October 30Oct 30 @Javi Is it expected after migrating plugins from PG3 to eisy-ui, you loose the associated Favorites in UD Mobile with the next synchronization?That is what I experienced after migrating several plugins over. Since I have a lot of customization programmed in my Favorites, that is a no starter for me. I migrated the plugins back to pg3 and restored UD Mobile from a backup and was able to get my Favorites back working.
October 30Oct 30 Not expected. should only happen if a node address changes or no longer exists, or command no longer exists for custom button.I would try one at a time to check, also install latest staging which has fixes for some issues.
October 30Oct 30 Author 1 minute ago, Javi said:Not expected. should only happen if a node address changes or no longer exists, or command no longer exists for custom button.I would try one at a time to check, also install latest staging which has fixes for some issues.I am on stagging and ran an update this morning just before starting the migration. I also reboot eisy after the update.I didn't notice the issue in UD Mobile until after I had migrated 3 plugins over to eisy-ui. All three lost Favorites after a synchronization in UD Mobile. I got the message about removing old data and did the backup each time, so I was able to restore UD Mobile after reverting the plugins back to PG3.
October 30Oct 30 Ok, based on your other post it could be profiles related. defer until next eisy-ui update.
Monday at 02:15 PM4 days Author On 10/30/2026 at 1:19 PM, Javi said:Ok, based on your other post it could be profiles related. defer until next eisy-ui update.@Javi Should I create a support ticket for the breaking Favorities?
Monday at 07:22 PM4 days Current suggestion would be the same, wait for next update for bug fixes for known issues.
Yesterday at 02:50 AM1 day Author On 11/2/2026 at 2:22 PM, Javi said:Current suggestion would be the same, wait for next update for bug fixes for known issues.@Javi Does today's Staging update contain the fix for this, or do I need to wat for another release before migrating?
Yesterday at 12:52 PM1 day I have had various favorites disappear on ud mobile after various changes to eisy (not plugin migration) many times over the past few years. Fortunately I had ud Mobile backups to restore them.
Yesterday at 03:09 PM1 day 12 hours ago, DennisC said:@JaviDoes today's Staging update contain the fix for this, or do I need to wat for another release before migrating?Staging fixes the known profile issues.
Yesterday at 03:50 PM1 day Author 38 minutes ago, Javi said:Staging fixes the known profile issues.Thanks.While I have not attempted migration again, yesterday I installed the Staging update, rebooted eisy, and after the startup, I still hade the same issue with profiles for Ryse Shade Plugin. I then tried restarting the plugin but that didn't fix the issue.
