Thursday at 10:01 PM4 days I haven't logged into my polisy in a couple of months, and when I did yesterday, I noticed that I had some updates to do...So, like the good user I am, I do them. Now my Polisy is offline, and I can't get the pg3 node server to start.It seems to be functioning manually, no Alexa. no automation.Current firmware version 6.0.5Current PG3x Vsersion 3.4.18And the portal says I'm offlineAny pointers on where/how to start troubleshooting this?Thanks in advance for any assistancePeteAlso, I've tried to force-reinstall the firmware, with the same result
Friday at 01:39 AM4 days 3 hours ago, PeteEaston said:I haven't logged into my polisy in a couple of months, and when I did yesterday, I noticed that I had some updates to do...So, like the good user I am, I do them. Now my Polisy is offline, and I can't get the pg3 node server to start.It seems to be functioning manually, no Alexa. no automation.Current firmware version 6.0.5Current PG3x Vsersion 3.4.18And the portal says I'm offlineAny pointers on where/how to start troubleshooting this?Thanks in advance for any assistancePeteAlso, I've tried to force-reinstall the firmware, with the same resultStart with rebooting eisy.
Friday at 01:48 PM3 days So are you able to access it with the admin console? If so, you could try redoing the update from there.
Friday at 05:56 PM3 days @PeteEaston you might be better off opening a support ticket with UD to get into specifics. Do you happen to know what IoX version you were running before the update? It's possible that it might have been longer than a few "months" and your system might have been just old enough that the update didn't take to some other underlying system. https://www.universal-devices.com/my-tickets But, yes, as @Guy Lavoie suggests sometimes trying to run the updates from the Java Admin Console again can complete an update process. Can you try to get to this web page (it's local so it's okay to hit continue to site if you get a security alert): https://polisy.local:8443/WEB/sysconfig.txt (you might need to replace "polisy.local" with the IP address of the device. If you do not know the IP address the you can usually find it in connected devices on your router (assuming it's booting up and connecting to the network).
Friday at 06:10 PM3 days Author Putting in a ticket was my next step, it’s only been 100+ days since I was last in. I don’t remember the version I was on but I read the read me before I did it and remember checking to verify it was ok. Yes I can get that page and I also tried to reinstall from the Java app with again the same results Thanks for the info
