BobM99
Everything posted by BobM99
  1. BobM99 replied to SHM's topic in YoLink
    Thanks everyone for the advice. Rebooting PG3 didn't work, but rebooting eisy did. In the process, though, my nodes got scattered out of the YoLink folder I created. @Panda88 Grateful for your work on this plugin
  2. BobM99 replied to SHM's topic in YoLink
    I upgraded the plugin to 1.8.66 and it's just going haywire, notifications every few seconds alternating between YoLink failed and connected. I had migrated it to eisy Plugins well before upgrading and everything was fine till I upgraded. I returned the plugin to PG3 and it's still happening. I tried restarting reinstalling, no help. YoLink_11-4-2026_92949_PM.zip
  3. BobM99 replied to Panda88's topic in Blink
    Hi, thanks as always for updating this plugin. I still received a 2FA text. Are you saying that I don't have to reenter the new code? Bob
  4. BobM99 replied to BobM99's topic in eisy
    @Javi Yes! The update fixed it. Wonderful, thanks.
  5. BobM99 replied to BobM99's topic in eisy
    Hi, @Javi Sorry, I'm not sure how to do this if I can't access eisy. And I'm not able to be sure, but I think it was upgraded to 6.1.2_7 through repo.
  6. BobM99 replied to BobM99's topic in eisy
    Hi @Javi . Thanks for getting back to me. Firmware 6.1.2. Eisy went offline for no good reason this morning, briefly came back for a few seconds, then went offline. I tried power cycling, no different. The on-off switch is blue. RIght now I'm not at home, but I can use a wifi plug to disconnect and connect power. When I reconnect power, UD Mobile notifies me that UD Portal is online, 2 out of 11 of the PG3 nodes are connected, then 20 min. later I get a message that says UD portal is now offline. In the process, I can't see anything on UD Mobile get through on https://my.isy.io/ Confession: a day or so ago I updated to the repo versions because people have said it was safe. It was working fine after that for a while.
  7. BobM99 posted a topic in eisy
    Eisy going on and offline this morning. No apparent reason. Just checking to see if anyone else is having this problem.
  8. @DennisC Thanks, that did the trick (kicking myself for not thinking of this). @Guy Lavoie Even from AC, PlugIn Store still doesn't work. We can't be the only two people with this problem . . . or could we?
  9. @Guy Lavoie I'm glad I'm not the only one. Ask for IoX Finder, I can't even get to that part. Once I acknowledge the IoX error, everything just shuts down and disappears.
  10. Hi, Please help me figure out what's going on or what I'm doing wrong. Ever since I upgraded to IoX 6.1.2_3 and eisy-ui 1.3.6 a few days ago, the following has happened: 1) I can't purchase or activate anything from PG3x Plugin Store. I click on the button and nothing happens (photo attached). 2) I can't access the Administrative Console with the Java .jnlp file downloaded from eisy-iu (photo attached). 3) My programs involving timed events have been screwy, although that seems to be working out over time. Thanks for any advice. Bob
  11. @Goose66 NestSDM is working wonderfully, but remains in the non-production store. I see the pinned thread explaining why. With eisy-ui and the changes coming, will this be available in the future? Thanks. Bob
  12. @Panda88 Absolutely interested. It would make programming these tasks easier. Thanks for bringing it up.
  13. Not exactly the same thing, but one of my programs is acting funny after upgrading to beta. This program uses a Z-wave energy monitor to track energy used by my very active sump pumps. The program resets the kWh used by a pump every 30 minutes and alerts me if the kWh in 30 minutes are more or less than the usual range. Recently the program seemingly randomly stops resetting the kWh, causing the number to climb, setting off an alert. I tried tweaking the program but it still happens once or twice a day. The only thing that changed was upgrading. Bob
  14. Mama don't take my Kodachrome away!
  15. Same issue with this leak sensor. You're all not alone.
  16. Thanks for the quick response. I have 4 Z-wave devices that are doing this. I tried waking them up and writing changes, but the problem persists. All of the devices are operating fine as detectors. If anyone has a tip, I'd appreciate it.
  17. Would someone please explain what the orange banners in the screenshot mean? This didn't appear with UI before. Thanks. Bob
  18. Thanks very much for dealing with the Whac-A-Mole situation. One quirk I've noticed for a while now is that I have to restart the plug-in twice before I receive a 2FA text. Either way, working well!
  19. FWIW, the Blink integration on Home Assistant has been broken for over a month: https://community.home-assistant.io/t/blink-integration-broken-after-ha-restart-cannot-complete-2fa-pin-entry-eu-uk-sms-2fa/1013424
  20. BobM99 replied to Panda88's topic in YoLink
    All looks good. Thanks for your work.
  21. I've been using a Nest thermostat that integrates well with eisy and Home Assistant. Funny thing, though -- I thought this would have happened with Nest first, rather than Ecobee. Just waiting for the other shoe to drop.
  22. BobM99 replied to hspindel's topic in eisy
    I don't know if this helps, but I use the SC546a Plug In Remote Chime with eisy, no problems. Bob X10.COMSC546a Plug In Remote ChimeInstantly Add A Doorbell or Warning Chime Anywhere in Your Home Just plug the module into any standard wall outlet, set the house and unit codes, and the modules "sings out" with a pleasant "Ding-Dong
  23. BobM99 replied to SHM's topic in eisy-ui
    I think you have to be on the "Home" page. The page in the screenshot is Home: Nodes. If you click on "Home," it should get you to the screen with the gear and allow you to create tiles.
  24. Lots of thanks to everyone who chimed in here. @paulbates Yes, this was the answer. Unplug eisy and plug it back in! @Guy Lavoie Thanks for being the first to answer. You've always been helpful to me. @hart2hart I do remember the capacitor issue with older PLMs. Thankful that it wasn't the case. @IndyMike Also, thanks for answering. It's all working now, two-way communication. Happy holidays.
