather "clean" powerlines. Later devices incorporated dual band as well as additional simulcasting improvements.
January 8Jan 8 Update - the app note I posted above is a bit misleading. It is in fact what the older Insteon supplies were "modeled" after. However the Insteon version regulated at 30V (not 5v as is the App note).The attached schematic was developed by jbauer back in 2006. As noted, the schematic is not complete.I found one of my malfunctioning ICON relay units from 2006 (photo's below). I had noted that the unit "cycled" when I pulled it. Unit powered up OK without a load. I disassembled and verified the supply regulated @30V as jbauer had documented. My unit had an additional MOV (SDS 201KD07) across the power input (201V threshold). The C2 470u cap appeared to be in good condition as did the D1 30V zener diode. C1 is the large brown (Mica?) cap. I would not expect this to degrade.
January 9Jan 9 That photo is for the later revision units. With the 24VDC relay. The earlier versions in the schematic had a 120VAC relay and a real small solid sate device to put a120VAC signal on the relay. Also had the two small bypass caps in series as a snubber. Across the relay contacts. They eventually shorted and the load tried to go through them. Magic smoke. Your model has a better snubber network in it.
January 9Jan 9 Thanks Brian. I should have noticed that the relay in the schematic was 120V. Miss on my part. Based on the date codes, my Icon was made about 3 months after @johnmsch 's togglelinc. Hopefully they're the same layout.Would you happen to have a better schematic of the Relay/dimmer versions in this Vintage? Understand if that is constrained by a NDA.
January 9Jan 9 No I have not seen any schematics except the 2412 and 2413 PLMOn the revision you are showing. The 30V Zener is under the horizontally mounted 470uzf cap. I had one of the diodes short killing the whole thing. One thing I did find out. Both revisions have the +5VDC logic supply. Directly connected to the Line hot AC input and regulation is on the - supplies side.
February 26Feb 26 Author On 1/5/2026 at 7:08 PM, paulbates said:That's an oldy, single band. I had several them at my last house, one at the far reaches of my electrical system. They get flaky after time or power events like brown/black outsTry a restore deviceIf that doesn't work, factory reset and and restore deviceThanks guys for all the help. Finally got some time to look at this situation again. Tried the restore but still having the issue.. Please refresh my memory as to how I factory reset on this device? One other issue I just noticed in my troubleshooting.This flaky switch is in a room in a corner of my basement. The rest of the basement lights are all controlled by a 8-button dimmer pad and a couple of scenes. I just happened to notice that when I turn off one of the scenes (which controls 8 separate basement lights), when each light in the scene goes off, so does the light in the corner room, for about a second, then immediately goes back on. This happens with the rest of the lights in sequence in the scene. Not the kind of light show I want to see!
February 26Feb 26 Follow this procedure:1) Pull out ToggleLinc’s Set button to create an air gap.2) Wait 10 seconds.3) Push in Set button and hold it. Do not let go.ToggleLinc will begin to emit a long beep.4) When beep stops, release Set button.A few seconds will pass.ToggleLinc will double-beep.LEDs will return to normal brightness.The connected load will turn on.Then go in iox and restore device to put any scenes back
February 26Feb 26 Author DOH! Now I remember that process and thanks for not telling me to go RTFM. 😁
February 26Feb 26 @johnmsch If you wanted to secure some replacement switches, you might want to look at this. @vbPhil was great to deal with and promptly sent out a few items that I needed for backup / replacement.
February 26Feb 26 Yes, Phil has been great to deal with. Unfortunately he doesn't have any toggelincs.
February 28Feb 28 Author Been a LONG time since I've been in my Admin Console! When I fired it up, I got this error:I then went through the factory reset process and restore. Within about 2 minutes, the off/on flicker returned. Restarted the console and again got the error above again on startup. I guess its safe to assume this old switch is toast. Looks like Insteon has a $59 on/off switch, ordering now.Thanks guys for all the help and stroll down memory lane. Being back in the console reminded me I meant to setup a couple more scenes back in the day... 😁
March 3Mar 3 Author The new switch is on the way. When it arrives, what is the best way to replace it in the admin console?The togglelinc will be replacing the "Office" item in the console. Is there some shortcut to having the new switch use that slot?
March 3Mar 3 The "replace with" feature only works with the same type of device. Dimmer with dimmer, switch with switch, etc. I don’t know if a Togglelinc can be replaced by a non Togglelinc, even bith are switches, or dimmers. The replacement process is done by adding the new device with a temporary name, then right clicking on the old one, selecting "replace with" and picking the newly installed temporary one. If the new one isn't in the list, then it's not deemed equivalent.
