October 24Oct 24 For me, I don't get that Error 500:Running versions appear the same as yours (I did reboot following each upgrade): Edited October 24Oct 24 by GPritchard
October 24Oct 24 Author This just started. Worked fine a couple of days ago. Did try a hard re-start, no effect.
October 24Oct 24 Author Figured it out, if you disable PG3 in eisy-ui. backup will not work. If enable works.
October 24Oct 24 Just now, EricBarish said:Figured it out, if you disable PG3 in eisy-ui. backup will not work. If enable works.Very interesting. Is this something that is really reproductible.If so, replicate the error and check what error you are getting in the eisy-ui logs.You can also open a ticket and send your log after replicating this error.
October 24Oct 24 Author Yes it is reproductible. Here is the section with the error codes, looks like something to do with the plugins.All plugs have been moved from PG3 and are now working, but not deleted in PG3.this error with PG3 disabled on backup try.2026-10-24 12:02:24 [error] web: Backup failed: Error: socket hang up at AxiosError.from (/var/eisyui/node_modules/axios/dist/node/axios.cjs:874:24) at RedirectableRequest.handleRequestError (/var/eisyui/node_modules/axios/dist/node/axios.cjs:3299:25) at RedirectableRequest.emit (node:events:509:28) at eventHandlers.<computed> (/var/eisyui/node_modules/follow-redirects/index.js:49:24) at ClientRequest.emit (node:events:509:28) at emitErrorEvent (node:_http_client:109:11) at Socket.socketOnEnd (node:_http_client:617:5) at Socket.emit (node:events:521:24) at endReadableNT (node:internal/streams/readable:1735:12) at process.processTicksAndRejections (node:internal/process/task_queues:90:21) at Axios.request (/var/eisyui/node_modules/axios/dist/node/axios.cjs:4339:41) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async eisyBackup (/var/eisyui/dist/server/services/system.js:600:33) at async /var/eisyui/dist/server/routes/api/authenticated/system.js:86:182026-10-24 12:02:24 [error] web: Error with API request to GET /api/system/backup/create: socket hang up eisy-logs-2026-10-24T16-04-30.zip
October 27Oct 27 @bmercier I got the backup 500 error after the most recent update yesterday.Here;s my debug snippet:2026-10-26 18:28:28 [debug] web: HTTP Request from ::ffff:192.168.0.108 - GET /api/plugins/store/local/list2026-10-26 18:28:28 [info] web: Get local plugins2026-10-26 18:28:28 [http] web: GET /api/plugins/store/local/list : 200 : 15ms 2026-10-26 18:28:31 [debug] web: HTTP Request from ::ffff:192.168.0.108 - GET /api/system/backup/create2026-10-26 18:28:31 [info] web: Backing up zmatter2026-10-26 18:28:31 [info] web: Checking if zmatter is connected2026-10-26 18:28:31 [info] web: zmatter is connected2026-10-26 18:28:31 [info] web: Backing up zmatter/ZWave2026-10-26 18:28:31 [info] web: Backing up IoX2026-10-26 18:28:31 [error] web: Backup failed: Error: socket hang up at AxiosError.from (/var/eisyui/node_modules/axios/dist/node/axios.cjs:874:24) at RedirectableRequest.handleRequestError (/var/eisyui/node_modules/axios/dist/node/axios.cjs:3299:25) at RedirectableRequest.emit (node:events:509:28) at eventHandlers.<computed> (/var/eisyui/node_modules/follow-redirects/index.js:49:24) at ClientRequest.emit (node:events:509:28) at emitErrorEvent (node:_http_client:109:11) at Socket.socketOnEnd (node:_http_client:617:5) at Socket.emit (node:events:521:24) at endReadableNT (node:internal/streams/readable:1735:12) at process.processTicksAndRejections (node:internal/process/task_queues:90:21) at Axios.request (/var/eisyui/node_modules/axios/dist/node/axios.cjs:4339:41) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async eisyBackup (/var/eisyui/dist/server/services/system.js:600:33) at async /var/eisyui/dist/server/routes/api/authenticated/system.js:86:182026-10-26 18:28:31 [error] web: Error with API request to GET /api/system/backup/create: socket hang up2026-10-26 18:28:31 [http] web: GET /api/system/backup/create : 500 : 259ms 2026-10-26 18:28:37 [debug] isy: Subscription vsid 0 had 63217 events for the last 100 hours and 58 minutes.2026-10-26 18:28:44 [debug] web: Subscription vsid 1 had 203 events for the last 4 minutes.2026-10-26 18:28:46 [debug] proxy: Proxy connection check: Successful.2026-10-26 18:28:48 [debug] Polls: Sending short poll to plugin 12026-10-26 18:28:48 [info] Polls: Message sent to plugin (slot 1) successfully
October 29Oct 29 A fix is coming.For your understanding, the problem is a timing issue with the zmatter backup & IoX backup.The zmatter backup creates a background process that creates & removes files in the IoX directory. When PG3x is enabled, it is backed up between the zmatter & IoX backup. This gives time for the zmatter background process to complete.When PG3x is disabled, the zwatter backup may not have completed when IoX backup starts.So the fix will be this:The backup process will no longer automatically trigger a zmatter backup. It will have to be done manually in the Protocols / ZWave section, before doing the system backup, just like it was in AC. There will be a clear dialog explaining that when starting a system backup.
Wednesday at 03:38 PM5 days I noticed this error 500 a couple of days ago, with eisy=ui 1.4.8.I just upgraded to 1.4.9 this morning and it's still happening.
Thursday at 02:46 AM4 days 11 hours ago, Guy Lavoie said:I noticed this error 500 a couple of days ago, with eisy=ui 1.4.8.I just upgraded to 1.4.9 this morning and it's still happening.By chance do you have eisy-ai installed?If so, it is a different problem and after updating to v1.4.9, you also need to update eisy-ai. That should clear the 500 error with backups.
Thursday at 03:05 PM4 days 12 hours ago, DennisC said:By chance do you have eisy-ai installed?If so, it is a different problem and after updating to v1.4.9, you also need to update eisy-ai. That should clear the 500 error with backups.In fact I do have eisy-ai, and happen to have updated it to 2.2.3 just yesterday afternoon. So I tried the backup again this morning and it worked 🙂 Thanks for the heads up!
Sunday at 08:43 PM1 day Sorry to Post here but it appeared issue for others has bee resolved.Mine just started throwing error 500 after starting a backup in eisy.pg3 appears in place, ai is 2.2.3 and on the latest staging. I do however vaguely remember deleting pg3, then brought it back into ui.Any suggestions?Thanks!-Tim
Sunday at 08:54 PM1 day 10 minutes ago, TJF1960 said:Sorry to Post here but it appeared issue for others has bee resolved.Mine just started throwing error 500 after starting a backup in eisy.pg3 appears in place, ai is 2.2.3 and on the latest staging. I do however vaguely remember deleting pg3, then brought it back into ui.Any suggestions?Thanks!-TimYes, UD is aware, as I have been working with them on this. Be patient, they should have something soon.
Sunday at 09:49 PM1 day 51 minutes ago, DennisC said:Yes, UD is aware, as I have been working with them on this. Be patient, they should have something soon.Thank you, not sure if this is the bug they are working on, but maybe it is. Once I deleted the last plugin I installed, both of my eisy's will now perform a backup from the stock system page in eisy.
