Bye bye admin console polisy implications?
59 minutes ago, Michel Kohanim said:
@apostolakisl , if you are in the staging repo, we made massive changes to support polisy upgrade through eisy-ui (udx 5.0.0_7 to be exact). The only thing is that it will not upgrade the OS above 14.3p5 AND we have no way of testing everything against the old OS. So, although we believe things should continue working, it's just not a guarantee.
This is where eisy ui says I am after the ssh upgrade. It appears I am in the staging repo. I don't know that I need cutting edge features on this polisy, but I would like to be certain it keeps working smoothly, especially with UD mobile.
I also have two of my test Polisys up to 6.1.2_10 as of this morning. There is a known issue with the backups not working, giving an Error 500.
So does this mean if my Polisy is on the Beta repo at 5.0.0_4, I cannot update using the Upgrade Packages button and need to do another SSH update at some point?
Or, should I switch over to the Staging repo?
You need to switch to staging, and then upgrade udx first. Then you can go back to Beta/Production and from then on, you can upgrade using eisy-ui.
Thanks - when you say "upgrade udx first", I assume you mean Upgrade Packages (which upgrades everything)?
I don't see an option to upgrade just one specific component like UDX.
You'll need to do that one by ssh:
sudo repo.staging
sudo pkg upgrade udx eisyui
sudo reboot
Then you'll be able to use eisyui for updates
Actually another minor update will be needed before that works.
Is that why I can't upgrade from eisy_ui yet? I'm in the staging repo, and as of today it's offering 2 upgrades:
PG3x 3.4.25 -> 3.4.26
eisy UI 1.3.11_1 -> 1.4.0
...but pushing the button doesn't do anything - other than putting up the "confirm" dialog and then the "don't reboot" dialog. So I need to do it by ssh one.more.time?
-Tom
-Tom
Yes, upgrade all 4 (isy, udx, eisyui, pg3x) through ssh commands. If it upgrades udx to 5.0.0_7, then you might need to upgrade that way again the next time too.
I am at 5.0.0_7 already, and the staging repo doesn't have an upgrade listed for it. Just PG3X and eisy UI. btw: is it safe to ask for an upgrade for a component that you're already current on? I sure hope so.
-Tom
-Tom
Yup, that's fine. No harm in requesting an upgrade if the version is already up to date, it just ignores it.