March 3Mar 3 Author 2 hours ago, Guy Lavoie said:The "replace with" feature only works with the same type of device. Dimmer with dimmer, switch with switch, etc. I don’t know if a Togglelinc can be replaced by a non Togglelinc, even bith are switches, or dimmers. The replacement process is done by adding the new device with a temporary name, then right clicking on the old one, selecting "replace with" and picking the newly installed temporary one. If the new one isn't in the list, then it's not deemed equivalent.Excellent! Thank you kind sir
March 3Mar 3 To add a note to Guy's suggestion, the original switch has to be moved out of its folder to the root area of the device tree or it wont work. Once replaced (if it works), the new switch can be dragged back to the original folder
March 3Mar 3 6 hours ago, paulbates said:the original switch has to be moved out of its folder to the root area of the device tree or it wont work.THIS! 100% THIS! Many will forget this step and claim it doesn't work just to find out the device was in a folder. Great reminder @paulbates!
March 3Mar 3 @johnmsch If the switch can NOT be replaced by the above mechanism, you will have two steps to complete. One is manual, the other can be automated. I always start with a temporary name until everything is completed below, then delete the old switch and then I rename the temporary name to the original name such as Office.1) Scenes: Any scene the old switch is in, you will need to move the new switch into and duplicate the settings from the original switch. Manual.2) Programs: Any program that contains the old switch can be automatically replaced by the new one by using the Find / Replace command by right clicking on the topmost folder level of your programs and following the prompts to Find the original switch, and replace with the temporary named switch.Hope that helps if it the original shortcut method doesnt work!
March 4Mar 4 Author Wow, thanks guys!If these don't work, I can just delete "Office" and create from scratch. Just doubled-checked and there are only two programs that control that switch
March 4Mar 4 yeh I was going to comment.. Unless it's a keypad, it's often easier to set up new switch, move it into existing scenes and remove old from those scenes. Programs are the trick, if you know that its less of a fishing expedition Edited March 4Mar 4 by paulbates
March 4Mar 4 @johnmsch I will often suggest people make a full backup of your programs in a text file. You can then use the text file to easily search for a device and recreate programs from that rather than memory.It's simple to make a backup for the programs.Programs Tab -> DetailsRight click on the root folder (usually "My Programs")Select "Copy folder to Clipboard"Open a text editor (not a word processing program/app) so it keeps any formatting basic and as textPaste in new text fileNOTES: Be sure you use "COPY" function - NOT export! - this will copy all the programs in a clear "easy to read" format when you paste into your text file.Save the text file somewhere you might keep your IoX backups for future reference. Maybe make note to do this often if you tend to change/update programs throughout the year(s). This file helps remind you of the programs you have and is key in helping to repair any programs that might break if/when you replace items. Good luck with the changes!
23 hours ago23 hr Author On 3/4/2026 at 4:44 PM, Geddy said:@johnmsch I will often suggest people make a full backup of your programs in a text file. You can then use the text file to easily search for a device and recreate programs from that rather than memory.It's simple to make a backup for the programs.Programs Tab -> DetailsRight click on the root folder (usually "My Programs")Select "Copy folder to Clipboard"Open a text editor (not a word processing program/app) so it keeps any formatting basic and as textPaste in new text fileNOTES: Be sure you use "COPY" function - NOT export! - this will copy all the programs in a clear "easy to read" format when you paste into your text file.Save the text file somewhere you might keep your IoX backups for future reference. Maybe make note to do this often if you tend to change/update programs throughout the year(s).This file helps remind you of the programs you have and is key in helping to repair any programs that might break if/when you replace items.Good luck with the changes!Great tip here, wish I had known about this 20+ years ago when I started down the Insteon road! Just did a backup of my ISY. Then followed this process, pasting the output to a new text editor window (UltraEdit) and saved the file with the same name as the backup, with a .txt extension, in the same folder as all by ISY backups. Very cool! Unfortunately, its not going to do me any good right now ☹️Paging through the text file just now, I found one of my programs somehow lost track of a switch and is now pointing to some <Not Specified> errors:If Time is 4:04:04PM And '<Not Specified>' - Unsupported RulesetThen Wait 1 hour (Random) Set '<Not Specified>' DON =100%, Else - No Actions - (To add one, press 'Action')This doesn't seem to be affecting anything obvious I'm aware of right now, but its driving me nuts! Anyone know of a way to go back through the last couple year's ISY backups without having to restore each one of them?Thanks!
21 hours ago21 hr The "Not Specified" refers to a device that has been removed and/or failed.. You need to specify a device.There's no way to extract a single device from a backup.
