January 11Jan 11 Hi All,Been a long time member since ISY, and now using Eisy for my home. I have a vacation home with a bunch of Zooz Z-Wave devices that are connected to a Hubitat C-8 hub. I also have Home Assistant that is able to see the Hubitat devices. Every time I get an email from UD, I'm always asking the question 'Should I upgrade to Eisy at the vacation home?'. So wanted to get some thoughts from everyone. Currently the issue that I have in the vacation home is that I have multiple 3-way switches that are set up in master/slave configurations. No matter what I do, there's always a slight delay when using one of the slave switches. This is irritating as heck for me and the wife. So wondering if I get the Eisy, will my troubles go away since I can set up switches in groups? Is my issue a Zooz Z-Wave issue or a Hub issue? I've done all the troubleshooting I could have (Zooz said to set up in direct connect mode, didn't fix it), and the issue still persists. I guess my options are: Try different Z-Wave devices (leaning toward inovelli), Try Insteon Devices, replace Hubitat.Any thoughts everyone? Thank you! Edited January 11Jan 11 by TomNow2
January 11Jan 11 I don't know how "scenes" work in Zwave, but with Insteon, you set up scenes that make the switches communicate directly with each other, so the eisy isn't involved in the actual communication between them, making for very fast response.
January 11Jan 11 When I started automating my home, the second thing I did (replacing a single manual dimmer with a KPL was the first) was to set up my 3-way stairwell with Insteon devices - a dimmer on the load, and two switches for the top and bottom non-load locations. It has never (and I mean never) failed to operate correctly at any of the locations or had any delay. And I could dim with the non-load switches, even they were the relay (on/off) version, which seemed like magic at the time. I have also taken maximum advantage of the built-in double tap off - the one at the bottom of the stairs turns everything off upstairs, and the one at the top turns off the downstairs and lights the way to bed.Long story, but I highly recommend you look into an Insteon conversion. The links for N-way are in the devices themselves, so there's never any processing delay, and it still works if the controller is nonresponsive. Some of this (multitap, direct links, etc.) has become possible with Z-Wave since I started automating, because that was a while ago, but I still think no one does direct device-device linking better than Insteon to this day. And if you are going to use Insteon, you MUST have UDI's controllers to set it up and control it. Nothing else comes close for ease of use and versatility.-Tom
January 11Jan 11 Author 30 minutes ago, Guy Lavoie said:I don't know how "scenes" work in Zwave, but with Insteon, you set up scenes that make the switches communicate directly with each other, so the eisy isn't involved in the actual communication between them, making for very fast response.Ahh right, I called them groups. Yep, I have scenes at my normal home set up in 3-way setups and I've had no issues either.
January 11Jan 11 Solution @TomNow2 I'm in the "if it ain't broke, don't fix it" camp. Aside from some issues (with z-wave in general) it sounds like things work as you have them setup. There's been a lot of comments through the last several years (and most recently in this thread) that z-wave (by nature) has a "popcorn effect". Meaning what you're experiencing seems to be normal for z-wave in lighting. Changing the controller wouldn't help the nature of z-wave and the inherent issues it has with lighting delays.Initially I'd say just leave it as it is. It's a vacation home and you don't seem to need to mess/fiddle with it how it currently is controlled. The other side of that would be that the investment to change the switches and other automation parts to other devices might outweigh the issues you're currently having, but living with. Sure, you could rip everything out and put in Insteon (for lighting) and have better control of on/off and dimming than what z-wave does, but you would also have a different controller that is going through ongoing development and updates that you'd need to push/update when you got to the vacation property. If the issues you're having are bothersome and you want to fix those then you'd more than likely have to remove all z-wave lighting control and go with a different option. If it's a DYI project then Insteon is probably the best option for that kind of job. Otherwise, there are still different options to consider (see referenced thread linked above). Just changing the controller for the issues you describe won't make things better. Note: I don't know the Hubitat system so can't comment on what it can/can't do. I tried Home Assistant a few years ago and was not impressed (too much learning curve at the time) so can't say if that would be beneficial to use differently.
