August 19Aug 19 Hi @Javi , I see these errors on sync after installing the major update today.They don’t seem to be causing any functionality issues.Can you help me understand what they are?Thanks!
August 19Aug 19 Solution It is a benign error, invalid parameter name mapping for i3Keypad. Will need to be fixed in the next firmware update.
Wednesday at 03:37 PM5 days I'm not terribly technical, but my update went fine, took about 20 minutes to get the reboot dialog. Slick and quick!
Thursday at 05:41 PM4 days I have the same type of error with insteon devices upon sync. Other than that have not had any issues with the upgrade with the exception of not being able to use the java app. I retrieved the newest app from the site but get the error "this version of the admin console is not compatible etc.". The admin console I downloaded is 6.0.5. Has the java been deprecated already? Edited Thursday at 05:50 PM4 days by CRaube Disregard on the java app. went into the java console and deleted the apps. Thought I had checked the box earlier. All good with that.
Thursday at 06:12 PM4 days 28 minutes ago, CRaube said:I retrieved the newest app from the site but get the error "this version of the admin console is not compatible etc.". The admin console I downloaded is 6.0.5. Has the java been deprecated already?You need to clear the java cache before getting back into it. The error you're getting is indication of that. Be sure you select all 3 boxes in the process. If on Windows look for "Configure Java" -> "Settings" -> "Delete Files"
Thursday at 06:12 PM4 days You need to clear your java cache, be sure to check all 3 boxes, then download the IoX Launcher from here:https://isy.universal-devices.com/start.jnlp
