November 19Nov 19 This is the message I receive when I click on Create Backup.I have rebooted the eisy.Thanks for your assistance,Ross Edited November 19Nov 19 by Ross
Thursday at 04:54 PM5 days @Ross what version of eisy_ui are you using? There was another post of this error on 1.4,6, but @bmercier indicated this is fixed in 1.4.8. That's now in the production release (I'm running 1.4.8) and do not get this error.Also, if running 1.4.8 what browser are you using?
Friday at 04:09 AM5 days This is probably a permission issue related to one of your plugins. I have had some people have issues while others not from plugins I wrote. Though I believe this is not isolated to my plugins. Currently I am running the latest firmware from the staging repo and all of my plugins installed using eisy ui plugins interface and backups work on my eisy. Ud has said that they are going to fix this on their end, but if it is one of my plugins I would be happy to work with you to debug.
Friday at 06:09 AM5 days Author @apostolakisl I was using your backup plugin. I noticed that the program triggered, but there was no backup on Google Drive.So, I tried to backup the "normal" way by going to System - Backup & Recovery - Create Backup and I that's when I received the Code 500 error.I had successfully backed up 3 times with your plugin (all when testing it) until the error above.Thanks,Ross Edited Friday at 06:10 AM5 days by Ross
Friday at 06:53 AM5 days 39 minutes ago, Ross said:@apostolakisl I was using your backup plugin. I noticed that the program triggered, but there was no backup on Google Drive.So, I tried to backup the "normal" way by going to System - Backup & Recovery - Create Backup and I that's when I received the Code 500 error.I had successfully backed up 3 times with your plugin (all when testing it) until the error above.Thanks,RossIt isn't the backup plugin, it is a different plugin. I believe you are using iox logger which could be the culprit. I just pushed an update to iox logger that I think will fix it. Though i can't confirm because my personal eisy was making backups just fine. It is a file permissions issue. When the native eisy backup runs and it tries to backup a file that it has been denied permission to, it breaks the entire backup. UD has mentioned that they intend to fix this. But in the mean time, I have scoured my plugins for any files that eisyui doesn't have permission to and updated the plugins so it will. v 1.1.4 of iox logger has the fix. http control also had a similar issue but i fixed that a week or two ago. And it appears that different versions of eisy firmware invoke the problem. Or whether the plugin was installed in pg3x or eisy plugins. Please just use eisy plugins since pg3x isn't supported anymore and I'm not testing anything with it. Edited Friday at 06:57 AM5 days by apostolakisl
Friday at 01:53 PM5 days 4 hours ago, DennisC said:Backup file permission issues is fixed in eisy-ui v1.4.10.Good to hear. Do you know if it just ignores files that lack permission or if it has granted itself permissions?
Friday at 02:48 PM5 days Author I updated http control, iox logger and eisy backup (I reinstalled each - I'm not sure if that's the only way to update them).The backup got further along, but it's still not working - it looks like it downloads, but the files look like this: I can wait until v1.4.10 is available in production.FYI - it would be nice for the eisy Plugins page to be similar to the System page and have Current Version and Upgrade To columns - with a button next to each one to upgrade.Thanks,Ross
Friday at 05:16 PM4 days 1 hour ago, Ross said:I updated http control, iox logger and eisy backup (I reinstalled each - I'm not sure if that's the only way to update them).The backup got further along, but it's still not working - it looks like it downloads, but the files look like this:I can wait until v1.4.10 is available in production.FYI - it would be nice for the eisy Plugins page to be similar to the System page and have Current Version and Upgrade To columns - with a button next to each one to upgrade.Thanks,RossThis means that chrome never completed the download. Can you hit ctrl-J in chrome to view your download history and send me a screenshot of that. The names you see there are the temporary files that chrome makes while downloading. Also can you send me a screenshot of your backup history like mine below. I am not having any issues downloading on my system. But with ud making so many changes to everything, there are a lot of moving targets. Are you sending your backups to G-drive or a usb drive and if so are those looking good? Edited Friday at 05:53 PM4 days by apostolakisl
Friday at 05:47 PM4 days OK, my working guess here is the backups are working fine, it is the download that isn't. And the reason may be the size of your backup. Yours is quite large. The way downloading was handled was to have java script download into memory and then save to file. I have changed that so it goes directly to file.And yes, the production version of eisy ui has a bug that doesn't display that you need an update. That is fixed in the staging repo and probably any of the more advanced versions.In the mean time, hit "reinstall" to get v 1.3.3 which has the direct to file download instead of buffering to memory. "reinstall" and "update" are functionally the exact same thing. But it is hard to know there is an update available if the "reinstall" button never changes to "update".