January 11Jan 11 Author 19 minutes ago, xlurkr said:When I started automating my home, the second thing I did (replacing a single manual dimmer with a KPL was the first) was to set up my 3-way stairwell with Insteon devices - a dimmer on the load, and two switches for the top and bottom non-load locations. It has never (and I mean never) failed to operate correctly at any of the locations or had any delay. And I could dim with the non-load switches, even they were the relay (on/off) version, which seemed like magic at the time. I have also taken maximum advantage of the built-in double tap off - the one at the bottom of the stairs turns everything off upstairs, and the one at the top turns off the downstairs and lights the way to bed.Long story, but I highly recommend you look into an Insteon conversion. The links for N-way are in the devices themselves, so there's never any processing delay, and it still works if the controller is nonresponsive. Some of this (multitap, direct links, etc.) has become possible with Z-Wave since I started automating, because that was a while ago, but I still think no one does direct device-device linking better than Insteon to this day. And if you are going to use Insteon, you MUST have UDI's controllers to set it up and control it. Nothing else comes close for ease of use and versatility.-TomThanks for replying. I'm definitely thinking this is a problem to be solved by Insteon, I'll add it to the list to try.
January 11Jan 11 Author 2 minutes ago, Geddy said:@TomNow2 I'm in the "if it ain't broke, don't fix it" camp. Aside from some issues (with z-wave in general) it sounds like things work as you have them setup. There's been a lot of comments through the last several years (and most recently in this thread) that z-wave (by nature) has a "popcorn effect". Meaning what you're experiencing seems to be normal for z-wave in lighting. Changing the controller wouldn't help the nature of z-wave and the inherent issues it has with lighting delays.Initially I'd say just leave it as it is. It's a vacation home and you don't seem to need to mess/fiddle with it how it currently is controlled.The other side of that would be that the investment to change the switches and other automation parts to other devices might outweigh the issues you're currently having, but living with. Sure, you could rip everything out and put in Insteon (for lighting) and have better control of on/off and dimming than what z-wave does, but you would also have a different controller that is going through ongoing development and updates that you'd need to push/update when you got to the vacation property.If the issues you're having are bothersome and you want to fix those then you'd more than likely have to remove all z-wave lighting control and go with a different option. If it's a DYI project then Insteon is probably the best option for that kind of job. Otherwise, there are still different options to consider (see referenced thread linked above). Just changing the controller for the issues you describe won't make things better.Note: I don't know the Hubitat system so can't comment on what it can/can't do. I tried Home Assistant a few years ago and was not impressed (too much learning curve at the time) so can't say if that would be beneficial to use differently.Thanks for being the voice of reason Geddy. 100% agree with you that I can probably live with it and everything else works fine. That being said, I could essentially try replacing just 3 switches with Insteon and do the programming from the devices themselves to see if it gets fixed. This way The Hubitat would still be controlling all the other switches and my 'test' would be on their own (which is fine). Then again, I think I'm just looking for another project for me to do lol
January 12Jan 12 @TomNow2 , I'm a bit late to the party and I'm confused by the delay that you are seeing with the Zooz switches. Zooz is one of the few manufacturers that allows you to combine their Z-wave switch/dimmer with a conventional mechanical switch. It's one of the reasons I've installed them.In my experience, the Zooz direct wire is far faster (immediate), 100% reliable, and far less expensive than the Insteon "virtual" 3-way.The Zooz direct wire install (below) should be immediate. You mentioned "slave" switches - I assume these are simple mechanical switches. There should not be any interaction with the hub. If actuating the mechanical switch doesn't produce an immediate response in the load, you may have a ramp rate or something else programmed in the Z-wave switch.
