January 19Jan 19 Is there a way to turn off “upgrade available” in notifications? I get notified daily. Would prefer that notifications be limited to system issues.
January 19Jan 19 If you update then the message won't appear. The updates contain bug fixes and enhancements.
January 20Jan 20 Author 9 hours ago, Techman said:If you update then the message won't appear. The updates contain bug fixes and enhancements.I assume that the message is about a hardware upgrade. Seems to me software might be called “update”. When I click on it, nothing happens should take me to info about an upgrade. Edited January 20Jan 20 by doug95630
January 20Jan 20 Are you receiving the notification in UD Mobile or the Admin ConsoleWhat controller and firmware version do you haveTo update the controller firmware you need to click on "upgrade packages"
January 21Jan 21 Author I’m getting the notification in UD Mobile. In mobile, it says that there is a firmware update available. Though I would think 6.0.4 is higher than 6.0.0. I need to go to my PC to login to the console and to make backups before an update will check tomorrow Firmware update available.Current Version: 6.0.4pg3x-3.3.23Available Version 6.0.0
January 21Jan 21 The current eisy firmware is 6.0.4._1Current eisy-ui is 0.9.0Current PG3x is 3.4.11iIt's possible that one or more needs an update i.e. PG3x
January 21Jan 21 The upgrade available notice is kinda broken. It really needs to have an easy way to see what the upgrade is going to do and a way to skip it (i.e. stop telling you everyday that it's available if you indicate you don't want it). And no, having to go to the forums and search for a post about it is not what I consider easy.When my system is stable, I'm very hesitant to install any upgrades. I'd like to know, before doing an upgrade, that there is something in the upgrade that will solve an issue I am having, if not, I want to skip it. This is for my "production" system. My development systems tend to be kept up-to-date.
Monday at 10:36 PM4 days The message is sent by eisy, through the Plugin Notification group. The group can be disabled in UDM > Notification Tab > Mobile Devices/Groups > Groups.The available was not updated on server side, so it is incorrect. If on 6.0.4 check eisyUI for upgrade specifics, eisy.local/system/upgrade
Tuesday at 02:48 AM4 days 4 hours ago, Javi said:The message is sent by eisy, through the Plugin Notification group. The group can be disabled in UDM > Notification Tab > Mobile Devices/Groups > Groups.The available was not updated on server side, so it is incorrect. If on 6.0.4 check eisyUI for upgrade specifics, eisy.local/system/upgradeOf late, the whole upgrade notification method currently in use by UD, is less than ideal.Besides the issue with UD Mobile notifying you daily about an upgrade, the upgrade notice in eisy, eisy.local/system/upgrade, just doesn't work. It rarely shows upgrade available when there is one. Case in point, I waited for two weeks when others on the forum indicate that the latest firmware was available before I upgraded. The upgrade status page in eisy never showed it was available.It was much better when staff made a post in the forum that and upgrade was available and gave some details about what changed.
