September 14Sep 14 My Eisy has the internal Z matter board which is z wave 700. Is there matter board with z wave 800? I do have some matter devices so would need to keep that functionality.
September 14Sep 14 Yes, there are now several Zwave and Zigbee dongles supported. See the list below.The ZMatter board (despite the name) isn't involved at all with Matter, Matter uses IPv6 through your network interface. So whatever Matter functionality you currently have will remain the same.Z-WaveRequires an external dongle (not included):AeoTec Z-Stick 10 Pro – Dual protocol Zigbee/Z-Wave [ link ]Sonoff Z-Wave 800 Dongle Plus [ link ]Zooz 800 Z-Wave USB Stick [ link ]ZigbeeRequires an external dongle (not included):AeoTec Z-Stick 10 Pro – Dual protocol Zigbee/Z-Wave [ link ]Sonoff Zigbee 3.0 USB Dongle Plus [ link ]
September 14Sep 14 @SHM Take a look at this postZooz Zwave 800LR dongle - Review - eisy - Universal Devices Forum
September 14Sep 14 1 hour ago, Guy Lavoie said:The ZMatter board (despite the name) isn't involved at all with MatterThat does not sound right to me. Is it, possibly, needed if one wants to use matter-over-thread?
September 14Sep 14 2 hours ago, SHM said:My Eisy has the internal Z matter board which is z wave 700. Is there matter board with z wave 800? I do have some matter devices so would need to keep that functionality.Do you mean ZMatter board installed in Polisy? I’m not aware of a way to put it in eISY. Edited September 14Sep 14 by hart2hart
September 14Sep 14 24 minutes ago, oberkc said:That does not sound right to me. Is it, possibly, needed if one wants to use matter-over-thread?I think that was the initial plan. But even the latest release announcement tells us that you need a border router for Thread, and the Zmatter device is now discontinued.
September 14Sep 14 Some Matter devices don't require a border router, it depends what type of matter device you have and whether it supports Wi-Fi or ThreadBorder Router Requirements:Matter over Wi-Fi / Ethernet: No border router is needed because these devices connect directly to your home network.Matter over Thread: A Thread border router is required to bridge the low-power Thread mesh network to your main IP network. The eisy controller does not have a built-in Thread radio.
September 15Sep 15 Of the zwave dongle choices listed above, I’d be prone to favor the sonnoff because based on measurements it is possibly that’s a full 1/2 wave dipole antenna. Thoughts? Edited September 15Sep 15 by hart2hart
September 15Sep 15 Author Would like to try the Z-stick 10 Pro on my eisy running 6.1.1_3/3.4.23 (with ZMatter board). Where do I find the z wave backup on eisy ui so I can restore it to the Z-stick?
September 15Sep 15 In the admin console, Z-wave > BackupBefore changing/adding a dongle remove power from the eisyYou should use a right angle usb adapater so the dongle is vertical Edited September 15Sep 15 by Techman