January 12Jan 12 Author 6 minutes ago, IndyMike said:@TomNow2 , I'm a bit late to the party and I'm confused by the delay that you are seeing with the Zooz switches. Zooz is one of the few manufacturers that allows you to combine their Z-wave switch/dimmer with a conventional mechanical switch. It's one of the reasons I've installed them.In my experience, the Zooz direct wire is far faster (immediate), 100% reliable, and far less expensive than the Insteon "virtual" 3-way.The Zooz direct wire install (below) should be immediate. You mentioned "slave" switches - I assume these are simple mechanical switches. There should not be any interaction with the hub. If actuating the mechanical switch doesn't produce an immediate response in the load, you may have a ramp rate or something else programmed in the Z-wave switch.Hi IndyMike, thanks for replying but my Zooz switches are in 'virtual' 3-way mode. The Master is connected to the light, and the slaves are the other two 'virtual' switches and not direct wire. There is a noticeable delay with ramp rate on the slave switches. I basically have to remember which switch is the master and use that one for any of my dimming needs. PITA but luckily I don't have to change the light dimming very often.
January 12Jan 12 OK, I understand why the response isn't immediate, but it's surprising that you notice a measurable delay. What specific switches are you using (Zen77, etc) and what type of Z-wave controller (I'm not up on Hubitat). To put things in perspective, I've been moving from Insteon (ISY994) to Z-wave (Home Assistant). I have numerous locations where I have Insteon/Z-wave switches controlling each other. This is a Virtual 3-way from the ISY994 to Home Assistant. I don't notice a delay. Insteon Switch >>>>> ISY994 >>>>> Network >>>> Home Assistant >>>> Zooz Dimmer.Not sure if you have a Hubitat problem or a Slave Switch problem
January 12Jan 12 Author 35 minutes ago, IndyMike said:OK, I understand why the response isn't immediate, but it's surprising that you notice a measurable delay.What specific switches are you using (Zen77, etc) and what type of Z-wave controller (I'm not up on Hubitat).To put things in perspective, I've been moving from Insteon (ISY994) to Z-wave (Home Assistant). I have numerous locations where I have Insteon/Z-wave switches controlling each other. This is a Virtual 3-way from the ISY994 to Home Assistant. I don't notice a delay.Insteon Switch >>>>> ISY994 >>>>> Network >>>> Home Assistant >>>> Zooz Dimmer.Not sure if you have a Hubitat problem or a Slave Switch problemThanks again for responding. I think at this point it's a Zooz Switch issue because I have them all set up as a direct link so they aren't going through the Hubitat hub. I did some extensive troubleshooting and have a post on the Hubitat forums. Notice it's from 2024 lol So yeah, it's been a thorn in my side for a while :) Virtual 3-Way Zooz Dimmers too slow - 🛎️ Get Help - HubitatHere my setup at my vacation home:Hub: Hubitat C8Dimmer Switches: Looks like they are Zen72I think I'll try with the Innovelli's and if the problem is gone, then it was a Zooz problem. Trial and error is fine with me cause it gets me something to do while I'm up there.I'm surprised to hear you switching out the Insteon's, they've been fantastic for me at my primary home! ISY+Insteon+ Home Assistant (for my automations and my zwave/zigbee devices) has been rock solid!
January 13Jan 13 @TomNow2 , read through your posts over at Hubitat. If I understand correctly you are using Z-wave Direct Association between your dimmers to construct an N-Way setup. I've tried that in the past with mixed results but I was using dimmers at opposite ends of my house. One of the things that tripped my up was that OTA firmware updates would break the association. You need to exclude/include devices after an update and then re-associate. I eventually went back to traditional Hub operated scenes which work well (HA).One thing that I did see in your post was that you were trying to "adjust" the dimming level using a slave. Assuming you are using LED bulbs I could see where that might be an issue. The LED dimming curve is non-linear and by the time you see a response in the bulb, you've typically overshot your desired setpoint. Any communication delays will exasperate the issue (you effectively have a bow wave of bright/dim commands in queue).Rather than trying to actively adjust the dimming level, you could use the double and triple tap controls to define scenes with the levels you desire. If doing so, I would eliminate the direct association and program the scenes in the Hub.I will admit that scene control is one of the areas where Insteon excels. I would be surprised if the Innovelli dimmers perform differently in the same configuration. I have a couple of areas where I could add a virtual 3 way rather easily. I'm also curious. I'll take a swing at some configurations and let you know if I learn anything.