Friday at 07:38 PM4 days 5 hours ago, apostolakisl said:Good to hear. Do you know if it just ignores files that lack permission or if it has granted itself permissions?There were several permissions issues that took awhile to track down and find a solution. Fixing one lead to another issue, anyway it mostly originated with eisy-ai.Release notes for 1.4.10 - Backup: Handle case where plugin file permissions are incorrect. Backup will report which files it could not back up. - Backup: Fix eisy-ai conversation history file permissions before proceeding with backup.
Friday at 07:45 PM4 days 4 hours ago, Ross said:I updated http control, iox logger and eisy backup (I reinstalled each - I'm not sure if that's the only way to update them).The backup got further along, but it's still not working - it looks like it downloads, but the files look like this:I can wait until v1.4.10 is available in production.FYI - it would be nice for the eisy Plugins page to be similar to the System page and have Current Version and Upgrade To columns - with a button next to each one to upgrade.Thanks,RossThere is nothing wrong with your download. Are you using Chrome browser?If so, at the top of the browser, when the download symbol appears, select it and as long as you know the source of the download, select "Keep". The download will then be accepted and the correct file name will appear.This happens if the file is unconventional or of a type not commonly accepted. It is a security measure and part of downloads security procedure. I would imagine other browsers have similar practices. I see it more often when on HTTPS.
Friday at 10:58 PM4 days 3 hours ago, DennisC said:Release notes for 1.4.10 - Backup: Handle case where plugin file permissions are incorrect. The permissions are just fine for the function of the plugin. It is only the way eisy ui's new backup works that makes it incorrect. And plugins being part of backups is a whole new world starting when pg3x converted to eisy plugins. And that was like last month. So this seems to be all a bit of some growing pains.Anyway, as far as I know, I have fixed permissions in all of my plugins so they should backup fully with no errors. Curiously, my personal system has been backing up fine running the later eisy ui firmware. I haven't seen any messages about files not backing up. But perhaps that is because I initiated all the backups from my plugin and never checked any logs when I saw "backup successful". In short, at least with my plugins, the files that didn't have eisy ui permissions were not files relevant to function of the plugin. They were the data files. So a restore to an empty eisy would lose your saved data. If you restored to the same eisy, those files would still be there. So like with iox logger, you would lose your logs, but otherwise it would all be the same.Anyway, I have two users who did have permission issues with iox logger who after my permissions modifications now report success, even with the older firmware that doesn't tolerate a permission fault. So I think my plugins are clean. Yeah! Hopefully done with this.
Sunday at 10:54 AM3 days @Ross On 11/20/2026 at 9:48 AM, Ross said:The backup got further along, but it's still not working - it looks like it downloads, but the files look like this:I believe that this is a Chrome issue, not a plugin or EISY-UI issue.The backup creates a .zip file, which Chrome considers insecure by default if you are using http, so it won't download the file. If you have a secure connection (https) then it should allow the download. If the connection is insecure, after you show Chrome where to save the file, you have to explicitly allow it to keep it. Click on the download icon in the upper right of the Chrome window and click on Keep next to the filename. It usually pops this window up, but sometimes it goes away or gets covered up depending upon what you are doing in Chrome.Alternatively, make sure you are making a connection to EISY-UI using an https:// address and using the portal credentials. In this case, Chrome should allow .zip file downloads without explicit approval.Dave
Sunday at 03:27 PM3 days Author @DNewkirk My link was http instead of https to eisy.local. I will use https in the future.You and @DennisC are correct that I just needed to add the extra step of downloading an insecure file. when I used http.What was weird was that I successfully downloaded several backups over the last month using http (and no extra steps - it just worked). So, perhaps a change occurred at the same time as I started using @apostolakisl backup plugin coincidentally.Also interesting is that it works using https even though my Chrome browser shows the following:@apostolakisl Looks like you're plugin is working as well. Thanks to all for all of the assistance,Ross Edited Sunday at 03:42 PM3 days by Ross
