August 19Aug 19 Based on the release notes, no, this would not apply to the Polisy. I believe I read others saying they tried to update their Polisy and nothing changed for them. https://forum.universal-devices.com/topic/46914-os-144-release-is-now-available/
August 19Aug 19 Solution It does work, but the update must be done manually, by accessing the Polisy by ssh. Then you do:sudo pkg upgrade udx isy eisyui pg3xThis method was suggested by Michel at UDI. I've successfully upgraded two Polisys this way. Remember the release announcement warning:If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system. Edited August 20Aug 20 by Guy Lavoie
August 20Aug 20 Author Do you know if this will be enabled/allowed from the Jave console in the future. I'm not that familiar with ssh control of Policy. I get this error when trying that upgrade command. No repositories are enabled. (My OS is 14.3) Edited August 20Aug 20 by EJones01
August 22Aug 22 This contradicts this statement. Do not use SSH to perform the upgrade; this will brick your system.
August 22Aug 22 Just now, brians said:This contradicts this statement. Do not use SSH to perform the upgrade; this will brick your system.That's for the Polisy only.
August 22Aug 22 3 minutes ago, Guy Lavoie said:for the Polisy only.4 minutes ago, Guy Lavoie said:That's for the Polisy only.Ok so I have a polisy do I use ssh to upgrade or not. The instructions are kinda ambiguous I think I see now that is a warning for older kernels Edited August 22Aug 22 by brians
August 22Aug 22 Yes, heed the warning about the freebsd version. This upgrade method was suggested by Michel at UDI. I've personally upgraded all three of my Polisys successfully this way. Page 4 on the following thread has discussion, including instructions on enabling the repositories if needed.
August 22Aug 22 19 hours ago, Guy Lavoie said:Yes, heed the warning about the freebsd version. This upgrade method was suggested by Michel at UDI. I've personally upgraded all three of my Polisys successfully this way. Page 4 on the following thread has discussion, including instructions on enabling the repositories if needed.I ran the command, been a while but I get this when connecting to the web...Should I just be patient now?Uploading Attachment...
August 22Aug 22 That might be normal, I saw something similar during the command line update, probably because the Polisy cannot be fully upgraded to freebsd 14.4. I'd reboot it and then check out that everything is ok.
August 22Aug 22 ok so that system busy went away.. I removed java cache and reinstalled and IoX seems to be on lastest version..Gonna restart now hoping for the best ;)
August 22Aug 22 Ok well that was nerve-wracking.. reboot didn't work from gui, so I did from ssh but was running a continous ping and didnt see drop so presumed crashed.. after a while I hard rebooted Polisy by removing power and it eventually all came back up.I did not have to use the command to set the repo when I upgraded unlike others.I got the impression that we will have to ssh upgrade polisy each time and possibly require to run command to set repo in future ?
August 22Aug 22 31 minutes ago, brians said:I got the impression that we will have to ssh upgrade polisy each time and possibly require to run command to set repo in future ?Very likely. I updated 3 Polisys this way and didn't need to set the repository on any of them. Not sure why it happens for some cases.
September 2Sep 2 On 8/19/2026 at 6:43 PM, Guy Lavoie said:If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system.Hiya Guy,I tried that url a couple of times, but it does not work for me. (Server Not Found.) https://eisy.local:8443/WEB/sysconfig.txtDo you know of another way to check the FreeBSD version?EDIT: I think I just woke up - that link is for Eisy's only? (eisy.local) Edited September 2Sep 2 by Athlon Update my post
September 2Sep 2 8 minutes ago, Athlon said:Hiya Guy,I tried that url a couple of times, but it does not work for me. (Server Not Found.) https://eisy.local:8443/WEB/sysconfig.txtDo you know of another way to check the FreeBSD version?Yes, hardcode the ip address of your controller instead. For example:https://192.168.0.123:8443/WEB/sysconfig.txt
September 2Sep 2 1 minute ago, Guy Lavoie said:Yes, hardcode the ip address of your controller instead. For example:https://192.168.0.123:8443/WEB/sysconfig.txtI just ran https://polisy.local:8443/WEB/and got this - looks like I'm good to go?FreeBSD polisy 14.3-RELEASE-p3 FreeBSD 14.3-RELEASE-p3 releng/14.3-n271444-30ad842dd970 POLISY amd64
September 2Sep 2 6 minutes ago, Athlon said:I just ran https://polisy.local:8443/WEB/and got this - looks like I'm good to go?FreeBSD polisy 14.3-RELEASE-p3 FreeBSD 14.3-RELEASE-p3 releng/14.3-n271444-30ad842dd970 POLISY amd64Yes. So go ahead and do the update, from the comnand line as explained earlier.
September 2Sep 2 1 minute ago, Guy Lavoie said:Yes. So go ahead and do the update, from the comnand line as explained earlier.Thank you!I'm trying to find my user name and password - been using my portal login for so long I may have forgotten it....
September 2Sep 2 2 minutes ago, Athlon said:Thank you!I'm trying to find my user name and password - been using my portal login for so long I may have forgotten it....You only really need the admin password.
September 2Sep 2 2 minutes ago, Guy Lavoie said:You only really need the admin password.That did it - thank you again!
September 2Sep 2 2 hours ago, Athlon said:That did it - thank you again!were you meaning admin for ssh? Mine is admin and password is admin so not the same as the IoX password.. not sure if that is normal or not... I don't remember ever changing it.. sure not the most secure LOL
September 3Sep 3 9 hours ago, brians said:were you meaning admin for ssh? Mine is admin and password is admin so not the same as the IoX password.. not sure if that is normal or not... I don't remember ever changing it.. sure not the most secure LOLYes, for ssh.