January 13Jan 13 Author 23 minutes ago, IndyMike said:@TomNow2 , read through your posts over at Hubitat. If I understand correctly you are using Z-wave Direct Association between your dimmers to construct an N-Way setup. I've tried that in the past with mixed results but I was using dimmers at opposite ends of my house. One of the things that tripped my up was that OTA firmware updates would break the association. You need to exclude/include devices after an update and then re-associate. I eventually went back to traditional Hub operated scenes which work well (HA).One thing that I did see in your post was that you were trying to "adjust" the dimming level using a slave. Assuming you are using LED bulbs I could see where that might be an issue. The LED dimming curve is non-linear and by the time you see a response in the bulb, you've typically overshot your desired setpoint. Any communication delays will exasperate the issue (you effectively have a bow wave of bright/dim commands in queue).Rather than trying to actively adjust the dimming level, you could use the double and triple tap controls to define scenes with the levels you desire. If doing so, I would eliminate the direct association and program the scenes in the Hub.I will admit that scene control is one of the areas where Insteon excels. I would be surprised if the Innovelli dimmers perform differently in the same configuration.I have a couple of areas where I could add a virtual 3 way rather easily. I'm also curious. I'll take a swing at some configurations and let you know if I learn anything.Great informative response, thank you @IndyMike ! I didn't know about excluding and including them again after a firmware update, I will give that a shot!You are correct on the dimming. I have LED's and dimming with a slave dimmer gives a crazy delay. I can't really change them because this is a new construction house with those bucket lights that are flush (kinda) with the ceiling. I didn't realize on the dimmer and LED issue though, so thanks for the education, I never had issues with all my LED lights in my main home and using Insteon dimmers.I do like the idea of using double and triple taps to assign different percentages, right now I have double tap assigned to go to 100%, maybe a triple tap would just do 50% and be good enough. I will definitely try this when I'm back up there.Great ideas for me to try, thank you!!
January 14Jan 14 On 1/11/2026 at 4:32 PM, TomNow2 said:Hi All,Been a long time member since ISY, and now using Eisy for my home. I have a vacation home with a bunch of Zooz Z-Wave devices that are connected to a Hubitat C-8 hub. I also have Home Assistant that is able to see the Hubitat devices. Every time I get an email from UD, I'm always asking the question 'Should I upgrade to Eisy at the vacation home?'. So wanted to get some thoughts from everyone. Currently the issue that I have in the vacation home is that I have multiple 3-way switches that are set up in master/slave configurations. No matter what I do, there's always a slight delay when using one of the slave switches. This is irritating as heck for me and the wife. So wondering if I get the Eisy, will my troubles go away since I can set up switches in groups? Is my issue a Zooz Z-Wave issue or a Hub issue? I've done all the troubleshooting I could have (Zooz said to set up in direct connect mode, didn't fix it), and the issue still persists. I guess my options are: Try different Z-Wave devices (leaning toward inovelli), Try Insteon Devices, replace Hubitat.Any thoughts everyone? Thank you!Unfortunately this is par for the course when it comes to Zwave. I helped a friend with his zwave setup zooz 800 series. I would take UDI controllers over it any day. The programming was terrible with hubitat. With that said, you'd still experience the same thing with EISY and zwave. It was so bad, he ended up ripping all of it out and going with Ra3 like I told him to do from the beginning. Be careful about swapping to insteon though. Depending on your setup, removing those can impact your mesh network. Depending on setup (sounds like the whole home is done so you should be ok), you could potential break the routing table your devices are using to communicate. With zwave being self healing, if you have enough devices, you'll be ok. To me, lighting is an experience and with how zwave works, I couldnt live with its limitations. Regardless of cost, you're paying extra for an experience that you are not getting. Its worth it to upgrade to insteon vs going through what you are dealing with. While there are work arounds, the more you go from natural operation to having to remember different presses (and explaining to people who are already overwhelmed with just the thought of using the system) detracts from enjoying your home and really isnt worth it IMO. Edited January 14Jan 14 by lilyoyo1
January 14Jan 14 @TomNow2 , managed to learn a few things (or re-learn) about direct association. It's been a few years since I last tried it. It was a little painful, but in the end it worked well.As I mentioned above, OTA firmware updates will absolutely break associations. Bit me again - caused me to use some bad words.Devices being associated MUST have the same security level - Bite #2.Certain Zooz devices cannot be used without a load. The ZEN76 and ZEN77 dimmers apparently use current sensing as part of their dimming scheme - totally fouls things up when used without a load - Bite #3. Bad word usage again. Your ZEN72 dimmers are listed as no load compatible. https://www.support.zboxhub.com/kb/article/1737-how-to-use-zooz-switches-without-a-load/Devices must have the same security level - this part I managed to remember.In the end I was able to associate a ZEN77 load connected dimmer with - a ZEN71 switch (on/off), ZEN32 scene controller (On/off, Bright/Dim), and a ZEN77 load connected dimmer (On/Off, Bright/Dim). All devices operated seamlessly with very little delay.Associations for the ZEN77 shown in the graphic below. This is a Home Assistant presentation - hopefully it will translate to Hubitat. The Lifeline association is from the switch to the Hub (all units should have this). The On/Off and Multilevel change associations are required to give "Insteon like" On/Off and dimming control. This actually worked far better than I remembered. There may have been improvements since I last tried things. Target device On level settings - Things didn't seem to synch well until I set the target to 100% on level in settings. Default was previous brightness Notes - the Zen77 devices were using security level S0. This may speed things up.Using two slaves would present far more associations and settings variables. This is where UD's Insteon scene setting shine. They've made things very easy for us.I have no experience with Hubitat. Not sure if there are limitations there.Bottom line - it was far more work getting the z-wave direct association working than anything I've used with the ISY994/Insteon. Once setup, it worked very well and was very responsive. I saw your posts on the Hubitat forum. You don't appear to be the type of person that throws in the towel easily...
January 14Jan 14 Author Thanks @IndyMike and I appreciate you tinkering around and testing all this out. Sounds like you've had as many expletives through this testing as I have. I'm not sure when I'll be back at the vacation home but will try at minimum to un-associate the devices, re-associate, and then get them direct connected. Admittingly, Hubitat's web interface and drivers are kind of kludgy. Looking back I would have been better off associating with my Home Assistant instance. Live and learn I guess. This is the never ending project for me it seems like 😅
January 16Jan 16 I hope things work out for you. I learned/re-learned a number of things going through the process. That's a good day for an old guy. I can't comment on the Hubitat interface - No experience there.Home Assistant was extremely unfriendly back in 2020 when I started with Z-wave. It has improved a lot since then. The Z-wave mapping/healing/manual routing capabilities are very beneficial. The Home Assistant interface to the ISY is excellent. It allowed me to bridge the ISY/Insteon system to HA, melding the two systems (thanks to @shbatm and @bdraco). I use it extensively.I've been using the ISY (26)/insteon since both started. I really can't separate the two since Insteon is nothing without an ISY. I began moving to Z-wave and Zigbee when Smartlabs shut down in 2022. I'll agree that the Insteon solution for lighting and scenes was excellent, but I will not be going back. Their price point combined with their single source nature makes them unappealing. I have a quantity of spare Insteon KPL's that I am coveting (I love these). Everything else gets replaced with Z-wave as attrition takes it's toll. As far as never ending projects are concerned, I prefer to call them Hobbies. My better half agrees - refers to me as her hobby.
January 18Jan 18 When Insteon was on the ropes I started down the path of installing zooz switches controlled with habitat. I was disappointed by the primitive programming method of the habitat but I could see why it might appeal to non programmers. I really missed the scene support and multiway flexibility of the ISY plus Insteon. So when Insteon was resurrected I got a couple EISY hubs and some new i3 stuff and pretty much removed the habitat and zooz, but the few items I have remaining there have been rock solid with no real motivation to change. I never had more than 10% of my devices on hubitat so the decision to move back was easy for me. For a simple set up with few complex automations I think hubitat is fine. Some of the stuff I do with multiple dimming levels, motion triggered temporary lighting and timed automations would be difficult on the hubitat and are pretty easy on the EISY. Also love the REST interface for custom dashboards and the polyglot integration of Lutron, Yolink, etc. So my advice is only move if you have a compelling reason that the current setup does not support for you.
